Old 11-01-2011, 11:58 AM
Superhart1977's Avatar
Superhart1977 Superhart1977 is offline
Send a message via AIM to Superhart1977
Mein Auto: 2011 328 XDrive
Coolant leak
Well, I checked both forums and couldn't find this specific leak so I am hoping you all can help me out.
The other day I was at work and walked past my car and noticed a puddle under the engine more to the passenger side front. I moved my car and checked later that day and sure enough another little puddle. It felt slimy like mineral oil so I new it was coolant. I jacked car up and dropped the plastic cover exposing the bottom of the engine compartment. I found the leak!! It is a thick hose connecting to the bottom of the radiator. On the passenger side. Anyone ever fix one or how to fix this. Parts, instructions ect....
I took a picture of the leak. Thanks everyone
Also. Is that red valve a way to drain the coolant out so I can replace
ID:	299390   Click image for larger version
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-01-2011, 03:21 PM
TxTaz's Avatar
TxTaz TxTaz is offline
Mein Auto: 2010 650i Coupe
Are you talking about part #3 on this diagram?
That's the lower radiator hose for $36.
Taz...
2010 E63 Black sapphire metallic
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
Old 11-27-2012, 03:49 PM
trekwars2000 trekwars2000 is offline
Mein Auto: '06 750Li and '08 FEH
How are you guys getting to the temp sensor? Is any jacking of the car up needed? I am being told by the stealer that my lower rad hose is leaking and needs replaced on my 06 750Li. From everything I read on here I am going to assume only the o-ring on the sensor needs replaced and try that first.
Also, this would be on the bottom left side of the radiator when looking at the car from the front of it?
Thanks in advance.
My Garage:
2011-Current 2006 750Li
2008-Current 2008 Ford Escape Hybrid
Retired:
2006-2011 2006 325i
Old 11-27-2012, 06:29 PM
3Pedals_6Speeds 3Pedals_6Speeds is offline
Mein Auto: fun cars
Thanks in advance.
I got at it from above. Doesn't seem like you can, but it will work.
Drive fast, take chances.
Old 11-02-2011, 05:23 AM
Txtaz. The diagram isn't coming up. Can you send again. Btw. It is the lower hose, is it easy to fix and can I drain the coolant out of the red valve that is in the picture? Thanks again
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-02-2011, 08:57 AM
TxTaz's Avatar
You can search for the diagram on http://getbmwparts.com/
I haven't drained the radiator before on my car so someone else will need to chime in here.
When I have done radiators in the past, I've always cut the hose and drained it. It makes it easier to remove the hose when it's cut in half.
Taz...
Old 11-02-2011, 09:48 AM
Yorgi's Avatar
Yorgi Yorgi is offline
In the past I've drained BMW rads using a bolt on the rad or by pulling the coolant level sensor on the lower part of the rad.
Here are the TIS instructions for draining and refilling.
The engine drain bolt tightening torque is 25Nm or 18 ft-lbs.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-05-2011, 07:56 AM
As for coolant. Do I have to use oem BMW coolant or can I use a different brand from a regular auto parts store. Thanks
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-05-2011, 09:07 AM
Yorgi's Avatar
Use OEM BMW coolant, you need two jugs and mix it 50/50.
The blue BMW coolant is made by Glysantin which all the German manufactures use. It is pH balanced, nitrate free, phosphate free and has very good corrosion inhibitors. Using BMW coolant will ensure your gaskets last as long as possible (ie you don't want to case a $2,000 premature engine coolant pipe leak by using cheap coolant). Prestone and other non-phosphate free coolants can be hard on BMWs rubber gaskets.
'04 M3 - track
Old 07-08-2015, 11:06 AM
kom_andy kom_andy is offline
Mein Auto: 2012 BMW F07 5 GT
Hi Yorgi,
About coolant did you guys ever try to use Evans or RedLine Water Wetter coolant, people saying good things about them.
Also what do you think about changing thermostat from 105c to 90c, I was thinking to do this soon while I have no leaks no errors on my 650.
Thanks,
Old 07-08-2015, 11:29 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Following on from Yorgi's thread, it has been stated many times that you should stick with BMW's own coolant and personally see no reason to differ from this viewpoint.
The BMW coolant is no more expensive than anything else on the market!!
Old 11-05-2011, 01:59 PM
Just got back from stealership and paid 81.00 for the hose and antifreeze, first thing in the morning I will replace and fill. I will time myself and post difficulty after I am done. Looks to me like a 30 minute job but we will see.
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-06-2011, 07:07 AM
Hope you are all out there, it's Sunday and dealership is closed. So it was an easy fix, you can replace the lower hose from top and without jacking car up and getting underneath. Found the leak!!!! It wasn't the hose!!! But I am glad I am replacing it anyway. The leak is coming from the temp sensor. I guess the green o ring has shrunk and failed. I put back together and filled with water and ran to flush the green antifreeze that must have been done from previous owner. I noticed the dripping coming from temp sensor, I wiggled it and I am certain. The problem is, it is Sunday, BMW closed, can I get an oring from local auto store that will fit and thick enough to seal?
