E36 (1991 - 1999)
1995 318i, boring to roaring in six weeks (v8 inside) CHANGES UNDERWAY SEE POST 61!!
It starts with an idea.
"A v8 e36 would be fun" It's an idea. It sticks in your head, but you've got a family, a mortgage, and no free time so it stays that way. Then, your side income of flipping cars throws a basket case Monte Carlo SS at you. Restoring it and reselling would be the smart thing. However, for the first time in your life you decide to throw financial gain out and do something for yourself. A junkyard bound $600 e36 stumbles into your path and things start falling into place. It's late June, and Bimmerfest is just six weeks away. A few phone calls later it seems possible; Small Block Chevy E36....build it in just a few weeks. Drive it two hours to Bimmerfest. From here on out, photos will tell a story. This car was built by Myself, My twin brother, Our Uncle, Our younger brother and the joint efforts of a handful of lifelong friends. The goal was obviously to complete the car, and get it to Bimmerfest. The idea came from the desire to blend our love of Bmw, and the e36 body with our uncles love of American muscle together into a car that we can all enjoy. -June 17 2011. Facebook post: "When life gives you lemons, build a v8 e36" -June 18, 2011 The car arrives, and as you can see it's seen better days. ![]() ![]() Tearing the car down and mocking the v8 up... one sleepless night. ![]() ![]() ![]() After looking at some ls1/ 5.0 swap mounts we drew something up and here's what we came up with: ![]() ![]() ![]() Final Mounting: ![]() ![]() ![]() ![]() ![]() ![]() The next several weeks consisted of taking care of various things: -Shifter; stock E36 auto shifter with linkage customized to shift the Chevrolet trans -Drive shaft; The local drive shaft shop had no idea what to do for me since I was using a BMW rear on a Chevy Trans After much trial and error I figured it out....The Chevy rear has the same amount of splines as the BMW (luckyyy) I removed the flange from the Chevy rear and it slid right into the BMW rear. Perfect. Except one small detail. The outer diameter was much smaller than the BMW flange. Solution: I had a friend machine a ring to press onto the GM flange to make it the proper diameter so the rear would not leak. Shorten Chevy driveshaft 6" and we're in business. The body and paint were just plain awful, so that was addressed. The interior was borderline not sanitary.... removed it all, replaced some parts, cleaned what we could, and re-installed it after paint. Rear: the stock 318i rear can't handle the v8. We swapped it with an auto rear from a 93' 325i. Also swapped the axles to 6 cyl. axles as they are beefier. Trans Cross member, was mocked, and fabbed, and modified until it worked as we wanted. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Headers/ Exhaust. Headers are Block hugger shorty headers. This was one of my brother's masterpieces. He cut the collectors off, extended the headers and re welded the collectors so that there was easy access to the collectors and that the steering shaft wouldn't be in the way. A custom dual exhaust set up to exit like an other BMW was made by him as well. ![]() ![]() ![]() ![]() Other loose ends: Wiring. Wiring a carbureted V8 is simple, a few hours and everything was hooked up, a few switches inside and she fires right up. Ecu and ecu wiring were removed, all other electronics are factory, and work. Speedometer works off of the rear so it works as it should. Fuel gauge works as we eliminated the factory pump and replaced it with a flexible hose. The factory Chevy mechanical pump then draws the fuel and things work well. Cooling The radiator from a Fiero fits between our frame rails, so we used that. A trans cooler from an e36 M3 keeps the trans cool. A factory Ac fan does the secondary cooling. factory windshield washer reservoir was converted to a coolant reservoir. Suspension Bilstein Shocks and H&R sport springs hold the car up Braking: Abs was eliminated and fresh lines cut, flared and hooked up to save space...and simplify the car. continued.... Last edited by Fazda; 09-05-2011 at 07:49 PM. |
The next several weeks consisted on assembling the car really.....
