Old 08-15-2011, 08:25 AM
RH512 RH512 is offline
Mein Auto: 535i xDrive, C4S cab
compact spare for F10
The problems with the 245/40-19 Goodyear LS2 were well known to me from this forum before i even ordered my car. But since there were really no options to change them, figured I would just see how it went - 300 miles to first bubble - that was in April with no replacements available. After a lot of conversation with my Goodyear retailer and Goodyear corporate, they replaced all four tires with conventional Michelin Pilot Super Sports. Huge improvement in ride and handling.
Then the issue of what if I get a flat? Ordered BMW Mobility Kit, which easily fits under the floor of the trunk. Signed up for AAA. Ordered the BMW jack and tool kit. Put a full size spare in the trunk - though not happy with the amount of room left.
I began a determined quest to find a compact spare that could work. It began as a fruitless exercise, compact tire manufacturers (Continental and Vredestein) pretty much wouldn't even discuss - somehow liability concerns prohibit them. Managed to get to management at BMWNA but no luck, nothing offered in this or I think any market and nothing planned. Phone calls and tens of email were all dead-ends.
Then I came across a thread about creating a spare from various parts for an E92 M3 by Tom Tarzian and GregW / Oregon here: http://www.m3post.com/forums/showthread.php?t=253769
Inspired by what they had come up with- I wondered if it could work for my F10.
Well it turns out that it seems to work with only a different tire than they were using in order to match the stock tires OD!
This is of course is not approved by BMW and I make absolutely no warranty or claims of fitness, but it seems to work for me. Did a couple mile test drive and all was fine.
Keep in mind that the reference thread started 2-1/2 years ago and some prices have changed and I'm listing some different sources as well.
Parts Details:
BMW 36-11-6-768-861 black steel wheel (this is for the X5/X6 compact spare); $88.68 list 70.94 plus $14.95 shipping at getBMWparts.com
BMW 36-12-1-116-326 rubber valve stem, $2.85 list 2.28 at getBMWparts.com
Centering Ring (centric ring) 74.1-72.56 mm many sources on the web; in plastic tirerack.com or aluminum justforwheels.com (had to buy four at $45.99- so three left).
Maxxis 155/70-18 26.54 112M TP10676000, 26.54 diameter- slightly shy of new OE tires- as regular tires are worn will match up, direct from Maxxis $139 delivered, go to estore on maxxis.com then automotive tires then compact spare tires. They ship from GA at least for east coast.
as an alternative, Tirerack has a Pirelli 135/80-18 at 26.5 diameter at $95 plus shipping.
mount and road force balance $20
So for $293.16 I have a compact spare that fits my 535i xDrive.
For a neater look and to cover the flat when it comes off, I ordered the Tire Rack Seasonal Tire Tote, a pair is $19.95
If I'm in an uncomfortable location, can always call AAA and get them to put on the spare but otherwise the BMW jack works well on a level hard surface in my test.
BMW Jack Set, MSRP $161.53 for $129.26 plus shipping at http://www.bmwpartsforless.com/index...eries-interior This fits inside the spare wheel.
My Process:
I had posted a number of times to see if anyone with a X5/X6 could try their spare on a F10, also posted in the M3 thread if someone could try on a F10 but never saw a response. So after a few months I went ahead and ordered the wheel from getBMWparts.com They keep it in stock so it came quickly.
Tried the wheel on the front, it cleared the brake parts with no spacer needed, hub was too large but expected that, centric ring solves the difference. Checked the stock lug bolt lengths and they seemed fine, I can get my hand behind and they catch all the treads and go beyond just a touch but less than the OE 351M wheels.
For a tire, I called TireRack about what they had available, they stock a Pirelli 135/80-18 which is close to the stock diameter. From the M3 thread although a different size they referenced Maxxis, a 155/70-18 is a smige closer to the target in diameter and had a higher weight load rating. So went ahead and ordered the tire from Maxxis. I was going to order the centering ring from 1010tires.com but their website was not responding to taking the order. Googled and ordered from justforwheels.com. I wanted metal- though that's just me. Tirerack has them in plastic as well, I'm sure it's just as good and a lot less money. Used clear RTV silicone to tack the ring to the wheel.
FYI OE OD - 245/40-19 OD 26.72 inches, 245/45-18 26.68, 275/35-19 26.58, 275/40-18 26.66
Took the bits to the tire store for mounting and balancing with the Hunter Road Force - overkill for a spare but I've gone this far. Went lock to lock to check clearances, two mile test drive.
Strapped it on one side to one of the hooks in the back of the trunk.
I think that's it.