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-06-2011, 08:34 AM
Yorgi's Avatar
If you think you can quickly pull and replace the sensor without draining the system then it would not hurt to try changing just the o-ring.
I would try the new o-ring, refill the system and if it still leaks grab a new sensor from the dealer ($25) tomorrow and replace it without draining the system.
Here is a shot of what a new sensor looks like if you want to see how thick the o-ring should be for reference.
'04 M3 - track
Old 11-06-2011, 09:46 AM
DBLAZE's Avatar
DBLAZE DBLAZE is offline
Mein Auto: Alpine White F01 750i X
This same exact thing happened to me about three weeks ago. It is the Temp sensor and all I had to do was replace the Temp Sensor O-Ring with one from Home Depot. The E46 has the same exact temp sensor and the O-rings fail all the time. I found a DIY on the internet and the correct O-rings to purchase are the Danco #31 O-rings that come in a pack of 10.
I'll stop by later today and give you one Superhart, since you live about 3 minutes away... All you have to do to replace it is unclip the temperature sensor from the wire harness and lift it out of the top of the engine bay. Remove the old O-ring and place this one on there in its place. No leaks ever again! You should have called me yesterday before you did all of this because I would have given you the hookup!
BMW F01 Alpine White 750i xDrive; Oyster Interior
[BMS Stage 1 Tune | VRS Front Spoiler | AC Schnitzer Trunk & Roof Spoilers | AC Schnitzer Pedals/Footrest | 45% Tint]
BMW E63 Jet Black 645ci - Retired
BMW E46 Fern Green 323ci - Retired
Old 11-21-2011, 02:49 PM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
Funny i came across this , they Told me $285 bucks to swap the lower radiator hose on my 750LI .. I have just replaced the hose ($35 bucks later ) and still leaking , I Knew for sure the dumb A$$ tech i spoke with was wrong as i told him face to face it can't be the house and could very well be the sensor O ring . Thanks for the info guys .
So Home Depot has these O rings ? I need to pick one up in a bit or should i just buy the sensor from BMW Tomorrow ?
Thanks again fellas
Old 11-21-2011, 05:31 PM
Thanks again fellas
If I was you I would start with the O-Ring. If you are not getting sensor errors then probably it still is working properly, you just have a leak? Here is the O-Ring at Home Depot so nicely posted previously, off to the right you can check the local store availability.
It is only $2.27 for a pack of 10, it is the best way to start!
http://www.homedepot.com/h_d1/N-5yc1...1&ddkey=Search
Old 11-21-2011, 06:20 PM
M4XBMW7's Avatar
TTurboFest
Just finished installing the O ring and leak gone ... Just took it for a ride and bone dry .. Thanks again fellas . But I'm thinking of grabbing a sensor and keep it in the car just in case
Here's the difference ... New rings fits nice and tight . (Green OEM O ring )
Old 11-06-2011, 12:55 PM
Thanks DBLAZE for stopping bye and hooking me up with some o rings, let's hope I won't need them just yet.
Well, BMW originally said that my lower radiator hose was leaking and wanted to charge me 265.00 for complete job. After taking the hose off myself I found that the hose was fine and the leak was the o ring on the temp sensor, a measly 2 dollar rubber gasket. I will return that lower hose to dealership for my money back, after filling and topping off with bmw antifreeze I ran car and got her up to temp, bone dry! Thanks to everyone who helped me out on this
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-19-2011, 05:55 AM
Just an update
two weeks and car is dry, no leak detected and water level is stable
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-19-2011, 07:15 AM
coug60's Avatar
coug60 coug60 is offline
06 BMW 650i Sprt/Prem Pkg
Mein Auto: 2006 BMW 650i e64
I had just posted this on the 17th... http://www.bimmerfest.com/forums/sho...d.php?t=582161
+ Various Mods & Upgrades
Old 11-19-2011, 08:32 AM
This is all great info, I am happy that you guys are posting the cause and fix. The simple O ring is the way to go. If the sensor is good and the hose is good I wouldn't replace either since it is simple enough to do if and when they actually fails. The O ring is obviously the weak link in the system. Another BMW engineer fail!
Certainly if I ever have a lower leak this is the first part I would check.
Old 11-19-2011, 10:40 AM
+1 Amen we are all on this forum to help and talk these issues through
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 10-13-2012, 08:21 PM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
+1
I got a low coolant notice last night. I was going to fix it in a week or so but may dive in this weekend armed with this info
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato (SOLD)
BMWE65: 22x10 / 22x11 Asanti ELT (SOLD)
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS430 UL:Air Suspension, 20"MAYA DLS
Old 10-21-2012, 12:38 PM
Mein Auto: fun cars
I just did this o-ring replacement today, and was surprised at:
1) how little coolant came out (maybe 4oz) even though the level is full (engine stone cold)
and
2) how the sensor doesn't 'click' in or anything similar. I was left hoping it's in all the way. I guess that just shows how important that o-ring is to the seal.
Diagram a few posts up was money, helped me find the sensor with ease.
