Old 03-10-2012, 06:09 AM
Gerry550 Gerry550 is offline
Mein Auto: 2006 550I M Sport
Easy way of opening exhaust valve on a 550i
The solenoid is behind the cover of the let tail light. Very easy to get to! All you need is a large syringe and a hose clamp used in Aquarians to regulate air flow on the air pumps. You pull the side pipe off the solenoid push it onto the syringe and draw it back, you will hear the valve open, put the clamp on the hose, push it back on the solenoid. Job done! Check the exhaust valve to make sure it is fully open. That's it. I am sure this can be done to any BMW with a valve on the exhaust.
Old 03-10-2012, 06:48 AM
mfrasca mfrasca is offline
Mein Auto: 550i
What do you gain from doing this?
Old 03-10-2012, 08:05 AM
sockmonkey sockmonkey is offline
Tail out!
Mein Auto: BMW
I wouldn't recommend it on an I6- I've had a master tech tell me that it serves a warm-up and backpressure function (at lower RPMs) on them. Doesn't matter on a V8, so if you want to safety wire it open or use this nifty vacuum technique, have at it. It will make your V8 car actually sound like a V8 at idle.
Old 03-10-2012, 10:04 AM
TRS550 TRS550 is offline
Mein Auto: 2007 550i
Noise.
Old 03-10-2012, 11:40 PM
It is a V8..... and yes that is what I am going for....just a little more noise. I have looked at 650 exhausts and they seem to have no valves on there two boxes? The two cars share the same engine so, I can only conclude the valve only service to keep the car quite at low speed and idle? I tried a new rear exhaust, but that was just too loud. The seems just right!
Old 03-11-2012, 07:53 AM
Tail out!
Mein Auto: BMW
On the V8 it's definitely a rumble-reducer at idle- beware, though- make sure that it actually opens when you goose the throttle well- Mine was stuck when I bought the car- the dealer ended up replacing some relay and the actual solinoid before I bought it.
Old 03-11-2012, 08:07 AM
Campfamily's Avatar
Campfamily Campfamily is offline
Mein Auto: 2008 550i
How do you check for this?
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod SOLD, but not forgotten
Old 03-11-2012, 08:44 AM
Tail out!
Mein Auto: BMW
I'm not certain of the exact throttle / load percentage required, but it should have some movement revved smoothly to 3/4 throttle at idle, and less in drive with a load. Mine just never moved (I could tell by the soot on one pipe but not the other, and condensation on one pipe after a spirited drive, but not the other).
Old 03-11-2012, 09:03 AM
I have a nice "rumble" now at idle and at low speed.... I think this is the way this car should have been straight from the factory.... one of the reasons you buy a V8 is for the "sound", God knows its not for the fuel economy!
Old 03-11-2012, 11:27 AM
Tail out!
Mein Auto: BMW
Did you try any physical restraints on the arm, e.g. safety wire or hangar stuff? My only concern would be that the vacuum leaks out past the clamp eventually...
Old 03-11-2012, 01:13 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z4 3.0, 535i
ahh this is a complicated process. All you need to do is bypass the vacuum valve in the trunk as the poster indicates where it is.
The vacuum valve turns on above 3,000 RPM ( electrically). The vacuum is always there from the vacuum line. This means if you disconnect both vacuum lines, one from engine, 1 to exhaust valve, you have a constant vacuum to keep the exhaust muffler valve open.
As long as you have no vacuum leaks this keeps the secondary valve and muffler seconf pipe open, giving you a more rumble at idle and free flowing exhaust. I have picked up .5 mpg by doing.
Old 03-11-2012, 02:57 PM
Tail out!
Mein Auto: BMW
Nice- I'll grab a connector and give it a try.
Old 03-11-2012, 11:06 PM
Thumbs up
This sounds good! have you checked the valve at idle? was it open?
Old 03-12-2012, 07:19 PM
Hogie's Avatar
Yes - Valve opens on vehicle start and stays open.
Old 03-11-2012, 01:43 PM
Campfamily's Avatar
Does a later model 550 with the sport package have this valve? I was just under my car looking at the muffler in the back, and I don't see anything but a single pipe splitting into two, entering two separate mufflers, then exiting into individual tailpipes. I don't see any kind of valve mechanism under there. It also seems as though both tailpipes are exhausting at idle. I believe that the sport package included a different exhaust on the 550 in 2008. Could it be that this feature doesn't exist with the sport package?
Keith
Old 03-25-2012, 06:58 PM
Arctic-Rodz Arctic-Rodz is offline
Mein Auto: 2004 Z71 Tahoe, 97 Z28
Keith
x2 on this.. i have an 08 w/ M-sport package. I havent looked into the exhaust but it does have a nice purr when you turn it on and it goes quiet right after.
Would like to keep the purr going
Old 03-25-2012, 07:03 PM
ArtchredTTU ArtchredTTU is offline
Mein Auto: 550i
Exactly my thought! haha you beat me to it.
Old 03-25-2012, 11:33 PM
I joined the two pipes, and it work great! Valve opens when the car is started and stays open. You can hear the car at low speed now. I have not notices any bad side effects of doing this at all amd mine has been this way for three weeks now. Fuel consumtion is still the same, so all looks well.
Old 03-12-2012, 09:40 AM
jsimon7777 jsimon7777 is offline
Giant Robot
Mein Auto: Scion FR-S
Any pictures?
2013 Scion FR-S
2007 550i Sport - GONE
2008 528i - GONE
"What are you going to replace your BMW with?"
"Another BMW, with a bigger engine!"
Old 03-12-2012, 08:14 PM
Mein Auto: 550i
Originally Posted by jsimon7777 View Post
Any pictures?
this^
Old 03-12-2012, 09:12 PM
Giant Robot
What?
2013 Scion FR-S
2008 528i - GONE
Old 03-12-2012, 11:07 PM
Thank! going to try this.
Old 03-25-2012, 05:25 PM
Mein Auto: 550i
Where the heck is the solenoid? I don't see it
Old 03-26-2012, 07:27 AM
Kalil147 Kalil147 is offline
Mein Auto: BMW 545i
Would this work on a 545i?
Old 03-26-2012, 08:49 AM
Thumbs up
I can not see why not.... look for the solinoid in the boot join the pipes and see.... best tip I have found on here so far
