E36 (1991 - 1999)
e36 weird high
Hi all , find some weird rear view from My E36 320i just this morning after full fill it with gasoline,my old lady a bit slant to the right side.
measure it from rear fender lips to wheel hub Center found about 1" differences left and right, the right side more close to the ground , what it can be causing the problem: 1. Shock absorber 2. Coil Spring 3. Stabilizer thanks for advice |
wat
![]() EDIT: Are you trying to say your car is leaning more on one side?
1997 Bmw 328i Vert - SOLD 3/25/2012 1992 Bmw 325i - ****ed 4/2/2012 ![]() Last edited by Jok15; 03-21-2012 at 12:26 AM. |
Yap...to the right side,same condition once the gas is half or empty ( I just finish it with long journey
Noted for above will go under her and check for the same, any way can shock absorber causing this problem
Passengers?
If not I would get under and inspect for anything that may have come unbloted. A cm or 2 might be normal but an inch is not.
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
What she doesn't know won't hurt her....
Could be your rear spring not seated in properly
... Or a different size tire on one side?
-Usama ![]() "The American Dream only makes sense if you're sleeping" - Lowkey |
Isnt the drivers side supposed to sit slightly higher so that when you sit in it, it evens out? But an inch is exessive.
ProjectTechnik.com - Alberta based BMW Community See My car on Project Technik HERE! | OE M3 Bumper | M3 Mirrors | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks | Founding Member of the Canyonrot Club! #343! |
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.” - Hunter S. Thompson, |
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
I've had three or four different master tech's mention it.
Also, there has not been a single example provided which shows any actual dimensional differences between the left and right struts. Not in the history of the internet, and not in any official BMW technical literature (to my knowledge). It's all "my mechanic said this" and "this forum says so". You guys gotta go with what's logical. There is nothing about the stock E36 suspension which suggests that one side is higher than the other.
Not sure if it's true or not, but I suppose the ride height could be increased on the drivers side by altering the spring perch, not necessarily the spring.
-CJ
What did they say in regards to how much higher the drivers side is supposed to be? Where did they say the measuring point was, ground to top of wheel arch?
Measuring point IIRC was top of fender arch to ground.
and the difference is 1/4 inch.
Id check for someone doing the Hazzard County sh!t in your car.
![]() REMOVE any cheap suspension component and replace with REPUTABLE PARTS. Then, get a PROPER Alignment done and tire/tyre inspection. Take pictures BEFORE, and AFTER from ALL ANGLES. Come back, and post pictures. We'll take a look. ![]() Cheers!
^ I've always thought the same.. Especially since the rear springs are interchangeable with each other, and so are the fronts.. sooo if you swap sides, the car will lean to the left?
Edit: this is meant to add to karls post
-Usama ![]() "The American Dream only makes sense if you're sleeping" - Lowkey Last edited by cmybimmer; 03-21-2012 at 11:15 AM. |
what about natural weight design of the car? IE the driverside weighs slighly less than the passenger?
![]() anyways OP check everything, if your not low just peeking you head under the rear bumper may tell you all you need to know.
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
While technically possible, this idea is highly unlikely, and has never been verified by or even alluded to by anyone. And when you tear down an E36 to a bare shell, nothing indicates that this is remotely plausible. Then there is the fact that E36s were sold in different markets, with both RHD and LHD.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 03-21-2012 at 01:22 PM. |
Maybe people just say that because the gas tank is on the passenger side?
-CJ
Only the filler neck is on the passenger side. The fuel tank itself is centered under the rear seat.
dude karl you are prepped for this! GO GO GO GO!!!
dab of oppo anyone? Project List: Replace coolant temp sensor Replace starter Brake and Power Steering Fluid Flush Front Control Arms, Bushings, and Tie Rods Replace Passenger Lock Actuator Reglue Peeling Hedliner Swirl removal |
this is a sicnes on e36s. some people say its becouse of batarie put on the back, but overal it is ur suspension problem. some of the bushes and links may me worn more what results in this problem, its always like that, when the weight is being put on the back, one side ( wekest links) will give more than other. unless u are going to change the whole suspension links, bushes joints etc, than there is no point to worie about.
#25
grow up, man. there is no need for all your bull****!
i said, that if the car leans to the left or to the right, its nothing to do with the drivers position or batteries position, its because suspention on that side is weaker than in other side, and MOSTLY it will show up more than normally, when weight is added on the car! |
