Photos: Duralast Platinum H6-AGM Battery into Z4M - Bimmerfest - BMW Forums
Old 03-24-2012, 02:25 PM
Zuzax's Avatar
Zuzax Zuzax is offline
Calvinball Professional
Mein Auto: '07 M Roadster
As set up in this thread, I didn't want to pay $275 - $295 for an OEM battery. So after a quick trip to AutoZone, I returned with a Duralast Platinum H6-AGM and got started:
One of the hardest parts was getting my hand in there to loosen the Velcro straps. Thankfully those little knobs on each side raise the tray the top folds into. Marginally.
BMW Strip-o-matic fasteners hold the bottom and three massively torqued 10mm nuts hold the top. This is the worlds most securely fastened flimsy battery cover.
Opening the wrong door on the positive terminal. Shut that now and never touch it again.
The correct positive terminal door. Thanks Ron! This level of visibility is impossible when changing the battery in a roadster.
Duralast Platinum H6-AGM left, BMW 61 21 7 553 951 right. Twins except for the stickers.
Duralast Platinum H6-AGM left, BMW 61 21 7 553 951 right. Note that the BMW battery has one of the venting holes plugged. You'll need to remove this and transfer it over to the Duralast. These batteries have vent holes on each side.
The vent plug.
Vent plug installed with vent plug installation tool.
Slightly different specs.
And now to hook up the negative terminal so we can test start it. Note the impressively tall screw for the battery bracket.
Started up like a champ. Reassembly commemorated with one last terribly fuzzy iPhone photo. Now to reprogram the Nav for clock/date and reprogram the auto-up on the windows. It somehow remembered my radio stations.
One extremely happy, unexpected change is that somehow my DICE came back to life with the new battery. I thought I had fried it with my CTEK during a reconditioning cycle, but it works once again, quirky DICE functionality and all.
Also the remote unlock and roof opening range has increased from about three feet to at least 25. I have not tested to determine its max range.
2007 Z4 M Roadster Sepang/Sepang-X/Black, Premium, Nav, BMW Strut Bar, Stubby Antenna, Dice, UUC clutch stop, Star Specs, and the rest joyfully stock.
Old 03-24-2012, 04:50 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
Nice write up! I guess that since I still drive my same OLD Z and the battery in under the hood I won't be able to enjoy the benefits of your instructions. OH wait! The M3 has a buried battery too! Any chance you can make the drive next weekend? It's kinda like the year you were the ring master.
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 03-25-2012, 11:55 AM
Starscream88 Starscream88 is offline
Mein Auto: Imola Red ///M Roadster
Wow they look totally identical!
Imola Red Roadster
Old 03-26-2012, 12:24 AM
Hoops432 Hoops432 is offline
Forever Fast
Mein Auto: '06 M Coupe, '08 K12S
Hahaha.... hilarious!
Thanks heaps for the write-up.
2006 IBlue BMW Z4 MC (OZ spec) - ESS VT2-525 Supercharged, JRZ RS1 suspension (500#F, 600#R) with Vorshlag plates, ST Trophy BBK with CL R6E pads, KKS gated exhaust, TMS sway bars, RE rear camber arms, VT engine mounts, Recaro Pole Position (driver), APR GT wing, Street: Volk G2s and Potenza, Track: Volk TE37SLs and BFG R1s.
Old 01-21-2013, 09:03 PM
senser senser is offline
Mein Auto: 540i/6 E39
Sweet dude. I put one of these Duralast Platinums ( H8-AGM ) in my 540i and it works nicely. I wanna see how long it will hold up though.
Old 01-22-2013, 11:19 AM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
I am sure it will last as long(if not longer) than the OEM battery did.
Old 01-22-2013, 12:53 PM
I sure hope so. The OEM battery had a production date of September 2001 so almost 12 years is awesome. Some research says that AGM batteries don't last as long as traditional lead-acid.
Old 01-23-2013, 06:30 AM
keeton keeton is offline
Mein Auto: '07 3.0si
Originally Posted by senser View Post
...Some research says that AGM batteries don't last as long as traditional lead-acid.
What research is that? The original Miatas used AGM batteries and 10+ years was the norm for those.
What will destroy an AGM battery is a fast charging rate that a wet-cell battery could more easily tolerate.
Old 01-23-2013, 07:08 AM
salameh13 salameh13 is offline
Mein Auto: 325i BMW 06
Battery Replacement
Hi,
My batter died in my 2006 BMW 325i, and I am looking to buy the Duralast Platinum from AutoZone, I remember I called the dealer one time and asked them about battery replacement, and they told me the battery has to be registered at the dealer after you install it, its gonna coast $140 just to do the registration,so if i buy it and install it myself, i will still have to go to the dealer, is this true?
