Old 03-20-2012, 07:13 PM
snickel snickel is offline
Mein Auto: 2000 z3
Security and keyless entry 00 z3
Ok I have just picked up a 2000 z3. My question is about the keys. I have two keys and an alarm remote. When I push down on the BMW logo a light comes on but doors do not unlock. Is it just a led light? When I push the alarm lock or unlock all I get is 3 loud fast chirps but doors do not lock. I have to put the key in the lock to get it to lock all doors. Does this sound like it is working right. The reason I ask is because on the alarm remote it has two buttons lock/arm panic and unlock/disarm with led light. Sorry for dumb question new to BMW. Thanks
Old 03-20-2012, 09:09 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
a. Ask the dealer. You should have been given a thorough briefing.
b. Read the manual. Almost everything (but not quite everything) is covered in the manual.
Old 03-20-2012, 09:29 PM
postalZ3 postalZ3 is offline
Mein Auto: 2000 Z3 2.8
Very common problem with the Z3. Does the vehicle has the original radio? There are 5 alarm switches on the Z3, hood, each door, trunk and radio, if any of those are not functioning as intended you'll get the three chirps you mention. If the radio has not been replaced with an aftermarket radio, I will take a look at the hood switch. Send me an e-mail at agsofia at att dot net I'll send you pictures of locations of the switches.
Tony
<img src=http://i.imgur.com/JMjPR.jpg border=0 alt= />
Old 03-21-2012, 01:36 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
1) Yes, the key only had a light in it to help to keep from scratching the car when unlocking at night.
2) 3 chirps means the system is not arming, normally due to something being open or a switch problem.
You can buy additional alarm key fobs and code them to your car. I got one off eBay. The instructions come with it or are available online.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 03-21-2012, 12:54 PM
Mein Auto: 2000 z3
Thanks postalZ3.... It was what you said bad switch. I unplugged it and now I have my alarm back and my doors lock.. Thanks so much.
Old 03-21-2012, 01:01 PM
Glad to be of help
Old 01-27-2013, 08:53 PM
LicLic LicLic is offline
Mein Auto: 2000 Z3
alarm issues
started having problems with the 3 chirps, found the one under hood, disconnected and same problem, reconnect. Where are the other 4 located and can I disconnect each one until i find the correct faulty switch
Old 09-27-2014, 07:27 AM
PeterJ73 PeterJ73 is offline
Mein Auto:
I have the same three chirp problem. I've isolated it to the hood switch. Does disconnecting the hood switch eliminate the problem? Is it worth replacing the switch? If so where can you find one?
Old 09-27-2014, 08:53 AM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
You can just unplug the switch. I replaced mine several time and it is now unplugged.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 09-27-2014, 03:32 PM
Mein Auto:
Thanks! I disconnected the switch and removed it from the frame. I was able to use my remote locking fob and so far so good! I was also able to find a replacement using part # 61-31-9-119-052 from PartsVP.com for $17.26. (including shipping) We'll see how long it lasts!
