Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 07-05-2011, 03:28 PM
99740il 99740il is offline
Mein Auto: 99 740 il
99 740iL - Radio/GPS/nav not working
Hi Guys,
I have a '99 740iL the radio would randomly come on and shut off. The GPS quit working, so thanks to this forum i started my research to fix my problem. I really wish all of these things were all separate ! oh well !
So after reading and trying my best, here is what I have done.
1. Checked the voltage of the battery, it has been replaced with a new battery. - Didn't fix the issue
2. I pressed the eject button and connected the power simultaneously - Didn't fix the problem.
3. Unplugged the GPS Nav mkII from the car and plugged it back in. Didn't fix the problem.
4. My dad has a 2001 740iL with the same GPS, so i plugged his unit into my car with no luck, I did put my unit into his car and the GPS /radio all work. So my GPS unit is not bad.
So from reading the forums I have a few conclusions,
1. Either my dash display needs to be changed as i do have a few pixels that are bad,
2. Change the ignition as that could be the cause
3. The DSP could be bad. Note: the dsp does not light up on the monitor it is greyed out.
Anything else you guys would recommend? I should try?
Thanks,
Raj
Old 11-15-2011, 01:43 PM
Edrys Edrys is offline
Mein Auto: 2004 BMW 745IL
Raj,
I have the same issue with my 2000 740IL. Did you get to fix it? If so, please post how you fixed it or inbox me.
Old 12-10-2011, 09:37 PM
Lockdown4066 Lockdown4066 is offline
Mein Auto: 740il
I started experiencing several electrical gremlins in the past 2 weeks, to include radio/nav/cd player going on and off to include wipers and other items. I just replaced the ignition switch and all is well in Bimmer land. Good luck
Old 04-30-2012, 11:58 PM
So I have not had much luck as I put the car in non op mode. Now I want to fix it. I think Lockdown4066's answer could be correct. Lockdown was changing the ignition difficult?
Thanks,
R-
Old 05-01-2012, 04:23 AM
setconstr setconstr is online now
Mein Auto: 2001 740i sport 2006 m6
Re:
http://www.bimmerboard.com/forums/posts/244045
2001 740i sport, Dinan upgrades, Bilstein's & H&R 2's , Zimmerman vented rotors, Akebono pads, HID fogs, BSW speakers and subwolfer, MKIV nav, Alpina Lip, OEM clear lights, 3m carbon fiber interior wood delete, 20" BBS, Fast enough for me
dsp, gps, monitor, nav, radio
