1992 E36 325i - Rough idle at all times. Hesitates when cold. - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-27-2011, 12:25 AM
puttitat puttitat is offline
Mein Auto: E91 330d
Hi,
I've got an issue with erratic idle on my E36 325i Coupé Non-VANOS.
It's not really the classic 400-1000 rpm surge, it's just erratic, sounds as if cams are swapped.
Tried disconnecting O2 sensor. No go.
Tried disconnecting TPS sensor. No go.
Tried disconnecting water temperature sensor (blue). No go.
Tried disconnecting MAF. No go.
Tried disconnecting IAT sensor. No go.
Tried another ECU. No go.
Tried another MAF. No go.
Fitted new rubber boot. No go.
Haven't checked the ICV as it's not surging as much as just being erratic.
It idles poorly at all times, when cold it surges a bit from 7-800 rpm in "jumps", and the engine hesitates while driving. Seems "nervous" in its running. After approx. 4 miles, the hesitation disappears as fog to the sun (litterally from one second to another!), and all is well - except for the rough idle as told above.
If I start the engine when it's hot, and drive, the hesitation is not present. It's only when driving for the first few miles after a cold start in the morning.
SOLVED!!!!!! CPS was the culprit.
Old 09-27-2011, 04:31 AM
granlund granlund is offline
Mein Auto: -02 530 & -92 325is
Try checking the color of the spark plugs if the engine is running lean or rich. Pictures would be good.
Do you have any cam chain noise? I wonder if the upper tensioner (between the intake- and exhaust cams) might cause this?
Old 09-27-2011, 05:45 AM
Mein Auto: E91 330d
They are very light brown. A bit lighter than a fresh-from-tab 10w/60. Uhmmm :-)
Old 09-27-2011, 05:50 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
How long has it been since you changed the plugs and coils? It may just need a good tune up.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-27-2011, 06:15 AM
Mein Auto: E91 330d
Steve
Coils have done 50000 miles, plugs was changed today.
Old 09-27-2011, 06:35 AM
50,000 miles ago (80,000 km), did you replace the coil rubber boots too?
Old 09-27-2011, 06:39 AM
Mein Auto: E91 330d
Yeah, it was 6 brand new BOSCH complete with boots. Ground connections from valve cover to coils are also intact.
New CPS will arrive later today.
Old 09-27-2011, 07:03 AM
BMR_LVR's Avatar
Humble E34 lover
Good luck. I don't think that the problem is the CPS, but it would not hurt to have a new one as they can crap out on you at the worst of times.
Let us know if you find a solution to the problem.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-27-2011, 07:23 AM
Mein Auto: E91 330d
CPS was the culprit. New CPS and voila :-)
Old 09-27-2011, 07:36 AM
BMR_LVR's Avatar
Humble E34 lover
Congrats. I was under the impression that a bad CPS basically caused the car to just not run at all. I learn something new everyday. Thanks for sharing the solution.
Steve
BTW, would you be kind enough to check the resistance on the failed CPS? I would be curious to know what the reading was. If it is in the normal range (540 ohms +/- 10%), then that makes the resistance check rather unreliable for establising the health of the CPS.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-27-2011, 12:23 PM
Mein Auto: E91 330d
Steve
Just for the fun of it I tried firing up without CPS connected. Ran fine.
The resistance is 728 ohms. Not that my measuring device is the most accurate in the world, but it draws a picture, that the resistance is too high.
Old 09-27-2011, 02:54 PM
BMR_LVR's Avatar
Humble E34 lover
Umm ...... the car cannot run if the CPS (crankshaft position sensor) is not connected ... unless I am just totally off my rocker
Not sure what you disconnected, but I would track it down to figure it out.
Gald you got it running though.
Steve
Edit: Are you referring to the camshaft position sensor? The car will crank and idle fine if it is disconnected, but it doesn't do well going down the road from what I understand.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-27-2011, 06:35 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
cpk, ckp= crank position sensor, cmp/cmps=camshaft in tech acronym jargon.
i get confuseded sometimes myself, so i look for the 'm' or 'k'. cam will be designated by the 'm', the crank by the 'k'.
and no, the car will not start without the crank signal. it will run poorly, though, if one if out of spec.
the cam position sensor is just for a synch signal to identify the #1 cylinder.
thanks for the update on this though. it'll help wihen others may be searching for answers to similar issues.
df
Old 09-27-2011, 11:01 PM
Mein Auto: E91 330d
Hah, yea, i was referring to the camshaft position sensor. My bad. Dunno if it shows from my profile, but english isn't exactly my native...
The car ran smooth without the cam sensor, no hickups or the like. It's fascinating how the M50 can run without most of the sensors, they're all there for fine tuning Congratulationswelldone BMW
Old 04-18-2015, 12:48 PM
max.merritt max.merritt is offline
Mein Auto: E36
Where did you buy the non vanos camshaft position sensor?
most places only sell for 1992+, my e36 is built in 1991/10
Old 07-22-2015, 08:27 PM
digitranz47 digitranz47 is offline
Mein Auto: 1992 e36
I have the same problem with my 1992 325i....Where is the crankshaft positioning sensor located
325i, e36, hesitate, idle, sensor
