E39 540 DSC Light On NOT ABS!
Hi all
My e39 540 DSC light is permanently on. All the searches refer to the ABS and DSC light on, but mine is just the DSC light on. The car has recently had new front discs/pads/pad sensor, brake fluid, battery, climate resistor, but the light was on before that anyway. A few other searches suggest various wheel/speed sensors, but the speedo works fine as does the cruise control and all other functions/features on the car. Other searches suggest ABS module, but then surely ABS light would be on as well? ABS 100 % works, no other warning lights on, just getting a little annoying every time I put my foot down hard I chirp the tyres, not too bad in the dry, not great in the wet though lol. I had a mate pop round with a laptop & data cable plugged it in somewhere under the dash, no faults found! I'm baffled! Anybody with any ideas before I have to take car to the garage? Thanks in advance |
Is it possible you accidentally disabled it by pushing the DSC button on your MID panel?
BMW--giving new meaning to the phrase "disposable income." |
I've pressed the DSC button several times but the DSC light is still on. Also reading the manual when the car is switched off, if working properly the system the DSC will be 'on' by default so the DSC light would be out when starting the car. Thanks for your help anyway.
Maybe it's a problem with the switch. I guess I'm hung up on this because it's hard to imagine the DSC function failing in isolation, without any other apparent issues.
There are at least 2 sensors that only affect DSC......steering angle and yaw rate accelerometer. The steering angle sensor error sometimes occurs after a front end alignment is performed.
Was your mate able to read the DSC module with his laptop connected? Do you know what software he was using? If your e39 has the underhood diagnostic plug you must use it, not the underdash connector, to read all modules. The DSC light is also characteristic of having a used but uncoded DSC module installed. http://forums.bimmerforums.com/forum...+code+used+dsc Paul S BMW CCA 69606 |
There are very likely other reasons also, my point was there are indeed reasons for only the DSC light to be lit, rather the the more common DSC/ABS/BRAKE light trio. Only e39's built before ~7/2000 have both the underhood and underdash connectors. Later US cars only have the underdash connector, not sure if these dates apply to the rest of the world.
Look at posts #11 & 13
http://forums.bimmerforums.com/forum...d.php?t=907448 Paul S BMW CCA 69606 |
Good info, Paul.
I just went through the same crap and it ended up being my alternator.
*Update, turned out to be the offside rear ABS sensor £143 diagnose supply and fit
Thanks for the update. It would be nice to know what the ohms reading is for the four wheel speed sensors:
- How to diagnose the BMW ABS BRAKE DSC/ASC trifecta (1) Here's mine, for example:
| Tags |
| 540i, abs, dsc |
