Discussion pertaining to the flagship BMW here. |
Hood wont OPEN!
Another Problem! My hood will not open. I think the cable has broke or has came off. There is no tension on the pully to open the hood inside the car. I tried and tried to get it open but no luck. I kno it has a latch on each side of the hood but have no idea how to get it open. Any advice will help!
Tks in Advance |
Keif is your saviour.....here's his excellent DIY here :
http://www.bimmerfest.com/forums/sho...d.php?t=403879
My BMW ACS7 ![]() |
My hood opens fine from the inside of the car....but the lever inside the grill is kind of strange...point in different directions all the time... and the hood doesnt stand up...falls back down....
You will need to have your Gas filled stuts replaced for the Engine hood.
2007 BMW 750Li w/ Comfort Access and Soft Close Doors Luxury Seating Package w/massaging driver seat, ventilated front seats, a heated steering wheel and rear sunshades Premium Sound Package w/ 13-speaker Logic 7 sound system with an in-dash CD changer Staggered Chrome Rims/Michelin Pilots & BMW Centers |
Dealer.........
Unfortunately it isn't my inside cable. I already took the stuff inside the car apart and it looks good. My problem is under the hood, but guess what???....I can't get the hood to pop. I can not access the locks like on Keifs post because the post is for 745. They added more things and it is not accessable on 750's. I hope there is another way. The dealer told me that tghey would have to cut the cables and it would cost $775.
Easy Fix
I followed Keifs instructions to a the letter and it was pretty easy. Just a word of advice though be prepared to get your hands scraped a lot.
Hood Struts
The hood struts are easy as pie to change, just pull the ring and pop them off. Install is the same as removal.
Once again, Keif's instuctions work PEREFECTLY for 745's. It also worked for taking apart the inside under the dash by the handle. I have a 750 and it is too obstucted to get in there. There are bars, resevoirs, and metal plates in the way.
If anyone in Houston has a 750 that I can look at, please let me know.
Sent from my ADR6400L using Bimmer App
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
can anyone help,,,2003-760li,,,,how to bonnet open???
plz |
