E28 (1982 - 1988)
Old 07-03-2011, 09:49 AM
Melrose Melrose is offline
Mein Auto: 540i
E39 Oil leak solved -- $16. and 30 minutes !!
After spending a lot of money -- $800. plus for parts only on the advice of so-called experts, discovered that my persistent oil leak was coming from the VANOS solenoid seal ($8.00 each ) on the right cylinder bank a 20 minute job.
After two weeks and the residual oil draining off, the five-year problem was solved. It was hidden by a bunch of stuff that prevented even a video camera from seeing it. What the hell I also replaced the left seal in ten minutes with a 10mm socket and wobble extension and a screwdriver for another $8.00
In the meantime the dealers and three other experts tried to convince me the valve covers that were replaced a year ago were the culprit, the valley pan gasket, the cooling accumulator, the EGR system, the backfire plate, the manifold gaskets --- yada yada ya................
The bottom line is most mechanics don't know jack.... I still belive in the value of a college education, and/ or the ability to read a manual or a Bimmerfest forum.
Old 03-10-2012, 10:52 AM
koolkoko02 koolkoko02 is offline
Mein Auto: 540i
Was this for a 540i?
Old 03-10-2012, 02:21 PM
catso's Avatar
catso catso is offline
catso
On an E28?
Don't be gormless; get some gorm!
![/I][/FONT]
Old 03-15-2012, 03:14 PM
paulcomi paulcomi is offline
Mein Auto: 540i 6spd w/ m5 sport pkg
I replaced mine yesterday. The gaskets are held in place with two bolts and simply slide off the solenoid. You just remove the connector from the solenoid, slide off the old one and slide on the new one. The one of the right side of the engine is harder to remove because theres more stuff in the way but with some patience you can do it. The left one is easy once you remove the air filter ductwork.
My local O'Reilly Auto Parts had the oem gaskets for $10 ea. They're hard plastic with a rubber center sleeve.
Old 04-01-2012, 08:53 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
Wrong forum
Jimmy Moreno
1995 530i
1986 535i
Old 04-01-2012, 06:13 PM
south26 south26 is offline
Mein Auto: 535i 1989
yes even with a college education he can not read. I see this all the time since I am a teacher. e28 doe not = e39. I am assuming that they were not not good colleges.
Old 04-01-2012, 06:33 PM
catso's Avatar
catso
Originally Posted by south26 View Post
yes even with a college education he can not read. I see this all the time since i am a teacher. E28 doe not = e39. I am assuming that they were not not good colleges.
+1
![/I][/FONT]
HTML code is Off
