Old 08-19-2011, 12:02 PM
RJ RJ is offline
Mein Auto: 2015 320i xDrive
X35D FAULTS 4D32 AND 4B1C replaced active urea tank and fuel filter heater at 43,68
Sorry the text below is in upper case but that is how the SA typed it.
At 43,683 Kms
CHECK ENGINE LIGHT ON-
CUSTOMER HAS BEEN IN FOR SAME CONCERN TWICE IN LAST 2 WEEKS. PLEASE CHECK AND ADVISE. CAUSE HAS BEEN A SENSOR THAT HAS FAULTED MANY TIMES. CUSTOMER HAS BEEN TRYING TO KEEP BATTERY CHARGED.
CAUSE: BP
CORRECTION - FAULT MEMORY READOUT. FAULTS 4D32: ACTIVE TANK TEMP SENSOR PLAUSIBILITY AND 4B1C: FUEL FILTER HEATING ACTIVATION STORED. TEST PLAN B1365-D7KSH-FUEL FILTER HEATING CARRIED OUT. AS PER TEST PLAN FUEL FILTER HEATER CONNECTOR WAS REMOVED AND CONFIRMED AS OKAY. PROPER POWER, GROUND AND ACTIVATION SIGNAL CONFIRMED AT CONNECTOR. AS PER TEST PLAN FUEL FILTER HEATER IS FAULTING INTERNALLY AND MUST BE REPLACED. FOR FAULT 4D32 TEST PLAN B1365-D7SCRAKTNK-SCR ACTIVE TANK TEMP SENSOR WAS CARRIED OUT. TEST PLAN FOUND THAT TANK TEMP SENSOR WAS READING 75 DEG C. AFTER VEHICLE HAS BEEN ON HOIST FOR 2.5 HOURS WITHOUT ENGINE RUNNING. TECH CONFIRMED TANK HEATERS WERE NOT OPERATIONAL DURING THIS TIME BY CHECKING ECU FUNCTIONS. TECH REMOVED ACTIVE TANK SENSOR CONNECTOR AND FOUND TANK TEMP SENSOR READING 1.48KOHMS COMPARED READING WITH BRAND NEW TANK. NEW TANK READ 11.3KOHMS AT SAME AMBIENT TEMP. TC CASE 47727125 SUBMITTED. AS PER TC NEW ACTIVE TANK ASSMEBLY MUST BE INSTALLED.
COMPLAINT: AS PER LINE 1 DIAGNOSIS PLEASE REPLACE FUEL FILTER HEATER FOR FAILING.
CAUSE: BP
CORRECTION: FUEL FILTER HEATER HAS BEEN REPLACED AS PER DIAG ON LINE 1
COMPLAINT: AS PER LINE 1 DIAGNOSIS PLEASE REPLACE THE UREA ACTIVE TANK
CAUSE: BP
CORRECTION: NEW SCR ACTIVE UREA TANK HAS BEEN INSTALLED. TANK HAS BEEN FILLED WITH UREA. VEHICLE SCAN PERFORMED AND REFILL DETECTION CARRIED OUT. TANK TEMP SENSOR NOW READING PROPER AMBIENT TEMP. FAULTS CLEARED AND ROADTEST CARRIED OUT. FAULT SCAN AFTER ROADTEST FOUND NO FAULTS STORED.
2002 325i, Titanium Silver, Step, premium package - salvaged.
2009 X5 xDrive35d Platinum Bronze Metallic, Beige Nevada Leather, Premium Sound Pkg, Premium Pkg, Comfort Pkg, Technology Pkg. - Traded.
2014 X5 xDrive35i Luxury Line Mineral Silver Metallic, Ivory Dakota Leather, Fine line Pure Wood trim, BMW Connected Drive Services, Driver Assistance Pkg., Premium Pkg.
2015 320i XDrive Sport Line Pkg, Navigation Pkg, Connected Drive w/ ARTTI, Mineral White Metallic, Black Dakota Leather
Old 12-22-2011, 10:20 PM
kkratochvil kkratochvil is offline
Mein Auto: 2015 BMW X5, xDrive35d
I just had a similar Active Tank Sensor replacement done after I had the Emissions/CEL light on for a bit in my 2010 x5, 35d. Same code as was reported here, 4D32.
They replaced the sensor first part of this week. So far, so good.
Old 12-23-2011, 11:03 AM
ard ard is offline
Resident Curmudgeon
Is there a question in this thread?
Just wondering. If it is just to capture and document the two fault code, thumbs up.
A
Old 12-24-2011, 12:42 AM
No question. I was just posting that I had the same code and issue, as I was reading some other posts surrounding DEF issues and thought it worthwhile to note for others.
