reverse ligth switch - Bimmerfest - BMW Forums
E28 (1982 - 1988)
Old 06-10-2011, 05:26 AM
jason54r jason54r is offline
Mein Auto: 1984 533i
My 84 533i reverse lights will not come on. Where is the reverse light switch located? Bulbs are good, sockets are ok also.
Old 06-10-2011, 02:13 PM
catso's Avatar
catso catso is offline
catso
On a manual trans the switch is near the top of the trans accessible from under the car. On an auto it's part of the neutral/park/back-up light switch at the base of the shift lever mechanism in the console.
![/I][/FONT]
Old 01-22-2012, 12:23 AM
andre535si andre535si is offline
Mein Auto: 535si ,ml320
check for voltage at conector in shift boot one leg should have voltage. I replaced tran. sensor but still no reverse lights turned out to be harness wires bad from boot to trans sensor.
