Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E30 M3 (1986-1990)
E30 M3 (1986-1990)
Old 09-19-2011, 09:36 PM
jadeasker jadeasker is offline
Mein Auto: 1990 325i E30
Cruise Control Fix
Hey ya'll. I recently joined the E30 fan group by buying a '90 325i. I love these cars. I need some advice about how to fix the cruise control. Mine simply does not work at all. Any suggestions on how to go about fixing the problem? Should I get a new CC module first? Any experience that you would be willing to share?
I appreciate your help!
Old 11-08-2011, 09:19 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
If you are going to DIY, I'd look at the cable drive in the under hood unit, and see if the belt is broken.
m
Old 12-10-2011, 05:25 PM
t_lydon t_lydon is offline
Mein Auto: E30 M3; 525iT
G'Day,
Also check the switch on the clutch pedal . If it is not open, then the cruise thinks that the clutch is depressed and it holds the cruise control off . Usually, it is a slightly tweaked bracket that holds the switch in position to contact the clutch pedal arm .
>>Tim