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() TUESDAY AUGUST 2, 2011. Complete. Registered. Drives in the parking lot just fine. Success???? No. On the first test drive the 700r4 trans gives up. It looked like our Bimmerfest deadline would fail thanks to something that we didn't even expect. Not one to accept failure I got on craigslist and sourced a trans. Wednesday August 3, 2011. I picked the trans up right after work. Got together with a few dedicated friends and my twin and got to work ![]() By 4 am thursday the trans was in. Car was together.... Success???? No. Torque converter failure. This time things looked gloom. Two hours of sleep, off to work where I made more phone calls than worked.... We were using older 700r4 transmissions with a 27 spline output shaft. That converter was expensive and hard to get on a moments notice. This was a budget build and this week had already lit my bank card on fire. Luck turned for us though. One of our closest friends stumbled across the right person at the right time and showed up at 5 pm Thursday with a later model 700r4 with a a good converter and a common 30 spline output. Go time. By 11 Pm the new trans was in and we were driving the car around flawlessly. Yes. Three transmissions in three days. 7 hours of sleep from Tuesday night to Friday night. Late night test run: ![]() I drove the car 12 miles to work and back friday. Tied up some loose ends after work and we hit the road to Aberdeen around 7:30 Our cooling system needs work, but the car made the trip without major concern... Maryland wooo!!!! ![]() Six cars, Twelve people, 3 hours and we arrived at the Days Inn Aberdeen Late Friday. Saturday Morning August 6th. We celebrate Success, as well as my brother and I's 25th Birthday at Bimmerfest. A fitting end to one of the most fun, exciting, stressful things I've ever been a part of. Hate the car all you want, and many of you will. But I don't think you can hate her story. ![]() Myself on the left, Twin Brandon on the right. Birthday Cake in the center. Thanks to our mother, sister and Uncle who made the two hour trip for the show just to see our success. ![]() I appreciate everything everyone that had a part in building this car has done. Thank You all. Jason and Brandon Draper- Owners Dave McNamee Uncle, tuner, level head to keep things rolling Dylan Draper, the little brother there to do what he could. Brian Pizzo, Michael Kershaw, Pat Bonner, Kyle Ulrich, Brian Bonneau, Steve Heimbach Friends that were there for the long haul. My apologies to our girlfriends, wives, and families. You can have us back now ![]() Thanks for the sleepless nights guys. I'd say we did well. Updates to come as there is plenty we want to change after the road trip. Look for the car at h2o weekend in September in Ocean City!!!! Did I leave something out? Feel free to ask. This was a lot to put together at once! I hope you enjoy the car as much as we do! -Jason |
would that be ocean city nj, or md??
![]() diggin the build, glad to see the pics, and great job!! df oh, and happy belated birthdays to you both!!
Enjoyed the write-up. Nice work, thanks for posting!
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Awesome work! It's incredible that you got that done in only 6 weeks.
-CJ
Props to you!
You rock dude!
![]() RIP Ben "Jever" Doebele, we wont forget you Hi, I'm Chad. Talk to me or GFY ![]() 1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things! 1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
Only bad thing I have to say.
Automatic ![]() But great build and awesome work!
Hopefully she'll be a manual by h2o. There was no meeting our deadline if we had went manual right away, but don't worry its on the to do list ![]() Thanks for the kind words guys. |
Nice work. What's next? Maybe an V8 engine swap on a Z4?
- 2003 525I Sedan - Manual Tranny, M-tech Bumpers Front/Rear, shadowline, M5 Mirrors, 19" Miro 279's, NNR Coilovers, Front lip, 50% tint, Dinan ECU Stage II, Dinan CAI, Dinan Free Flow Exhaust, DICE Ipod, Connects2/Parrot Bluetooth, SSK Kit, AC Schnitzer Shift Knob, CDV Delete, - 2008 R350 Mercedes Wagon |
Great pictures, thanks for writing this up. Dope work.
![]() 1998 328i Koni Sport Suspension |
Stick around man.
I hate seeing these nice cars to go to the beyond.
nothing.
I'd like to try to make it to H20 this year. We'll see.
Amazing Job guys!!!
Love the car looks awesome!!!
97 M3, KW V2 C/O, shark injected, SS Headers, AA Exhaust, Apex Arc8s, Daily Driven, POS, Slammed! |
Great job guys!
It's nice to see an actual completed project in the sea of over ambitious never to be finished (or started for that matter) swap threads. Just one question.. Where's the video?
WOW!! more than just impressive, given the time crunch!!!
1995 325i, 225K miles (yes!), 5sp, LSD, M3 cat back, halo projectors, H&R/Bilstein/etc. suspension overhaul, painted sideskirts... |
Nice work.
Part out. http://bimmerfest.com/forums/showthr...67#post7418867 "Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI Stock 2004 X5 3.0i (Wifes) E30 87 325e |
Hell yes! Awesome!
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
What'd you do for driveline? Keep the e36 trans? If not what about the driveshaft?
Really cool project man, makes me want a v8 e36
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
![]() 700r4 or something.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
To answer your question poorboysracing it is a 700r4 tranny with the stock chevy driveshaft shorten with a custom flange mated to the bmw rear.
What a great post. I like how the car went through about 5 sets of different wheels during the process
I nominate Fazda as an honorary wheel whore!
thats redunkulous!
#25
Lots of respect for anyone who can shoehorn a completely different engine into a car. You guys are car "hackers" in the purest form.
Craig
Winter: 1997 DOHC I-6 2.8L 5Spd BMW 328is (2-Door) Summer: 1992 DOHC I-4 2.0L 5Spd Toyota MR-2 Turbo (2-Seat) Summer: 1983/1984/2007 Honda CB550SC/VF500F/CBR600RR (2-Wheel) |
