E28 (1982 - 1988)
Blue Smoke when cold
I've got a 1983 bmw 533i that I just bought for $1,400. The car is in good condition but when I start it cold I get some blue smoke. I talked to a mechanic at my school and he says it probably has something to do with the valves. Can someone please tell me what it needs and what the cost of the fix will be? Thanks
Black on Black 540i |
Also, If i pull out the dipstick when its running the idle drops down a bit, then when I put it back in the idle raises again. Is that related to the valves?
The smoke means you need a head rebuild or another head because your seals are going and it is burning oil. As to the dip stick, you are loosing vacuum when you take it out, so it should run badly. Sorry to have to say that. How many miles?
Andy |
like 165k or something. The car reads 273k except the engine was replaced recently with one that has 160 and it was barley driven after that. Damn, I might have to buy your extra head off of you. I'm gonna get a few more people to check it out to make sure it was the head then ill get back to you. also, let me know when my package ships!
Ya get the head checked it should not be blowing blue smoke with only that amount of miles on it. Are you sure about the amount of miles that were on the engine? These engines should be good for at least 300,000 miles.
Andy |
I gotta get this fixed though!
Probably means that you have worn or hardened valve guide seals. The only problem is that doing it requires head disassembly and or that you will need the Bentley repair manual.
Jimmy Moreno 1995 530i 1986 535i |
| Tags |
| 533i, blue smoke, e28, thermostat, water pump |
