E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
Brake job: Dealer vs DIY?
Just for fun and comparison:
Dealer's quote: Rear brake job - rotors/pads/sensor/labor/tax ~$1000 US (holly macro!!! components must be gold plated at least and technicians must have PhD) (they keep car for a day, you spend ~ hour between dropping car and picking it up so between you and wife it is 2 hours invested?) Let me me see if it makes sense:\ Brake job on BMW is relatively easy and not requiring special skills or tools...unless you ask SA @ dealer ![]() ( set or sockets, lift, rubber gloves, large rug (so dirt from brakes doesn't go on surface) and small rug - to wipe stuff, can of brake cleaner....) and beer or two.... Not mentioning how smart you will look in your spouses eyes.... Front brakes maybe more sensitive to parts quality but rear is less - though a bit more complicated as it has parking brake... Pads are critical - rotors also. Yah, a bit dirty job.... DIY: BMW parts (if you absolutely insist on original BMW parts): from www.getBMWparts.com parts/shipping $421.22 Savings : $ 579 (~1.5 labor ) You making $286/hour (not bad) OEM quality parts from autohousAZ (my choice) : parts: $235 (no shipping and no tax - delivered to your door). Same Texar pads as BMW uses, Zimmerman rotors - solid coated and balanced... Sensor and piece of noise dumping "stuff". Savings: $765 You are making `$510/hour. Man, that is better than lawyers fees? What am I doing in my job? |
Tell me about it. I have access to a machine shop via my job, and have recently taken up re-surfacing brake rotors for myself. And boy does that help out. I was quoted $150 a piece for rear rotors from the dealer a couple weeks ago. Um, no thanks, they may be "OEM" but I'll pass for now. Now that I'm re-surfacing (talk about flat and parallel mounting and braking surfaces within .001" baby!
I am with you! I prefer a good DIY over paying someone. I might even spring for a little higher quality product
My brake job is looking closer to $700 but higher performance on. Still a hell of a savings.
![]() Schwarz | Premium | Sport | Nav | Sat | Paddles | PDC | Lead Foot | Hardwired Passport 9500ix w/ Escort Live | Convenience | Matte Grill | JB4 | DCI | LI Jammers | smoked side markers | Specdock | rear spoiler | AutoWerke BOV | BMS Oil Catch Can | R1 Cross Drilled Rotors w/ Hawk HPS pads | BMWCCA Peachtree Chapter Member 444107 |
DIY if you know how is the way to go. Since the advent of the all-wheel disc brakes, brake jobs could not be easier. The old drums were a pain because of the initial set and the follow-on, reverse and slam to get the auto-adjuster just right.
----------------------------------- Nube1Kenobi 2008 535i Monaco Blue/Dakota Black/Dark Poplar | Sports Package | Premium Package | Cold WX Package | Navigation, Voice | RTTI | PDC | L7 | HD | I-Pod/USB | PWR rear shade | Sports Auto - paddles | Active Steering | Comfort Access | Fold Down R/seats | Rear DMS Airbags | Adaptive Xenons | Now with recalled and replaced -446 HPFP Do not argue with an idiot else he lowers you to his level and beat you down with experience.. |
Sent from my T-Mobile G2 using Bimmer App |
I got my pads online for $100 and my sensor for $19 and changed it all in about 35 mins. I'd never go to the dealer for brakes...
2004 525i AUTO, STAGGERED 20" BEYERN RAPP WHEELS, 20% TINT, 7.2 HEADREST MONITORS, KICKER AMP & DIRECTED SUB WOOFER, ADAPTIVE 6K HEADLIGHTS & 6K HID FOGS, LED INTERIOR LIGHTING, HEATED STEERING WHEEL
I did all 4 corners, pads only for under $200. Rotors would have added a few more bills. Took a few hours and only special tool needed was a torque wrench. IMHO brakes are fairly easy as long as caliper/piston seals are in good shape and you use top quality parts.
Said "thats how these german cars are made....produce alot of dust but brake well thats why you have to replace them all each time" thoughts? thanks jason |
Your dealer is a liar. I havent replaced rotors in my last 2 brake changes. I measured the rotors and checked the surface and there was no need to replace them. I havent had any trouble out of them at all.
