E36 (1991 - 1999)
Old 07-03-2011, 03:10 AM
ian_alex ian_alex is offline
Mein Auto: e36 convertible
M50 engine noise
I have had a noise issue for several years and which is getting progressively worse as you might expect.
Nothing when cold but when hot at low revs under light load what I can best describe a a dull knock. Under heavy load eg a fast start it does not exist! In any event the noise goes away at higher revs.
With a stethoscope it seems to be from the timing chain area but it is not what I would regard as chain noise.
Various dealers have listened but no ideas except to disconnect Vanos which I did with no effect.
I thought about oil viscosity change with temperature perhaps related to chain tension but this is spring loaded!
What about hydraulic tappets? but location does not stack up
I intend to remove the cam cover to have a look but don't expect to see anything amiss.
There are no performance or any other issues.
Any thoughts or suggestions would be appreciated
Old 07-03-2011, 07:40 AM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Does disconnecting the Vanos actually stop the parts from rotating? I don't think so.
Turbo Build Here
Parting Out Complete 96 328is
Old 07-03-2011, 08:44 AM
crisscross's Avatar
crisscross crisscross is online now
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Nope, it will continue to rattle and make noise until the seals and bearing are replaced, plugged in or not.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3 2000 TiAg 4.4l X5
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 07-03-2011, 02:51 PM
mksu19's Avatar
mksu19 mksu19 is offline
Yes, they're real!!!
Send a message via AIM to mksu19 Send a message via Yahoo to mksu19 Send a message via Skype™ to mksu19
Mein Auto: 04 325i / 05 X3 2.5l
http://www.bimmerfest.com/forums/sho...d.php?t=552051
Originally Posted by bimmerbarbie View Post
...Not everyone can be as beautiful as Mona and me...
Mona B.
