E46 M3 (2001-2006)
Old 11-11-2011, 12:27 PM
BlackStarMiG BlackStarMiG is offline
Mein Auto: BMW E46 M3
Exclamation Loud Diff Clunk
ok its made that sound since i bought the car in February but it wasn't this bad it happens when I accelerate from a stop and when high rpm shifts are made. at first i thought it was the normal m3 diff clunk but eventually it got to the point where when i made high rpm shifts or accelerated fast it felt light someone was hitting the underbody of my car with a hammer ( a big hammer) now im just afraid of driving hard or even gong any higher than S1 on my SMG its been like this for a while and this morning i decided to check if it was the rear diff bushings so i lifted the back end and tried ti see if the diff had any movement and it turns out they are still good there wasn't any movement with the diff also the subframe bushings are good as well and so is the Guibi or whatever u call it the rubber spacer between the driveshaft and the Diff. so i guess my question is:
1. Where else is the sound coming from it feels like mid to rear clunk.
2. Could it be the Driveshaft center support?
3. i need to fix this please help
Old 11-11-2011, 01:56 PM
Matt P. Matt P. is offline
Mein Auto: 2004 E46 M3
I get the exact thing on mine under hard acceleration. If I lift my foot off the pedal when it shifts, it doesn't do it.
I had my car looked at in a dealership and they found that the shafts were loose in the diff. Everything else is still very solid. (bushings in front and behind the diff, tower mounts, subframe, etc.) My problem is the diff and shafts. That, at the dealership is a $5000 repair.
Old 11-11-2011, 10:55 PM
yea same here if i let off the pedal right before it shifts it doesn't do it. so did you get it done? did it fix the problem?
Old 11-12-2011, 04:46 AM
I haven't done anything yet. It is in storage for the winter. I will try and find a used diff over the course of winter because $5000 is way too much. Or I might have this one rebuilt. There is a shop that specializes in diff reconstruction not too far from where I live. I will have them look at it before I do anything.
I don't know about your diff, but mine is leaking slightly too.
EDIT: I just noticed where you are from. I bought my car in Scottsdale. North Scottsdale BMW did the inspection and completely missed that.
Old 11-12-2011, 09:23 PM
yea here in scottsdale there a chappman bmw thats where i buy my oil and all but im afraid to take it to get it inspected and have it come out with something else that didnt fix the problem and cost me an eye. i mean my diff feels good the car is really fast doesnt feel like something is wrong with it other than that loud bang i guess the best thing i could do is take it and see what they come up with
Old 11-13-2011, 02:15 AM
2004M3JMF 2004M3JMF is offline
Mein Auto: 2004 M3 convertible
Yes, mine does the same thing. My diff is leaking a little too. Again, if I lift a little when shifting it doesn't do it. I would also like to know what the cause of this is. Maybe a mileage thing. I have 70k. Does anyone have the same issue with low mileage leads than 20k?
Old 11-14-2011, 05:52 AM
My diff feels fine as well. There's no loose feeling when I turn corners. There's no wandering on the highway. The car is as fast as can be. It can spin the tires up and into 3rd gear. But when I give it a go, like you said it thumps so loud that it feels like the rear end will shear off.
I have 97k on mine now. I don't know the previous owners driving habits either. Are all these cars from southern states where it is hot year round? I did notice that in Arizona, it was practically impossible to to make the rear tires spin on the hot pavement. Maybe the extra grip causes (premature?) wear on the diff and drivetrain?
Old 11-14-2011, 04:16 PM
i didn't notice any oil leaking and yea mine pretty much burns out up to 3rd gear as well and i have 9+ inches of rear tire with my IForge rims, i dont think its the extra grip that does it, but thats the thing i just dont know what it can be that makes such a loud thump or bang sound i mean you feel it hit pretty hard in the underbody or somewhere and when i lifted the car the Diff looked and felt really solid no play at all i even tried moving it with a crowbar and some leverage but nope no play at all. my other option or thought was that it could be the shaft center support that might be worn so it could have some kind of play in the shaft and when you give it power or shift it could bump but idk since it was covered up by the heat shield
Old 11-14-2011, 04:23 PM
I'm going to lift it up again and inspect it pretty thoroughly to see if i find something i didnt before ill let you guys know what happens
Old 11-20-2011, 05:08 PM
WE90325 WE90325 is offline
Mein Auto: 06 325i
I am buying a 2004 M3 with 99,000 miles. The owner said he replaced the diff fluid with Royal Purple fluid which does not have a friction modifier. He said he had it for a few months like that and before I purchased the car he would drain it and put in the OEM fluid?
Do you think this would have any negative effect or have destroyed anything?
1970 Mini Cooper
2004 Mitsubishi Evolution RS
2004 Subaru WRX STI
2008 BMW 135i Coupe
Old 11-22-2011, 09:23 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Turner Motorsport has a kit to fix/prevent the subframe mount issues.