ah perfect, i replaced my fronts rotors pads sensors and all found a shop to do it for just 80$
the rears are squeaking a little now although my sensor says 20k miles left so i was thinking about replacing the pads and sensor myself and seeing what that does... |
I have to check mine on a 2008 535Xi with sport wheels and suspension. |
It is your choice and decision. I change pads and rotors every time... it costs little extra but I can sleep and most importantly brake well.. I tried to change just pads on fairly flat rotors - they warped in the middle of the new pads life cycle... One time I asked shop to resurface. Shop charged me $30/pc.. and these wrapped before new pads expired... After some research I found that every rotor manuf is using different process and some of them make surface harder but once you wear it - the metal under is softer and warping is likely... So now I pay $80 -100 bucks for rotor and have no problem... Bottom line - your life (and others) depends on your brakes - you make the judgement how much risk you wiling to take. I don't "save" on brakes... |
Rotors (almost) never warp. They're not made of putty. The proof is in the measurements. The severe vibration (often called shudder, pulsation, shimmy, judder, etc.), is mainly due to the way you brake. That is, when you brake hard, as in the bottom of an exit ramp, do you leave your foot on the brake pedal? That's a no no! You then deposit an extremely thin "pad imprint" onto the rotor (or so the literature says). That imperceptibly thin pad imprint then collects more and more pad deposition as you drive - ultimately - "warping' the rotors. The long-term solution? a) Bed the brakes properly to deposit an even molecule-thin layer of friction material onto the rotor b) And, modify the way you brake to reduce or eliminate uneven pad deposition The short-term solution? a) Re-bed the brakes (to scrape off the pad deposition) b) Or, turn the rotors (same purpose) & rebed c) Or, replace the rotors & rebed Don't believe me. Believe the experts: - The truth about rotor "warp" (1) REFERENCES: - Avoiding Brake Judder at the Track, by Dave Zeckhausen - Brake Rotor Shake Demystified, by Dali Racing - The "Warped" Brake Disc and Other Myths of the Braking System, by Carroll Smith - 8 Myths ... Holding You Back from Performing the Best Brake Job, by Andrew Markel - Brake Roughness and Vibration: Causes & Solutions, by Dave Mann - There's no such thing as 'warped' brake rotors, by Michael Block - Raybestos Brake Tech School, Part One: Rotors Don't Warp, by Police Fleet Manager Magazine PS: A brake job DIY is trivial to do at home with the right equipment (which is free, after the first brake job). |
I really need help. I just changed my brakes a couple of weeks ago with he help from this site... thank you everyone! It's a 2006 525i.
But the sensor warning did not clear as I hoped it would. I have tried all the "turn the key a little and hold this button for a while" tricks, but my car is not responding like they say it will. What should I do? Buy a code scanner? If so, which one? I bought the car used last year and love it, but these code things are driving me crazy! Thanks, Ed |
Porando,
I just found that today after posting my question. I am going to try it tonight. Thanks! Ed |
While I do not disagree with experts, I am doing what I am doing (replacing rotors) based on my experience. I drive BMW's for over 15 years and my driving habits don't change much...
I replace my brake components and always bed them the way it is recommended. I have done few autocross and race track session, I attended few BMWCCA technical sessions so I am aware of "deposits" physics/chemistry. Even w/o any problems once in a while when I remember I will re-bed my brakes and if they start shaking _ will try to run a "gunk scraping" (aka re-beding) session For all these years I have "experimented" a bit with different quality components, changing pads only or machining rotors... I don't remember having any steering wheel shaking problems while braking (that is what I associate with "warped" rotors) when I change pads/rotors for a good quality ones.... and every time I have done something different - there was a noticeable reaction... Jut maybe a year ago, I ordered a front set for my X5 and unfortunately I made mistake when entering PN so I got front rotors for a car with 4.8L engine which a quite larger... I have not noticed that until I had brakes taken completely apart.....So since my rotors where "not that bad" - has small groves but looked fine, and to return/replace would take a week or so I decided to leave the old rotors in and put only new pads... and see what happens. Everything worked great (as normal) for about 8k miles - and than it started to shake while braking... Pads were not even half through their life when issue become so bad that I had no choice but fix it..... So, I replaced both rotors and pads (could leave pads alone but I just did not want to save $50 and worry about that year or so after.... and brakes are back tot their normal "razor sharp" braking" . Was it "deposit" - maybe but I still believe that it was more related to the temp distribution on rotors or their inability to handle it. Sure it can have nothing do do with rotors but it could be i.e "sticky" calipers ( one site braking harder and making one site of the rotor hotter which could cause warp? )... but if it was caliper I would feel it after I didn't do anything with calipers but only replaced rotors/pads...made about 8k on new set and still no problem. |
The articles referenced above are pretty clear that the rotors don't actually 'warp' (i.e., they don't change shape). Plus, as the photo above asks in the caption, you'd have to measure true 'warp' off the vehicle (as compared to runout) ... and you and I both know almost nobody actually does that. So, almost (if not all) instances of 'warp' are really 'something else'. Whether that 'something else' is merely pad deposits is what you're discussing above. I dunno. Personally, I'd place my bets on the side of the (ample) anecdotal evidence which 'seems' to show that putting larger rotors & calipers (at least on SUVs that have anemic rotors) seems to reduce the instances of brake-related shudder. The theory (in that situation) is the larger rotors dissipate heat better (duh) which then causes less brake pad deposition (which in itself is mostly happening during high-speed (i.e., high heat) stops where the driver leaves their foot on the pedal, thereby causing pad imprints. The theory is that the 'cooler' rotors imprint less. But ... this is just my two cents. |
