garage door opener - Bimmerfest - BMW Forums
Old 01-11-2012, 05:00 PM
amelia'sx5 amelia'sx5 is offline
Mein Auto: x5
garage door opener
So i have read the manual and i still can notseem to figure out how to program the garage opener. HELP!
Old 01-11-2012, 05:15 PM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: Deutsch Automobil
It's clearly laid out step by step. Read it again
I did it on my first try
Old 01-11-2012, 05:37 PM
larrytressa larrytressa is offline
Mein Auto: X5 and 135i
Garage door
I have a 135i and a WAYNE DALTON garage door opener and they are not compatible. You'd think BMW would cover all bases..... You may have same problem.
Old 01-11-2012, 06:58 PM
nicusor123 nicusor123 is offline
Mein Auto: Sedan
I'm with Wayne Dalton as well and my x5 works just fine.
Old 01-11-2012, 07:05 PM
Frigs Frigs is offline
Mein Auto: 2008 335XI
I have programmed my Z4M and 335Xi, and the programming works differently than other cars I'he had. It is ultimately about following the book, which says you have to first follow the non- rolling steps and then the rolling code steps. Where most people have rolling codes you'd think you could start there, but you have to go through both steps.
Of course my newest car is a 2008 and your models could be different ... hope this helps
Sent from my Kindle Fire using Bimmer
Old 01-11-2012, 07:27 PM
jashearer jashearer is offline
Mein Auto: Holden Wagon & Sedan
Mine too, although I can't program it to open both doors, every time I do the second opener it overwrites the first... Is the same on all my gm products as well.
Jay
Sent from my DROIDX using Bimmer
Rover - 2013 Holden Commodore SV6 Sedan
Clark - 2013 Holden Commodore Sport SV6 Wagon
Brumby - 1955 Holden FJ Ute
Old 01-12-2012, 02:07 AM
ductman's Avatar
ductman ductman is offline
Mein Auto: 2011 X5 35D /2011 M37X
I too had many issues with the rolling code, took me two days to figure it out where previously on any other vehicle , took me about 5 minutes, I solved the problem by
reading the manual from my wife's 2011 M37, apparently BMW skipped a step in the programming instructions, all Homelinks operate the same, it is helpful with another person as you have to push the learn button on the garage opener and run back to the car and push the coressponding button 3 times within 30 seconds, if you do it yourself it is great exercise , climbing the step ladder to push the button and running back to the car, in fact I didn't have to go to the gym that day as I must have run back and forth at least twenty times!
Old 01-12-2012, 05:14 AM
bobamoo bobamoo is offline
Account closed at users request
Mein Auto:
Programmed mine in a few minutes. First, learning the remote. Then, learning the rolling code. Works great!
Old 01-12-2012, 07:17 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
What worked for me was actually touching the remote to the mirror during programming. Holding it an inch from the mirror just wasn't working. Other than that the instructions were fine - I just wiped the memory first then followed the rolling code programming steps.
