WHERE does the CCV vacuum source port go for the E39 CCV valves that are not plugged?
EDIT:
I'm curious WHERE the vacuum hose goes for the E39 CCV valves that do NOT have their CCV vacuum port plugged. My theory (which is just a guess) is that this plugged port #9 on the back of my 2002 M54 engine is where the CCV vacuum hose 'would' have gone had it been in place. - Engine => Vacuum control => AIR PUMP F VACUUM CONTROL That plugged port is also shown as #17 in this diagram: Engine => Intake manifold => Intake manifold system Do you think this plugged port is what WOULD have been connected to the CCV if the CCV port wasn't also plugged? NOTE: There is a typo in the caption; it should be "BTW, note the cracked condition of that endcap" (since replaced as explained here): - How to locate all the vacuum hoses in the E39 engine bay NOTE: We found the part number & size for the endcap over here: - M54 vacuum hoses ... what diameter ... what brand ... what material ... what length? NOTE: See also a thread which asks what the vacuum port on the CCV actually does: - CCV vacuum hose important? Last edited by bluebee; 11-08-2011 at 06:06 PM. Reason: Changed title from: Am I blowing smoke with this new CCV vacuum hose manifold port endcap theory? |
I see what you did there.
I have no clue as to the answer but why does this matter?
Snipe hunt.
suscribed
I am curious about this as well.
My M52TU uses this, but not my M54. M54 has more CCV issues and mayo. I worry about hydro-locking the M54 every winter. I recall a post where someone applied intake vac to this port on CCV of M54 and achieved less oil consumption, which I experience on M54 and NOT with the M52. Curious if it would run cleaner in winter, but am afraid to mess something else up with balance of M54 harmony. I will try to research this after work. |
why does it matter?
if youre worried about crankcase valve issues in the cold, just change your oil more often and make sure you drive your car a little harder. you merely need to get the oil to a temp in which the water naturally will vaporize. |
It matters to me
Daily commute for M54 is 30 minutes each way mainly hwy speeds. Oil is changed every 6k with M1 0w-40. I'm not from the "short drive cycle" / "high OCI" sample. |
The more we learn what BMW was thinking when they designed the M54 engine, the better we understand our engines.
Perhaps, if we understand what port BMW originally intended to deliver vacuum to the CCV, and if we then apply that vacuum via that port, 'something' useful may result from the experiment. Last edited by bluebee; 10-30-2011 at 04:53 AM. |
(But that's just my opinion) *I know Poolman modified his CCV but he has demonstrated a high degree of mechnical competence and has been a pioneer in other areas (Vanos) so he is somewhat of an anomoly. |
Perhaps your image of this forum is correct, but it is surely unwise to promote a "don't bother to think about why" attitude here and leave intelligent minds with poor initial impressions of this forum. Note my thread count. |
You need to reread my thread. I am not promoting a "don't bother to think about it" attitude. My concern is what BB is suggesting when she says "Maybe we'll find a way to hook it back up to the CCV". What I am saying is don't even consider a radical modification of your CCV
The Vanos seals is a great example of a major problem applicable to all M54s, M52s, etc. that has been modified by the aftermarket. Beisan Systems diagnosed the problem, reported it to BMW (who ignored them) so they redesigned the seals and wrote up a detailed DIY to replace them. Even with the glowing remarks from people who did this job (Poolman), it still took me awhile to muster up the willingness to open up my engine to do this. If you do anything to your car, do this, for the performance improvement. WRT to the CCV specifically, there is no aftermarket solution other than the insulated hoses. Consider the scope and magnitude of the CCV problem before you consider any corrective action you may regret. First, do a search to determine how many hydrolocked engines have occurred due to CCV issues. It is not many (more common on the X5). Second, a failing CCV is rarely an immediate catastrophic event, unlike a cooling system or DISA valve failure . A failing CCV system typically begins with increased oil consumption and a smokey exhaust. Can it fail catastrophically? Yes as in Doru's case. But it can be corrected by simply (actually a PITA) replacing the CCV and hoses. Modifying your driving habits can help to reduce the likelihood of a problem. All in all, the CCV is flawed system but not what I would consider a major deficiency in the M54 design. I personally feel this is the best designed engine I have ever owned. My advice is simply this: "A (wo)man's got to know his limitations". Learning more about something is one thing. Doing something about it is an entirely different matter. Just one guys opinion.
