Old 10-31-2011, 10:12 AM
cgstelle cgstelle is offline
Mein Auto: 2001 740il
01 740iL - Headliner question
Hello everyone...For anyone out there who has ever taken down and reinstalled their head liner (or someone else) for what-ever reason, how long did it take or how long should it take if you know what you're doing? I need my sun roof cassette/cartridge replaced and am getting various responses from local body/auto shops. Appreciate all responses....
Old 10-31-2011, 05:18 PM
exred92 exred92 is offline
Mein Auto: 2001 740i sport
It takes about 2.5-3.0 hours to take cassette out. Need to remove A,B and C pillars,both front sunvisors,four handles that on headliner,disconnect interior alarm sensor,drop the headliner, disconnect all four drain tubes, disconnect sunroof motor and unbolt cassette from the roof. Headliner and cassette both comes out from left rear door.
Good luck.
P.S. Sunroof glass lid needs to be removed first.
Old 11-08-2011, 04:42 AM
wattbmw wattbmw is offline
Watt
Mein Auto: Black, 2000, 740i
On this same thought. The material is falling away from the roof of my car. I believe air has gotten in the liner. Is the process explained the same way to tighten up my liner?
Old 11-08-2011, 04:53 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
If it got loose the easiest way is to replace it. There are some special clips @ Oreily's that will hold it in place
JOY = BMW
Old 11-13-2011, 11:11 AM
Prevost Prevost is offline
Mein Auto: 1998 BMW 750il
I replaced the entire cloth piece on my headliner. 3m makes glue that works extremely well. It comes in a spray can and usually costs around $10-$15
Old 11-13-2011, 11:26 AM
Watt
How did you do the replacement?
Old 11-13-2011, 12:58 PM
Remove the entire headliner from the car, remove the healiner cloth from the actual headliner its self. The headliner is actually just a shaped board. After that scrape off the old glue so the cloth can actually adhere to board, not the glue on the board.Then pick some fabric to use, I'd go with something relatively thin, its lighter and more flexible. Cut out the cloth in the shape of the board, then use the 3m heavy duty glue to glue it to the board. I usually spray both the cloth and the board with the glue to get a better hold, but follow the instructions on the can. The whole job can be done in a day easily. I suggest practicing on a couple before diving right in just to make sure you can get the curves right. I'm doing the one on my 750 soon, I can post up a guide with pictures when I do if you'd like.
Old 11-13-2011, 02:24 PM
Watt
I would really appreciate the lesson. My roof appears to be falling on top and makes the ride look bad. Thanks
Old 11-18-2011, 12:01 PM
samsly samsly is offline
Mein Auto: 01 E38 740i
I paid 300 bux to have the Headliner and the sides replaced, the guy did a GREAT job... (WattBMW) since I see you are in the Tampabay Area I can send you the guys name and number if you want it done professionally. My next steps are the seats, sticking with leather
Old 11-19-2011, 07:31 AM
joyism5's Avatar
Headliner removal http://www.bimmerboard.com/forums/posts/566588
http://www.bimmerboard.com/forums/posts/418973
http://www.wlsheadliners.com/tutorials/bmw/
JOY = BMW
Old 07-22-2012, 06:54 PM
Watt
Samsly, sorry it has been close to a year for reply. I would love the number for the person who can repair my lining.
HTML code is Off