But it is a weld in kit and requires some skill to install.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 12-05-2011, 01:18 PM
golferken55 golferken55 is offline
Mein Auto: 2006 E60 (BMW 550i)
wow thanks guys. I was just about to post a question but I think I found the answer. I hear a "thud" after shifting into gear and releasing clutch. I think its the differential but I dont hear anything though as been described. What does "wandering " mean?
Old 12-05-2011, 06:34 PM
I recently spoke to one of my technical advisors from a high performance shop I usually bring my other cars to and he said the thump we hear would be "normal". He said the system as it is will feel like the whole rear end wants to rip right off the back. Also said that the car may feel like it wants to break itself in half. We'll see, I have plans on getting that thoroughly checked out in the spring. Possibly even change the diff.
Old 12-06-2011, 08:07 AM
Pinecone's Avatar
M Mad
Uh, NO.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 01-05-2012, 01:05 AM
Any new News??? i wanna see if we can bring this thread back to life im still having the problem and im just getting more and more scared one day ill look in the rearview and see my diff on the ground and now i hear that the vanos bolts are crap and they sheer off potentially killing your engine wtf? i swear i have nightmares why are e46 full of problems all of a sudden thi has always been one of my dream cars now i kind of regret having it
Old 01-05-2012, 10:28 AM
Uh, NO.
That's me being sceptical.
Right now my car is nicely tucked away, sound asleep in a garage next to an '86 Toyota 4Runner rock crawler. The more I think of it, the more I just want a "new" diff to end the problems. My frame is not damaged. I have the Turner Motorsports reinforcement kit to install no matter what to strengthen it.
Old 01-05-2012, 10:47 AM
Just so I can understand, I have seen different displays for the transmission on the dash. Mine doesn't look like what I have seen.
Here are some pictures of it. Sorry about the poor quality... they were taken with a cell phone... the ex took my camera.
Neutral...
Auto mode... with a large D and a small S?
Manual... Little D and no S??
So far, does this all look normal to you all? Is it what you have?
This is one I found on google image... NOTHING like mine...
The thread where I found the picture said O are early model and N are later models. Sounds reasonable. But I don't understand the large D and little S in Auto mode and only the little D in manual. Do you guys have anything different?
This is where I found the picture.
http://www.cslregister.com/forum/showthread.php?t=7564
They also talk about abrupt gear changes on the second page with a program upgrade to make the changes smoother. (at full throttle with foot buried in the carpet)
Old 01-06-2012, 07:35 AM
Pinecone's Avatar
M Mad
It may not be the diff.
But my point was that ths is NOT normal.
I was saying that this part:
..one of my technical advisors from a high performance shop I usually bring my other cars to and he said the thump we hear would be "normal". He said the system as it is will feel like the whole rear end wants to rip right off the back. Also said that the car may feel like it wants to break itself in half.
was NOT correct.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 01-05-2012, 01:13 AM
also before i forget since i live in arizona its always hot here but recently its been pretty cold well to us arizonians 57 degrees is cold. and when i start my car in the morning and switch to auto on the SMG on S1 it will not shift from 1st gear to 2nd till like 5k rpm or unless i switch to paddles but after a few gear changes i go back to auto and its fine. dont tell me my trans is gone now too ill shoot my self. any comments??
Old 01-05-2012, 08:42 AM
Hey I ma having same issue with my e46. It soiunds "clunky" on occassion like rear diff is going to fall off. Also, do have trouble getting into low gears when accelerating slowly? It jumps and sloiws and jumps and slows like its noit in the gears right?? Thanks
Old 01-06-2012, 07:33 AM
Pinecone's Avatar
M Mad
The little letter to the right of the neutral or 0 position tells you that moving the stick in that direction changes the mode to that mode.
The display is two parts. The left part is the Gear Number Indicator. The right part is a s shift diagram (like you find on shift knobs). But since what happens when you move the shift lever to the right changes, the letter on the shift diagram also changes.
In the early cars, S is sequential manual mode (only shifts when you tell it via the paddles), A is auto mode (shifts when it thinks it should).
A Big A next to the gear number tells you it is in Auto Mode. No letter next to the gear number means you are in S mode.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 05-15-2012, 06:57 PM
mwhiteknight mwhiteknight is offline
Mein Auto: 05 m3 05 545i
If you feel resistance when you turn then it is the diff. Either need fluid service or a new diff. It should be smooth and no resistance.
Old 12-22-2013, 05:33 PM
rexone rexone is offline
Mein Auto: 2003 M3 Convertible SMG
I have the loud "thud" in the rear also, but only occurs when I am in Manual Mode under HEAVY acceleration and occurs when I shift from 1st to 2nd and then from 2nd to 3rd, after that no Thud.
Any ideas on this one.....