The vacuum port on the CCV valve went to the fuel pressure regulator on the M52 engines--the M54 engine the port is capped off-----on the M54 engines the fuel pre--reg derives vaccum from the small vac hose that goes into the air intake duct--right after the maff--along side of the vac hoes for the jet suck pump
I am 'not' attacking your assumption by asking the clarifying questions below ... but if that statement above is true, everything I 'thought' about the CCV vacuum source is wrong. So ... I 'must' ask ... If the hose on the M52 goes from the CCV to the fuel pressure regulator, would I be correct in assuming the DIRECTION of air flow MUST be FROM the fuel pressure regulator TO the CCV? If so, having the CCV be the 'source' of vacuum is directly the opposite of the user-annotated (mostly by cn90 and me, IIRC) diagrams sprinkled all over the place. For example, look at the pictures & diagrams here: - How to test the crankcase ventilation (aka CCV, CVV, PCV, CPV, & OSV) pressure regulating valve system (1) Both the picture above (from cn90) and the diagram below (annotated by me), assume the CCV vacuum port is connected to a 'vacuum source'. So, to move forward, we have to clarify how the M52 worked before we can begin to understand the M54. QUESTION: Q: In the M52 engine, what is the DIRECTION of air molecules in that vacuum hose? Said in other words: Q: In the M52 engine, which end of the hose is the vacuum source (i.e., the CCV or the fuel pressure regulator)? Last edited by bluebee; 10-28-2011 at 09:51 PM. |
That was a wonderful explanation! (As was the previous one about the 'blanking cap' over in your Bimmerforums.co.uk reference.)
To ensure value added, I will add both explanations to the annotated pictures in order to further leverage those revelations to other CCV-related threads (& get the word out). The most interesting comment was this one: Quote:
Besides making all the diagrams wrong in an instant, it also instantly negates the 'need' to find the 'missing' vacuum port on the M54! Believe it or not, a key question might be the shape of your F connector! You may wonder why I ask that ... and I'll explain in due time ... but first, may I ask if the F connector on vacuum-equipped CCVs is actually L shaped as shown in the diagrams in this recent thread? - Correcting the F-connector errors in the realoem diagrams (1) Quote:
Apparently on the S62, this CCV-derived vacuum port does not exist. On the M54, it seems degradation of this endcap can indeed be a source of vacuum leaks. In fact, there is a simultaneous quest to find & replace the two, three, or maybe even four endcaps over here: - What are the vacuum endcaps in the E39 engine (1) Quote:
REFERENCE: M54 engines - guide to finding vacuum leaks REFERENCE: Steve530 in this thread REFERENCE: Detailed DIY for Crankcase Ventilation Valve Overhaul for the M52TU Motor Last edited by bluebee; 10-29-2011 at 12:38 PM. |
I don't know anything about the M52 engine vacuum routing, but I may be able to answer you question.
I still have the CCV I removed a few weeks ago. I took it apart, so I think I can explain how it works. The bottom cone shaped part is a cyclonic separator. If you look at the entrance of the vent tube, you'll see that it enters the cone at a tangent. The blow-by gasses and oil hit the sides of the cone forming a vortex. The oil droplets are thrown against the side of the cone and fall into the tube that drains to the dipstick. The gasses are forced through the center of the vortex up through the "L" shaped tube that connects to the upper part of the CCV. The connecting line that connects the upper part of the CCV to the manifold supplies a vacuum. The upper part has a diaphragm and spring. When there is a high vacuum at idle, the diaphragm moves to close off the connecting line. When the vacuum drops at high engine speed, the spring pushes the diaphragm back allowing the gases in the cyclonic separator to flow into the manifold. I think this is typical design for a PCV system because it allows blowby gases in the manifold at high engine speed and blocks the blowby gases at idle. The "L" shaped tube has the nipple. When the diaphragm in the upper part is open, the nipple will have the same vacuum as the manifold. When the diaphragm closes, the "L" shaped tube is closed off from the manifold vacuum, so the nipple will be at the same vacuum as the crankcase. So it seems likely that the nipple was indeed a vacuum source for a fuel pressure regulator. At high engine speed, a vacuum would be applied to the FPR to increase fuel flow. At idle, the high manifold pressure the closes CCV diaphragm and no vacuum would be applied to the FPR through the line connected to the nipple. If you connect that nipple to the manifold, it will pull blowby gases into the manifold at idle. Because the engine speed is low, that may not be a good idea. .