Old 01-15-2013, 02:51 PM
djs335d djs335d is offline
Mein Auto: N/A
@kkratochvil @ard - no question here either - similar problem and codes:
a followup on 4D32...
My yellow emissions light came on and my 2010 335d (40K miles) and it spent Friday 12/7 - Wednesday 12/12 in the shop - at least they gave me a 2012 535i xdrive as a loaner. Here's the write up:
Tech performed short test with charger. Found 2 faults in DDE, 4B82 EGR and 4D32 Reducing Agent. Followed both test plans, reducing agent faults. Test plan states will occur in winter. Clear fault and drive vehicle to see if fault returns. EGR test plan - function test EGR, EGR sticking. Tech removed EGR and inspected. Found carbon build up in EGR valve. Needs to be replaced. Diag code received. Test drove and active tank sensor fault returned. Original test plan stated to replace active tank if fault returned. Ran test plan again and received diag code...."waited for parts"...When replacing tank, tech found pump submerged in fluid crystals. Tech drained fluid from system, replaced tank and pump. Refilled system, cleared faults, test drove.
Parts replaced: EGR Valve, SCR Container, Supply Module, Diesel Exhaust Fluid, 2 clamps.
So far so good.
now - 2011 335i xDrive - MSport, PPK
then - 2010 335d - Sport Package
Old 01-16-2013, 09:19 PM
dcharnet's Avatar
dcharnet dcharnet is offline
Mein Auto: BMW '15 X5 35d
Anyone have an idea of the cost of this had it been outside warranty?
Old 08-21-2013, 01:48 PM
Turbo_D Turbo_D is offline
Mein Auto: 335d
Hi everyone!
I'm new to this forum but not to BMWs.
I just got a BMW dealer quote to replace the active urea tank.
$3300 for parts and labor!
Old 01-16-2013, 08:01 AM
ard ard is offline
Resident Curmudgeon
Thanks for adding to the knowledge base. It will be important, useful and valuable in the future!
A
Old 01-16-2013, 08:16 AM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
both are common your x5 was in good hands.
Sent from my Nexus 7 using Bimmer App
Old 08-21-2013, 02:05 PM
Mein Auto: N/A
Update - April trip: SCR container
August trip - Metering Unit, Processing Unit, SCR Container
Each trip also had miscellaneous clamps/bolts and replacement of the urea.
Old 08-21-2013, 02:50 PM
Mein Auto: 335d
Thanks for the update!
Do you have the service reports handy?
Old 08-21-2013, 02:59 PM
Mein Auto: N/A
I do - and I just found the December one - replaced the SCR Container, EGR Valve, and supply module in that one...
Old 08-21-2013, 06:26 PM
Mein Auto: 335d
Can you please post the service reports? Or PM me. Thanks!!!
Old 04-04-2014, 07:57 AM
MudyOvl MudyOvl is offline
Mein Auto: X5 xDrive35D
Same issue here in my '09 X5 (51,400 miles). CEL light came on two days after a factory scan. They ran multiple tests and got the DEF tank sensor to trip several times. Current quote is Parts $722/Labor $660. X5 is 1,400 miles out of warranty. SA is going to request BMW fix this in good faith. I was told if BMW covers entire cost, parts & labor will not be warranteed. Yes, no warranty (what a crock). However, if I cover 10% ($130), parts & labor would be covered for two years and unlimited mileage. That decision is a no brainer. My only concern is the fact that some members have experienced this issue repeatedly. Should I be concerned?
-Chris D.
Old 04-04-2014, 10:22 AM
ard ard is offline
Resident Curmudgeon
Originally Posted by MudyOvl View Post
. I was told if BMW covers entire cost, parts & labor will not be warranteed. Yes, no warranty (what a crock). However, if I cover 10% ($130), parts & labor would be covered for two years and unlimited mileage. That decision is a no brainer. My only concern is the fact that some members have experiencedD.
Hmmm
Methinks there is a warranty either way, but if the SA convinces you to pay $130 he gets n extra $130 for the dealership.
In the back office, where warranty claims are handled, BMWNA will NEVER see the paperwork that shows 90% them and 10% you....if BMW covers it, BMWNA give the dealer $xxx. Whaever else the dealer scams is their business.
My two cents...dont take my word for it.
Old 04-04-2014, 08:17 AM
blue dragon blue dragon is offline
Mein Auto: X5 35D
Thank you for adding to the knowledge base, and posting the codes. I know I tend to search for codes
'09 X5 35D - Work horse
'17 X1 MSport - Wife
'17 340i MSport (ordered) - Soon to be daily
Old 08-14-2015, 04:16 PM
vetaldj vetaldj is offline
Mein Auto: 2015 VW eGolf
Damn me, I brake my own rule to never say that my car is problem free and here you go.
