Old 09-21-2011, 01:05 AM
DinanBimmer's Avatar
DinanBimmer DinanBimmer is offline
Mein Auto: 1998 540i 6-speed/2003 M5
Show me some pics of your e39 with wheel spacers, trying to decide what size to get.
Hey guys, just trying to decide what the most practical size would be for wheel spacers. Let me know what you've got and share some pics to make this thread more interesting. Thanks
Supersprint X-pipe attached to Dinan Free Flow Exhaust, m tri-color black kidney grills, 20% tinting on back windows, LED Angel Eyes, HID Fogs, and much more to come.
Old 09-21-2011, 08:27 AM
demas demas is offline
Mein Auto: F10 550i M-Sport
12mm H&R spacers up front with 18" Style 32's. Nothing in back. OEM M-Sport II drop.
Here are some close-up's on the front.
With spacers:
Without:
Old 09-21-2011, 10:01 AM
fabby318is fabby318is is offline
Mein Auto: 97' 528i & 91'318is
Very nice! Loving the apline white.
Old 09-21-2011, 11:07 AM
With spacers:
Without:
Why only spacers in the front? Does that make the front wheels even with the back or just personal preference? Car looks great by the way.
Old 09-23-2011, 04:56 AM
thanks. Just did the fronts (for now) to get rid of the 'sunken in' look. With the OEM wheel offsets, the fronts are almost even with the rears. 15mm spacers would have been almost exact (within 1mm) but for balance, my tuning shop recommended the 12mm.
I'm considering one day to move the 12mm in the rear and go wider up front - but it will be a tight squeeze in my mechanical elevated parking space, especially with the negative camber in the rear.
Old 09-21-2011, 10:57 AM
DennisCooper!'s Avatar
DennisCooper! DennisCooper! is offline
Mein Auto: 03 Ex Cop 530d Touring
Hi,
there is no one size recommendation. You can get spacers in 2,5, 10, 12, 15, 20, 25, 30, 35, 40, 50 mm sizing and every size in between if you get custom ones made. You need to assess what wheels you are running and their current offsets for a start, then decide how much further out you want them to be and take into consideration if you are lowered and by how much. You also need to look at the shape of your tyre shoulder, some are more square and others more rounded.
If you are looking to go lower and want to space/stance the wheels out, do your research and evaluate from there!
Cheers, Dennis!
Old 09-21-2011, 11:08 AM
Originally Posted by DennisCooper! View Post
Hi,
Cheers, Dennis!
Thanks, I'll take this into account before I decide which size.
Old 09-21-2011, 01:31 PM
SilverE39's Avatar
SilverE39 SilverE39 is offline
Mein Auto: '01 530i S/P 5sp
15mm on all corners. You probably can get away with 20mm up front and 10mm in the rear. I had to get my rear fenders roll slightly with 15mm.
18x9 Style 42 Rear
18x9 Style 42 Front
17x8 Style 42 Rear
17x8 Style 42 Front
OEM M5 F Bumper | EuroDyne R Bumper | Magnaflow Exhaust Manifold and Full Cat-Back Exhaust | Koni+H&R Sport | CDV Deleted | Eibach f/r sway bars
Hard-wired V1 Radar | E60 shifter w/ZHP shift knob | 18x9 Style 42 | Continental DW 255/40 | Zimmermann XDrilled F/R w/Akebono Euro Pads
35% Madico tint | Infinity Basslink | E0n0n D5201Z Navi | Thule Bike Rack
Old 09-21-2011, 02:01 PM
Looks good, i'm definitely trying to avoid rolling the fenders. How much would that cost btw?
Old 09-21-2011, 02:09 PM
SilverE39's Avatar
Dinan,
I think it was about $15-$20 per fender. If you're using your OEM rims, then 15mm all around with no problems.
Old 09-21-2011, 03:46 PM
Originally Posted by SilverE39 View Post
Dinan,
Good idea, I think that's what I'll end up doing.
Old 09-23-2011, 12:46 PM
I wonder if 15mm all around would effect handling.
