E34 (1989 - 1995)
Old 06-05-2011, 07:04 PM
south26 south26 is offline
Mein Auto: 535i 1989
reasons to change your timing belt on a m20
Hi, I was taking a head off a m20 from a e34. I bought the car to part out. I was told that it had a blown head gasket. Well I have never seen a gasket go like this. I did not count but a number of rockers broke. 6 valves broke, one stuck in a piston. 4 out of the 6 pistons had holes in them.
Remember change your timing belt.
Andy
_________________
Old 06-05-2011, 07:52 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Yes i think thats good advise.That a lot of damage for one event. I can only imagine the sound that made. good pics too. I have two m50 h/g blown engines on Dolly's for the day i decide to rebuild one.
Name:	igors  93 525i m50 012.JPG
Old 06-06-2011, 04:55 PM
gomfrddy gomfrddy is offline
Mein Auto: 93 525i
it sounds like a miniature machine gun or sewing machine....ratatatatatatatatata
Old 06-06-2011, 07:49 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
...But it's got a Mobile 1 oil filter!
Good food, good people, good times.
Old 06-06-2011, 03:31 PM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
Wow, that's comprehensive. Bad head gasket, yyea. Perhaps mail a valve head to the seller
Take my advice, I'm not using it.
Old 10-16-2011, 12:30 PM
Banned
Mein Auto: car
Hi Ross ole' buddy ole' pal !! How are you ??? Have a lovely day !!
Old 10-16-2011, 08:56 AM
Reason to change your timing belt.
Andy
Old 01-22-2013, 03:22 PM
Hi, I thought I would bring this back for those with a m20.
Andy
Old 01-22-2013, 04:22 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Ahhhh .... the joys of an interference engine with a timing belt (that is not properly maintained/changed out)
Most problems are usually something simple !
Originally Posted by noego View Post
It's Deja Poo - as in, I've heard this **** before.
Steve
Calypso Red 1992 525i with 225K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-22-2013, 08:33 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
reminds me i have to do the one on my M40 in my 3er sometime in the next 6 months. ergh. its not a difficult task on either, ive done it several times, but just so time consuming!
E30 above Sold
Last updated 2nd January 2014
Old 01-23-2013, 06:32 PM
but not doing it is some much more time consuming.
Andy
Old 01-23-2013, 11:43 PM
not a true-er word was said
E30 above Sold
Old 10-10-2013, 07:26 AM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Thats what costed me my first car and second car.. Cruising along then all the sudden SNAP!
Time for a new car.. Hadnt gottn into swapping yet.. Seemed to hard back then lol
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 01-04-2015, 07:23 PM
Bump to help with reasons to change your timing belt.
Andy
Old 07-10-2016, 07:07 PM
For those new people that have not seen what happens when you forget to change your timing belt.
Andy
Old 07-17-2016, 06:33 AM
aliff01 aliff01 is offline
Mein Auto: E34 M20 and 850SE
Actually do all m20 engines use timing belts rather than chains?
Old 07-17-2016, 12:29 PM
Yes all m20 use a belt.
Andy
Old 07-17-2016, 07:46 PM
How many kilometers would a new one last before it snaps and what are the signs of it needing a replacement?
Old 07-18-2016, 06:28 AM
No signs, just breaks. In miles it is every 60,000 miles or 4 years. If sitting for 6 years and only has 10,000 miles it should be changed.
Andy
Old 07-19-2016, 07:56 PM
BMW_507_4ME BMW_507_4ME is offline
Mein Auto: 530i
Belt/ chain
As all know BMW used a timing chain in most motors. Even the chain can be a disaster if you don't keep up with the tensioners. The M50's had a double roller timing chain with a mid engine gear on a bearing to take the stress of the chain. My 740IL didn't have that gear, instead, BMW just used plastic chain guides and as such, many failed as a result. BMW must have saved hundreds per car, but their customers (and reputation) lost thousands. I am sure they saved a few bucks using a belt on the M20's also. My advice is to change your tensioners and / or belt often, even more often then you might think you might need too, cheap insurance IMHO
Old 07-19-2016, 08:35 PM
I think you might be over stating the fact about the chain. It is not a common problem and yes can happen but not likely. As to saving hundreds? The m20 with the belt was built to be less of a gas hog compared to the m30, which it was. The belt was suppose to deal with the closer specs compared to the 60s tech that made the m30. I have driven a car with the m30 and have never worried about the chain. I have parted 26 BMWs and have never parted one because of a failed chain., 5 of those had a failed belt. So yes a chain guide can fail but not likely.
Andy
Old 07-19-2016, 09:09 PM
Mein Auto: 530i
Belts VS Chains
Well, you missed my point. It was that chains are much better "IF" properly maintained and don't suffer from a poor design. But I am sure after junking so many BMW's you already know what the major design timing chain flaw was in the M60 0ver the M50. I only have 40 years of fixing and racing cars and bikes under my belt, junking must be much harder and I am sure you learn more by tacking one apart, then by making them run, thanks for setting me strait, I will junk my car tomorrow
Old 07-20-2016, 07:42 AM
Your point might have been to replace parts when they are needed, but instead made it sound much more likely that the chain would break. My point was that in all of the cars I have taken apart I have never seen a problem. Also never said it was easier to take fix a car then part it. If you want to junk your car that is your choice. The whole point of this thread is to help people. M
Andy
Old 07-20-2016, 08:18 AM
Mein Auto: 530i
M62
Andy
Me too, most BMW timing chain designs were great, even going back to WW2 times. But for some reason on the M62 and other V8 motors they decided to negate the idler gear at the lowest and most stressed place the chain travels and replacer it with a plastic runner
The M50 and others had the idler gear and almost never have a failed timing chain, but many 740's and others have died and gone to heaven due to the newer design
Here is a link to a short video that shows just what I am warning other BMW owners to be aware of for their own sakes. My 740 M62 never failed even at 240k miles, but I kept the oil fresh and I changed the timing chain adjusters before any slack and ware could happen. If the link doesn't come through anyone can just google BMW M62 timing chain failure and there will be tons of video's and write ups on it. That is because the are tons of M62 motors in the junk yards. My 530i M50 has the idler gear, so I decided not to junk it just yet, it only has a quarter million miles on it so far
Old 04-04-2017, 04:46 PM
Now that it is getting warmer go out and replace your timing belt.
Andy
