BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
335d: DTUK CRD-T Vs. JBD box?
It seems the DTUK-T is a better option as it is a two channel system controlling fuel throughput as well as turbo boost. DTUK is manufactured by DTE in germany which has years of diesel tuning experience for multiple auto manufacturers. JBD only controls fuel, does not control turbo boost, and JBD makes only one module for this one engine.
I could be wrong, please enlighten me. I have been considering buying both myself. |
This is a tune I've been using for some time now, and it's my tune of choice at this point, fwiw.
Stug, which version are you using? They show 3 with the top one controlling both CRD and Boost. They offer 4 different mappings for this version, so which do you choose? How do you order and take delivery stateside?
Curious minds want to know! |
Why?
Indeed we do.
Entertaining America Since 1975 ![]() European Delivery July 26th 2011 ED Video: https://vimeo.com/60051914 ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294 335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns BMWCCA #448878 |
http://www.diesel-performance.co.uk/...ails.php?id=10
And technically, there are 28 maps (each of the 4 maps has 7 different settings). Regarding ordering, just talk to Andrew/work through the site, and they'll get you taken care of. Tell Andrew that Ronin sent you if you happen to pick one up.
"Unlike our other common rail modules, GREEN, RED, CRD2, that only connect to the common rail pressure sensor, the new CRD-T also connects to the turbo pressure sensor, allowing us to control and increase the boost settings. This results in an even smoother power delivery, and even lower emissions and even more power and torque." My question is where is the turbo pressure sensor connection exactly? Last edited by cssnms; 04-18-2012 at 10:38 AM. |
It's the only piggyback tune that hooks into the boost sensor, as well, it has 28 maps to choose from (in this respect, DTUK > JBD > VAC), and it feels more powerful than the 3 I have (and yes, I've done back to back to back comparisons). My next goal, when I can actually find some time, is to dyno the car with each of the 3 modules, and then I'll have hard data to support what the butt dyno is telling me.
![]() Last edited by Stugots; 04-18-2012 at 04:03 PM. |
I have nowhere near the experience with other tune boxes as Ronin, however after three weeks or so I am very happy with my DTUK CRD-T tuning box. I have spoken at length with the DTUK GM Andrew, and am pleased with customer care and support. My 2011 335d is doing great.
Subjectively, of course, it appears turbo lag is 90% reduced. Power output feels about 30% better across all RPMs. I have not dyno'd it yet so take my claims with a few grains of salt. |
![]() It sounds fantastic, too good to be true? ![]() It certainly makes sense to control both fuel delivery and charge air pressure. They mention a new model with 3 channels, or am I getting confused already? |
![]() Post your ride already.
1. How is the turbo lag reduction on the dtuk compare to the jbd? 2. How easy is the dtuk to install compared to the jbd? 3. Are you able to clear the tuner codes when they are triggered by the dtuk unit? 4. When you say power output feels about 30% better is that compared to the jbd (at which setting on jbd) or stock? Thanks. |
At what setting on the DTUK and JBD are you comparing against?
Was the 365hp using a guestimated parasitic loss to get back to crank hp? Surely that wasn't at the wheel???
If so I need one of these ASAP ![]() Jay
Herbert - '12 X5 35d / Sapphire Black / Black Perf Nevada / Aluminum trim / ZPP / ZPS / ZCW / ZAV / Apps / 3rd row Betty - '04 CTS-V / Black Raven / Black Leather & Suede / 6 speed LS6 combo 400 hp & 400 tq Sterling - '06 Silverado HD / White / Grey Leather / LBZ Duramax - Allison 6 speed combo / Crew Cab Short Bed LT3 |
Update:
1) pbmw60 give you GBP £60 off of a crd-t 2) new review in current performance bmw mag |
So which setting seems to not pull any codes or limp mode? I assume it is kind of like the JDB where if you dot get too greedy with the settings then fear of codes/limp should be nonexistent.
--Aaron |
To all here. I have the RENNtech flash and I went LIMP Mode when I dynoed the car , hence I had NOT completely turned OFF the DSC, but I have YET to go limp mode while driving i have had as quoted by STUGOTs Or Ronin I believe the following quote:
[COLOR="Blue"]"Codes that can pop up (and will, generally, with a tune) when this happens fall along the lines of Rail Pressure Plausiblity, but I've also seen Air Mass Sensor and Gas Pressure Sensor. "[/COLOR] The first one was because I had the clamp to the mass flow sensor lose! after that I did not go SES until a month later and before I did the code erase it turned off by itself. I spoke to my mechanic and he stated that whenever you have tunes sometimes some codes will come up but usually not serious, but he did advise me never to ignore whenever the light comes up. |
JBD at 100% and DTUK @ Program 3 Map 7. Quote:
![]() Last edited by Stugots; 04-20-2012 at 09:21 AM. |
Curious, were the conditions the same between the two tests (JBD v DTUK), ie. temps, humidity, engine temp, hood open/closed in both cases? I remember you saying something about your car was heat soaked when you when to test the JBD, not sure if the DTUK was part of that same test. Also any limp modes or SES lights at Program 3 Map 7? How many miles have you driven it at this setting? Last edited by cssnms; 04-20-2012 at 10:46 AM. |
Long time no talk. For the JBD we used the dynojet at specialtyZ. You can not compare results from that dyno to another, especially a non-dynojet, as they will vary greatly. If you'd like to get together again at specialtyZ I'd be happy to pay for a dyno comparison of the systems. The JBD is a quick install easy to use type product so we've never been going for the most power with it. But if there really is something else out there making 30hp+ more (which I doubt) even if the install is more involved I would be very happy build a better mouse trap for you more serious guys. We're also working on a D meth kit currently.
Also the dyno results for the DTUK was performed at a setting that sounds virtually unusable since it puts the car into limp mode more often than not. |
You know me...I'm always open to suggestions and options. No need for you to pay for the dyno...I'd be happy to throw up the car and the tunes for comparison. I still love the JBD, fwiw, and I still consider myself a very happy owner. When it comes to the Meth kit, make sure to remember me when it comes time to test it. I have no problems driving up there and getting things set up.
#25
does anyone make a bigger intercooler yet? seems like that would be easy and make decent gains.
powered by lemings
Though I did not know the place, I set out for the land of my dreams. Having arrived at the land of my dreams, I found I did not know the place. |