ID:	289216   Click image for larger version
ID:	289215   Click image for larger version
2011 535i xDrive (week 11 build) Sophisto Grau, Black Dakota, ZAV, ZCW, ZCV, ZPP, ZMP, ZP2, 2TB, 610, 464, 465, 6NR, 5DL, de-badged, Black Grills, 3M clear bra, Gloss Black Fender Light Trim, Mud flaps, Michelin Pilot Super Sport summer, Michelin Pilot Alpin PA3 on 350M winter
Old 08-15-2011, 08:41 AM
alewifebp's Avatar
alewifebp alewifebp is offline
Mein Auto: 2014 550i
Thanks for the writeup! Does the tire move around at all in the trunk?
Sent from my HTC EVO using Bimmer App
ED on 7/18/2014: 2014 550i, Space Gray, Mocha. M Sport, Cold Weather, DAP, Executive, Lighting
PCD on 9/6/2011: 2011 550i, DSB, black/oyster. Prem 2, Conv, Ventilated, HUD, Sport, DHP, SAT
Old 08-15-2011, 08:58 AM
It's strapped tight on the right, so it can slightly pivot but not a lot, two straps would hold it better, one from each side but that would make the space on each side harder to use.
Old 08-15-2011, 09:09 AM
Me530's Avatar
Me530 Me530 is offline
Happily Driving
Mein Auto: 2014 550i M Sport
Fantastic- this thread should be stickied at the top!
2014 550i M Sport, European Delivery May 2014
2013 X3 35i, Dealer Delivery July 2012
Gone, but not forgotten:
2006 530i
, European Delivery June 2005
2008 335i Coupe 6MT, PCD November 2007
2011 550i M Sport, European Delivery May 2011
BMWCCA #350568
Old 08-15-2011, 09:29 AM
bobr2001 bobr2001 is offline
Mein Auto: BMW 525d 2011
lol
Old 08-15-2011, 09:45 AM
1HOT BMR's Avatar
1HOT BMR 1HOT BMR is offline
Mein Auto: 2015 X5d/ 2012 X5d
Thanks very much for posting this solution.
I too have been hoping to find an alternative to the RFT/no spare thing and this is the best solution I've seen
Old 08-15-2011, 09:49 AM
L1Trauma L1Trauma is offline
WHO DAT NATION
Mein Auto: 2015 M3
Excellent work!
2015 M3 MT SO/SO full leather, CF trim, DAP, Exec, Lighting, 19" black wheels, adaptive suspension, H/K, rear shade
Old 08-15-2011, 10:21 AM
FBI808 FBI808 is offline
Mein Auto: 2011 535i
looks a pretty decent solution for people driving in north east side of the country especially NY.
Old 08-15-2011, 12:44 PM
radarguy radarguy is offline
Mein Auto: 2016 A6; 2015 X5 35ix
Thank you. Excellent info.
Old 08-15-2011, 04:08 PM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Mein Auto: E92 335i
I need a drink after reading that.
Old 08-15-2011, 04:32 PM
Gives you some idea of how many pints I needed to get through it.
Old 08-15-2011, 04:36 PM
TJPark01's Avatar
Mein Auto: E92 335i
Don't get me wrong, I have tremendous respect for the time and effort you put out on this. I can't think of any other hardcore enthusiasts that would do what you did in defiance of the mother ship. Cheers to you!
Old 08-15-2011, 08:27 PM
Rafa Rafa is offline
Mein Auto: 2011 550i
Well said, TJ !
ED on Sep. 28, 2010: 550i Dark Graphite Metallic, Oyster/Black Nappa Leather, Anthracite Wood Trim, Convenience Package, Driver Assistance Package, Premium Package 1 (Std.) & 2, Sport Package, Sport Automatic Transmission, Dynamic Handling Package, Active Cruise Control, Head-Up Display, Side and Top View Cameras, 4-Zone Automatic Climate Control.
Retired: 2008 528i Space Gray.
Old 08-16-2011, 07:54 AM
Emilner Emilner is offline
Mein Auto: 2013 SL63
And to think that BMW actually offers the whole setup for sale, just not in the US
2015 S550 Anthracite blue, Silk, loaded and doin just fine...
2013 SL63 AMG black....
2014 GL350 The kids chariot.
2012 750IL x drive, imperial blue/oyster, a finely loaded beater car... (gone)
2012 650 Cabriolet M sport (gone)
Old 08-15-2011, 06:38 PM
Me530's Avatar
Happily Driving
I bet you don't always drink beer.....
2006 530i
BMWCCA #350568
Old 08-15-2011, 04:29 PM
tdepetra tdepetra is offline
Qualityhound
Mein Auto: 2011 535Xi
I'll buy you a drink someday!!
Old 08-15-2011, 06:26 PM
pera pera is offline
Mein Auto: 2011 BMW 528i
Thanks for the info - very valuable.
Old 08-15-2011, 06:40 PM
Quacker Quacker is offline
Mein Auto: 2012 535i xDrive
Brilliant!
