Old 12-11-2011, 06:49 AM
tylerdog44 tylerdog44 is offline
Mein Auto: 740I
I recently have replaced my alternator and cannot get back in to top off my coolant.
I pulled on my hood release and it will not pop the latch.
The weather is extremely cold and had someone hold the latch while I pulled up still not working.
The car always gave me a hard time by myself but when I had someone hold it has always opened.
The passenger side grill is off how can I trigger the switch manually to release hood?
Can anyone help?
Old 12-11-2011, 07:59 AM
CrossT CrossT is offline
Mein Auto: E38
Tylerdog. I've got the same thing happening with my 2000. How did you remove the grill?
Todd
00 740i
Old 12-11-2011, 08:40 AM
Mein Auto: 740I
remove grill
The grill has plastic latches holding it from the inside. The latches were already broken from previous owner so all i did was shift it from side to side and it pulled out. The passenger latch is right there but I still do not see anything i can trigger to release the hood.
Old 03-07-2012, 01:01 PM
kingbled kingbled is offline
Mein Auto: 1999 540i 6speed
Are you still having problems getting into you engine compartment? You left no update
Old 03-07-2012, 07:46 PM
Mein Auto: E38
I was able to remove the grilles and get to the latch mechanism to pop it. I didn't fix the cable yet though. It appears to be missing an end piece to attach to the latch mechanism. So, for now I removed the hood mounted part.
Todd
00 740i
Old 03-09-2012, 06:42 AM
I had the same thing happen. It is not that hard a fix either. The cable will meet on the drivers side where you will see a first box that can pop open. It can be fixed there with the purchase of a 40$ hood mechanism if it broke in another place there is a junction in the front of the car. The driver part leads ito the fire wall. Make sure you lube them so it does not happen again.
Old 03-09-2012, 01:00 PM
Mein Auto: E38
Mine doesn't appear broken, just missing wherever attaches the cable to the mechanism
Todd
00 740i
Old 05-06-2012, 07:14 PM
sik740il sik740il is offline
Mein Auto: 1999 BMW 740IL
i just replaced the two hood pins on mine and it works great again....l
1999 740iL with Seidl body kit, angel eyes, custom interior , chrome tips on exchaust w/performance chip , K&N filter
Old 05-06-2012, 08:45 PM
Mein Auto: E38
sik740. What are those wheels on your car? I think I have the same. Mine are 19's
Todd
2000 740i
HTML code is Off
