E36 (1991 - 1999)
Old 07-07-2011, 05:01 AM
Birds Birds is offline
Mein Auto: 1994 325is
Try to lock all doors through Driver door, Passenger door doesn't lock
Hello again! I have a 94 E36 2 door.
My problem is my passenger door lock. I will lock my doors via putting in the key into the driver's side then turn the key. Driver's door locks, but passenger's door doesn't. I will have to walk over to the other side of the car and put the key into the keyhole of the passenger door then then it to lock it.
Even then, the little knob on the inside does not go down like it is supposed to (it goes down hardly, probably in the millimeters range).
Pressing the driver's door lock while in the car locks the driver's door, but not the passengers'.
I have no aftermarket alarm (or alarm in general) installed, but am planning on getting one. Any thoughts on this and what brand and model to go for? I read that some alarms mess the locking of their E36.
Old 07-07-2011, 05:11 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Most likely an actuator
An for alarms im not sure i have a viper system that has yet to be installed.
Just dont get anything cheap and your should be fine.
http://www.directed.com/ is a trusted company
-Dino
Old 07-07-2011, 04:47 PM
3B2M8WI 3B2M8WI is offline
Mein Auto: 1998 BMW 328i - Avus blue
You could just wait a couple of weeks and it might start working again or at least thats what my actuator wants to do.
Old 07-07-2011, 06:35 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
sounds like an actuator. i suggest taking the doorpanel off and inspect for binding or other interferences. it may just need to be lubricated, or it may need to be replaced. either way you wouldn't know for certain without takig a look at it.
df
Old 07-08-2011, 08:31 AM
Thanks everyone.
I've had this problem for a few months now.
Now time to remove that door panel!