...And if you want, you could probably sell your solution all kitted up.
2012 535ix Space Gray, Cinnamon, SAT, Premium, Prem sound, Cold W., Sunshades, Gloss Black Grille, Gloss Black Side Markers, RE970AS 245/45/19 non-run flats that run very smooth + quiet and also correct the otherwise optimistic speedo
Old 08-15-2011, 07:32 PM
kaysid kaysid is offline
Mein Auto: 2014 535i MSport Xdrive
x2
_____________________________________________
Current:
2014 BMW 535i Xdrive Msport Dark Graphite/Mocha Nappa
Tinted Side/Rear Reflectors|Black Chrome Emblems|M Rear Spoiler|Rear Sunshade| Carbon Fiber Fender Trim | LCI M5 Grilles | M Performance Exhaust Tips
2015 Volvo V60 Wagon Platinum Black/Off Black
Retired:
2011 BMW 535i Xdrive DSB/Venetian Beige
Old 12-11-2011, 08:38 AM
sdg1871 sdg1871 is offline
Mein Auto: 2012 Dinan Stage 2 550xi
Mad props.
2012 Dinan Stage 2 550i xDrive M Sport, Imperial Blue Metallic, Cinnamon Brown Leather and Light Wood Trim. Major options are M Sport package, cold weather package, sport automatic transmission, active roll stabilization, premium sound, and side and top view cameras.
Dearly departed BMWs: 2009 550i M Sport in Carbon Black Metallic and 2003 540i M Sport in Titanium Silver
Old 12-13-2011, 10:19 AM
warantee warantee is offline
Mein Auto: 2011 BMW 535XI
Great information. Thanks for the write up!
2011 BMW F10 535XI
2009 Harley VROD (Muscle)
2008 Mercedes GL450
2003 BMW E46 330CI
2003 BMW E66 745LI (Retired)
1997 BMW E39 528I (Retired)
1995 BMW E36 325I (Donated to X)
Old 12-13-2011, 11:01 AM
Thought I could add this to the original post but guess it's too long ago.
Since my project I've become aware of the following new information:
realOEM.com is listing a BMW part number for a spare and tool kit for the F10, it is 36112159862, however my checks at getBMWparts.com and BMWpartsforless.com does not bring up anything for that number.
Bimmerzone is selling a spare kit, basically what I have done though they've used the 135/80-18 as TireRack sells instead of the Maxxis 155/70-18 for those that don't want to go- la carte.
Old 01-23-2012, 08:52 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
I'm doing a spare tire with a Maxxis 145/70 R17 for my 2011 335D M sport. I'm wondering if a TPM sensor should be put inside the wheel. I know it's only for a temporary ride but the little screen thing will be going off while one of the 4 sensors is not present. Is this to be expected and I should not worry with the sensor. It might not even fit on the 17x4 rim i'm going to use. The 145/70 R17 pretty much nails the height matching compared to the normal tires which are 225/40R17 front and 255/35R17 rear. The biggest deviation between the two is only .093" or 2.4 mm. The front tire is taller than the rear. The rear tire is only .035" or 0.9 mm taller than the spare. So, the match is best for the most important spot.
Here is little different twist I'm doing though. I'm going with an E53 X5 scissor jack with a long jack handle. I'm getting the jack out of a auto salvage on Ebay ($50 +free shipping) and purchasing the long handle from local dealer for $15. I still need a 17 mm lug wrench.
Wheel & valve stem $82
Maxxis tire $150 ( i got hit with $11 texas sales tax)
Mount and balance $16
Scissor jack for X5 $50
Jack handle $15
$313 and counting. I didn't need a centering ring as the 17" rim fits well. I'm hoping to get a 17 mm wrench for less than $25
Old 01-10-2013, 05:07 PM
septaken septaken is offline
Great info thanks...
Old 02-13-2013, 07:48 AM
chuck92116's Avatar
chuck92116 chuck92116 is offline
Mein Auto: 2015 435i Convertible
Reviving thread with updated information
Just an update on this thread for those of you who want a simple solution.
Genuine BMW F10/F11 Series Space Saver Spare Wheel Kit is available on www.ebay.co.uk web site from a BMW/Mini Dealer.
http://www.ebay.co.uk/itm/1210636074...84.m1439.l2648
Part number 36 11 2 159 862
Total cost with shipping is around $550. (Shipping is about $110 U.S.)
This is the best thing I have seen, it includes the tire, wheel, jack, gloves, etc. and even includes the bag (around $100 alone) to store everything in the trunk.
I am not sure why BMW won't sell this in the U.S. Even if you keep run flats, the kit offers piece of mind on long road trips.
ID:	362045   Click image for larger version
M Sport, M Performance Power Kit
2016 Lexus CT200H
2016 Lexus NX200t