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
I have an additional comment on the above quote from Steve530's post and that is that the vacuum for the FPF on the M52 motor and all other FPRs that I am familiar with works in exactly the opposite way that Steve530 describes. When the engine is at idle (& at deceleration) it produces the greatest vacuum. This vacuum applied to the FPR reduces the fuel pressure at idle-less fuel is needed at idle. I know this for sure because when I installed a supercharger kit on my 2000 528iT (M52TU), I kept getting 1088 & 1089 fuel control fault codes-the short term fuel trim was in the -24 to -27 range on both banks when the engine was at idle. The instructions from the SC company had me disconnect the L shaped connector from the CVV and route it to the intake tube of the SC, sealing off the connection for that tube at the intake manifold. This removed the vacuum source from the CVV and hence from the FPR. I finally connected the vacuum hose from the FPR to an unused 3.5mm vacuum nipple on the back of the intake manifold-the STFT values went to -2 to -3.5 (normal) and no more fuel control fault codes. So the vacuum reduced the fuel pressure at idle. Also when the throttle is opened the vacuum is decreased & fuel pressure is increased when engine power needs to be increased. BTW your vacuum port #9 above with the cracked cap is connected, in my car, to a vacuum line that supplies vacuum to the brake booster. Also the FPR in the M52 (single Vanos) is located on the fuel rail. On the M52TU it is relocated under the car, just in front of the fuel filter, under the driver's seat. On the M54 the FPR is integrated into the fuel filter located under the car, under the driver's seat. Last edited by johnstern; 01-20-2012 at 09:04 PM. |
From what I can gather from this issue is that M54 engines with end caps need those end caps replaced to prevent vacuum leaks.
Blue Bee--told ya before--don't second guess me --when I had problems with oil usage--one of the things I to make the fix with was--I ran a vac line from the ccv port we are referring to and then hooked the other side to one of the ports at the back of the intake manifold. This helped some, but not enough. I ended up with my oil catch can and putting the complete crankcase in a controled vacuum utlizing a common PVC valve from a big block Ford--Ford products work well everywhere
We are thinking the same thing but you got the jump on me, by, oh, I don't know, a few years probably! As soon as I saw an empty unguarded undefended port, my mind wanted to make good use of that otherwise-wasted vacuum source for my purposes quicker than Nancy Pelosi could wrap her hands on a new source of revenue to be squeezed out of the hard-working people! The thread you're referring to is probably one of these, which I will read:
Assumption: Since we now know that the ccv vacuum port was intended to be a 'source' of vacuum for the fuel pressure regulator ... (i.e., the movement of molecules was intended to be INTO the CCV valve)... Question: What is the logic of benefits from reversing the flow from that of the initial design? Note: I'll first read for the answer in the threads ... but that's the first question I have since I now realize the CCV was never designed to be attached to a vacuum source at that nipple in the middle of the CCV. |
This stuff makes my head hurt, and my hands ache. I remember connecting those nipples and hoses, and the thought of ADDING one makes me want to run away.
Interesting ideas. |
The confusion arises because the BMW schematics seem to be as badly written as a cellphone law by Joe Simitian!
I think we wouldn't have half this confusion if the realoem diagrams were closer to correct. To that end, I asked M52 owners to confirm the latest hypothesis to fall out of this thread: - E39 M52 owners: Please check your realoem diagrams against your vehicle & help us out Quote:
An interesting observation occurred today while discussing the M62TU SJP:
- How does the BMW E39 sucking jet pump (aka suction jet pump) work & how does it fail? Apparently, with respect to the CCV vacuum port:
For the record, this related post was made today over here:
- M54 vacuum tubing ... what diameter ... what brand ... what material ... what length? Quote:
| Tags |
| ccv, ccv vacuum hose, manifold vacuum, misfire, vacuum leaks |