Old 11-14-2012, 07:41 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
anytime you move the wheel inboard or outboard, you are changing the "SCRUB RADIUS" aspect of the suspension. Scrub radius applies mainly to the front suspension b/c this is a steering issue. When this radius is changed, the fulcrum pivot point on which the tire turns is changed, which changes the behavior of steering EFFORT, braking sensitivity, and overall "FEEL" from the steering wheel inputs.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 11-14-2012, 09:41 AM
Cool, thanks for the info! So would you say that spacers have a positive or negative effect?
Old 11-12-2012, 11:49 PM
More than a year since my last post about this, but I FINALLY bought a set of 15mm spacers off ebay:http://www.ebay.com/itm/4-pcs-15mm-H...ht_1540wt_1270
They're just standard aluminum ones. I confirmed with Albo on their quality and he says they've held up well on his car. I'll be sure to post pics when I fit them next week.
Old 11-13-2012, 12:13 AM
Albo's Avatar
Albo Albo is offline
Der Ursprüngliche....Albo
Mein Auto: OO=[][]=OO
Did you get some extended bolts as well?
2003 530i (Alpine White/Sand Beige) - 18x8.5 & 18x9.5 ACS Type II Wheels - BC Racing Coilovers - Eibach Sway Bars - Beastpower Sway Bar Brackets - M-Technic Replica Bumpers - Slimmbones CSL-Style Spltters - Magnaflow Muffler - Dinan CAI - TopSpeed Performance Strut Brace - Carbon Fiber Valve Cover Fascias - Zionsville Autosport Radiator/Fan Kit - Revmax Stage II Torque Converter - AMG Paddle Shifters
Old 11-13-2012, 10:35 AM
I did, 43 mm and they're 10.9 rated.
Old 11-13-2012, 12:43 AM
fullthrottle540's Avatar
fullthrottle540 fullthrottle540 is offline
DINAN 5
Mein Auto: E39
here's one that had H&R wheel spacers...and tried to drive fast on 'em. Ricer mistake.
Old 11-13-2012, 02:08 AM
SilverE39's Avatar
WTF does spacers have to do with driving fast and ricer mistake?
Please explain......
Old 11-13-2012, 10:00 AM
DINAN 5
Mein Auto: E39
It's only ricers who decide that they don't like the way their wheels "look" (first of all, you should have bought the correct offset of wheel) so they sandwich some metal plates between the wheel and the hub, and purchase extended lugs so that they can secure the metal plates.
This is a dangerous ricer practice. I work the tech inspection at my local track and I would not allow any ricer with wheel spacers to risk anybodies life just because they wanted their wheels to "poke out a little more." If you have spacers then you belong with the lowrider club that hangs out at the beach & takes HD photos of cars, NOT with actual racers who USE their cars.
Old 11-13-2012, 02:08 PM
1BADBM's Avatar
1BADBM 1BADBM is offline
Mein Auto: 530i
I doubt the majority of people here are racing their cars on the street or track. How many of us here are "actual racers"? Relax.
Old 11-13-2012, 05:35 AM
AntsE39 AntsE39 is offline
Mein Auto: E39 528iA
+1 please explain
Anthony
Old 11-13-2012, 02:12 PM
Just what I was going to say. My car won't be seeing the track for a while, if ever. Plus my style 19's have no offset so they require spacers to fill the arches. I don't think it's common for spacers to cause you to crash, unless you're driving extremely hard around turns.
Old 11-13-2012, 03:00 PM
SilverE39's Avatar
Fullthrottle,
Your answer doesn't support anything. I have OEM wheels, yet when lowered, I have too much of a gap still so I use spacers. Spacers give your ride a wider stance. I do agree that the Euro poke looks stupid as hell.
So what if you work for tech inspection? You can't discriminate cars w/or w/o spacers. There's no law against running spacers, unless your lugs are too short/long to affix wheel to hub. Quit stereotyping and using ricer. I use spacers, am I a ricer?
I've been autocrossing for 3 years with spacers and have no problems. Spacers have nothing to do with crashes.
Old 11-14-2012, 12:54 PM
champaign777's Avatar
Looks like he wanted to eliminate gaps as more as possible
Just look on his real wheel , i see no gap at all
People when lower/add spacers think how your car will drive
Dont be stupid , the look is never != drive
Hope someone will take a lesson from this SAD story ...