I have CEL as well and after reading I have 4D32 and 46F9 codes. After some googling found this (go to FAULT SYMPTOMS tab. It looks like SCR container with all that stuff is faulty.
Have apt for tomorrow. Will post updates. My car is CPO and also, it happen to be that I have 69300 miles and by living in CA my car should be subject to CA Extended Emission warranty 8 years or 70K miles (I hope so). In any case I will find this out soon.
Commuter: 2015 VW eGolf SEL Pacific Blue, 20K
Pleasure: 2016 X1 xDrive Tech/Driver Assist/Cold Weather, 6k
Pleasure: 2010 X5 35d Monaco Blue/Saddle Brown with Premium/Technology/Sport/Climat, 80K
SOLD - 2003 525i Green M Susp/M St Wheel, 202K
SOLD - 1997 528i Silver, 116.5K
BMWCCA Member # 447308
Old 08-14-2015, 07:16 PM
ard ard is offline
Resident Curmudgeon
Make a point to print that part of the CA warranty. As I recall the tank is inthe list.
Believe it or not, service advisors have told clients, when they say "isnt there a CA warranty" that "that is between you and the State"
Old 08-16-2015, 11:24 PM
Well, needless to say that problem was active tank, part ordered, all covered under warranty, either CPO or emission, don't know yet.
Old 09-16-2015, 08:57 AM
stockmanski stockmanski is offline
Mein Auto: X5 3.5 D
Hi everyone,
It seems like this DEF / SCR tank is an ongoing issue in the diesels.
I have a '10 X5 35D and had the initial EGR recall completed about a year ago as per below:
The emissions recall actually has three items in it:
1) Possible EGR valve replacement
2) ECU reprogram
3) Possible replacement of SCR mixer (injector)
I have the Extended 5 year certified warranty on the truck and it expires in January 2016. For the last few months I have had an intermittent SES light on with the code: SCR System Efficiency 4D16
I took the car in for service and the dealer is saying that I need a new SCR tank. ($1500 for the part alone). I mentioned to them that I had the initial recall done listed above and that I'm still under warranty. They told me this part is not covered in the certified 5 year warranty. This is a crock of Shi* in my opinion as this is a critical part of the Engine mechanics for the diesels and should be covered in the extended warranty...no? Any suggestions here? And if not covered, why would i even consider getting an extended warranty option after mine expires? This would leave me paying for the Extended warranty that doesn't include the expensive parts of the Urea system. So frustrated.
I have been driving with the SES light coming and going, and the dealer said that there is Urea in the tank, so that it is a faulty sensor. Does anyone know if they can just replace the sensor and not the whole tank? Seems excessive....
Any advice on if I should go through with the repair> If it's just a sensor, and the system is still 'working', should I just run with it?
Is there an angle I can take with BMW dealer (or with escalation, Corporate)?
I live in Toronto Canada and scratching my head on how this major engine part is not covered under warranty?!?!
Any advice or direction is appreciated.
Old 09-16-2015, 09:52 AM
ninja_zx11 ninja_zx11 is offline
Mein Auto: 2009 X5 35D
If you can DIY then i think there is a cheaper option for $499 with a life time warranty and they are in Toronto.
here is the link:
http://xemodex.ca/ca/product/scr-con...eturn-for-bmw/
Old 09-16-2015, 04:13 PM
serge1's Avatar
serge1 serge1 is offline
Mein Auto: 2011 BMW X5 35D
Good. Wouldn't not having to pay $50 deductible be better? Push for Emissions warranty, get a loaner from them and go have dinner on that $50.
Old 09-16-2015, 01:48 PM
smyles smyles is offline
Mein Auto: X5
Isn't this code related more to the metering valve?
And what tank do they want to replace, active or passive? I'd fill that one up to the max with DEF to see if it clears CEL (and yes, I know BMW warns against filling to the max, but no one has died from it, so chill)
Old 09-16-2015, 01:59 PM
Mein Auto: X5 3.5 D
They did fill the DEF to the max, as I do it myself anyhow. There was no issues before.
I spoke with the service staff and they are sending me a copy of the report and I will post it. They said I would need to change the SCR tank, so if that is active or passive, I'm not sure.
Old 09-16-2015, 03:16 PM
Doug Huffman's Avatar
Nuclear engineer
Mein Auto: 2012 Feb 11 X5 35d (E70)
Originally Posted by smyles View Post
[ ... ] L (and yes, I know BMW warns against filling to the max, but no one has died from it, so chill)
Where is this warning, please?
