X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
Buy a new set of rims and non-RFT.
'12 35D AW-CINN ZAP/ZC3/ZPP/ZTP/456-multicontour/2LE-20's/300-spare/220-self-leveling/4MS/752 www.playabonita.ca -- wifes bathing suit company -- pretty girls... |
Bunch of manuf with all weather 20s. Search the forum...Michelin, Continental.
Check on tire rack. Don't think they exist though
Get a second set of wheels.
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production |
There are several different non run flat all season tires in our size, but the only winter tires that I've seen in our size are Pirelli Scorpions, and they are run flats...have them on my '11 50i. They do ride somewhat softer than the Bridgestone summer run flats that came on the truck, but the ride is still on the stiff side. As you might expect there's a bit of a handling tradeoff with the softer ride and the winter tread pattern, but my guess is that only enthuisatic drivers would notice. And despite the wide width of the tires, the Scorpions are great in the snow. The X5 with 20 inch Scorpions is better in the snow than my Pathfinder with Michelin LTX tires, which have a reasonably aggressive tread pattern (and I have an older Pathfinder with part drive 4 wheel drive) I know I'm in the minority here, but I like the stiff ride and sharp handling of the run flats on this truck, whereas I ditched the run flats on my Mini Cooper S (with sport suspension) because the ride was nothing short of brutal. On the Mini there was a noticeable loss in the go kart handling due to the softer sidewalls of the non run flat tires, but I had little choice as the ride with the run flats simply was not tolerable with the bad roads around here (I'm in New Jersey)
Just pick up a set of 18's or 19's and have a dedicated winter set. Get best performance in summer and winter, not to mention you will save the 20" rims from the winters. The cost is not more, you just front load your tire cost.
12 X5 50i Sport 11 M3 DCT 11 X5 50i (lemon) -- SOLD -- 08 550i M-Sport 04 BMW 545I sport 07 BMW X5 4.8I sport 02 BMW X5 4.4i sport 01 BMW 540I M/sport 00 SL500 97 SL500 |
No doubt 18's or 19's will be better in the snow versus the wider 20's, but for me I like the look of the 20's...that's why I paid the extra $ for them to start with, and I would prefer to have that look year round. When I purchased the truck I was concerned that there would be no 20 inch tire available that would be good in the snow, but like I said above, the Scorpions do work well, although many here want to avoid any run flat tire whatsoever. It would be interesting if someone who is using 20 inch all-season non run flats could relay their experiences.
Is anyone running 20 inch all seasons?
There are always a lot of comments about going down to 19 or 18 inch rims for winter, but that's a pain in the rear end - storing them, switching them, etc.
Has anyone actually tried running all seasons on the 20 inch rims? I know they are available, I'm just concerned about the width and it's realistic ability to handle snow. Any first hand knowledge? |
So I figured I'd come back and provide an update. I'm running the 20 inch staggered setup and I've switched over to the Continental DWS's. There have been 2 snow storms here in the last week, so if course I've taken the car out to experiment before and after the plows were coming through. I also took my family members 4.8is with the 20's because he has taken the 20's off and put dedicated 19 inch 255 snows). So I have a fairly good comparison reference. Without snow, the DWS's are fantastic tires. Very smooth ride, good handling, and excellent low noise. A significant improvement over the run flat's that originally were on the car. Absolutely love them. The great news is, the DWS's are also FANTASTIC in the snow. We took both X5's up the same course and routes and ran into no situation the DWS's couldn't match the dedicated snow's. Slow crawls up steep hills, descents with lots of braking, extreme and controlled handling comparisons. Highway, local roads, back roads. Bottom line, the DWS's are about as close to dedicated snow tires I've experienced in all seasons. Additionally, I was amazed the 315's didn't seem to have much effect. My conclusion, for anyone trying to decide if they should go the DWS route or use dedicated snow's, unless you are running in very extreme climates or locations, the DWS's will perform amazingly well even in the 20 inch setup. You can take the comments from the peanut gallery not running them with a very large grain of salt. For many of us, storing and changing over dedicated snow tires is a pain. The DWS setup in the staggered 20's IMO make that changeover completely unnecessary in my region (about 1 hour north of NYC). Best of luck! |
what type of conditions have you tested them in (i.e. depth of snow, etc.)?
I want to take mine up to mountains for ski trips in Tahoe, and I have experienced significant snow fall in my previous vehicle, so I'm skeptical of the handling and performance of a 20" tire in challenging conditions. |
I assume you have the same tires? If not, this assessment does not apply, this is my specific experience with the continental DWS's on the 20 inch staggered setup, it will not translate to any other tires, so please don't read it as a generalized statement about all 20 inch setups. Tires are almost new (under 2000 miles). Unplowed to about 8 inches, and of course all conditions between that depth and different degrees of plowing. Packed down, loose, etc. The temperature fluctuated over the day/night between roughly 26 and 30. Heavy snow falling during most of the playing. We sought out the most difficult roads we could find. The largest crawling incline/decline slope was very exaggerated and quite unrealistic for most normal driving, a paved but unplowed private entrance. As I indicated, the width was a surprising non-issue, which was my largest concern. And i had another x5 with me with dedicated 255 snows for direct comparison. We switched back and forth driving both cars and for what it's worth, all 3 drivers had the same reaction/opinion. |
I don't know if this is still the case, but a few years ago it was recommended that you not switch run-flats on rims very often, as the tire mounting machine can compromise the integrity of the side wall. If it's still the case, it's a good reason to get a specific set of wheels for your snow tires.
| Tags |
| run flat tires, x5 |