Old 01-23-2013, 03:13 PM
Originally Posted by salameh13 View Post
Hi,
I would assume an 06 325 is similar to the E85 Z4. If so there is not a registration process so the dealer is pulling your leg. I could be wrong and the E46 forum should be able to confirm, but I think I saw threads there where folks were swapping E46 325i batteries on their own.
Old 01-22-2013, 12:18 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
On realoem.com it looks like this fastener is #8, p/n 07147120304 (plug). Can anyone confirm this? My car didn't have any of these fasteners although I noticed that the holes are there.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 01-23-2013, 10:17 AM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
Registration electronically mates the new battery to the car's charging system and can extend the life of the new battery by charging it more intelligently.
http://www.bimmerfest.com/forums/sho...gister+battery
However, registration is not cost effective if you must buy a new battery from the dealer that costs $350 including registration. Or if you buy a $150 Duralast from Autozone and must pay a dealer $140 to register it with your car's ECU.
It is cheaper to just buy the Duralast and replace it when it goes bad in 3 to 5 years. Like we have done for decades.
Old 01-24-2013, 08:31 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
Sometimes when a battery supplies marginal voltage, the car's electronics go "crazy" (yea, that's a technical term). Perhaps the battery came with only a partially charge. Did you charge the battery before the first use?
Old 01-24-2013, 08:43 AM
No I didnt, i just bought it and install it.
Old 01-24-2013, 10:09 AM
formerly updmst
Double check the battery's connections are clean. Then charge with one of the "smart" chargers (CTEK, Battery Tender). The battery may recover.
Old 01-24-2013, 10:48 AM
I will double check it once i get home, thank you though so much for your responses.
I have a question i don't know if i should ask it here, I read in one of the forums about resetting the throttle by holding it all the down to the ground for 30 seconds then push the start button, i know the process steps right,but what does it do to my car if i do it?is it gonna be like adding more power when i press the accelerator paddle cause i am not really satisfied with the way it is when i go from the 0
Old 08-22-2013, 06:18 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
I know this is a old post - but to add a piece of info from my "Battery Source" guy, most batteries are coming from the factory only partially charged and they now charge everything prior to installing in a car or if you do it yourself they recommend overnight trickle charge before installing.
FWIW.
Regards
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
VRSF Charge Pipe /
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 02-07-2014, 01:03 PM
Stolizino Stolizino is offline
Mein Auto: 2006 M Roadster
So, My Z4M Roadster is now almost 8 years old with 21,000 miles. I'm the second owner, bought it in 2009 as a CPO. The battery power and charge-holding capacity has diminished to the point that a replacement is warranted. I purchased the Duralast Platinum H6-AGM from AutoZone for $162. Upon exposing the old battery, I saw the DPO apparently installed a plain vanilla Interstate MTP-91, no AGM, AND he failed to connect the vent tube. What harm might have already been done, and what benefit does my car gain, if any, to now install my Duralast AGM? And exactly where does one connect the vent tube?
I decided to install the Duralast and once lit up, I needed to reset the clock and re-pair my iPhone, but my radio station selections and seat positions were intact. The intermittent left headlight outage seems to have repaired itself as well.
Old 02-08-2014, 07:07 AM
I would think the vent tube would still be back there when you opened the cover up and should just pop right into the new battery. A non AGM battery works fine- I replaced mine with a standard battery a couple of years ago and have had no issues. So you are on your third battery in 8yrs. That is pretty short lifespan. You will also likely need to reinitialize your auto up/down windows if you haven't yet.
Old 02-08-2014, 09:43 AM
Auto windows required no initialization. I'm also getting improved fuel economy.
The vent tube is present. The question is, how does one connect it to the battery?
Eight years since the car was first delivered to the original owner. Total of two batteries during that time, so let's say average life expectancy is 4 years on a car that is not driven that frequently. Is that really a short life span? The new Duralast warranty is only 36 months total.
Old 02-08-2014, 07:03 PM
There is a small hole on the back side of the battery(facing the rear bulkhead when installed) at the center top of the battery which the tube will insert into. IMHO 4yrs is a short life span. My first battery lasted from 2006-2011. My car is also rarely driven(18k miles on a 2006). I do trickle charge the battery monthly.
Old 02-20-2014, 08:05 AM
elerner61 elerner61 is offline
Mein Auto: '07 Z4M Roadster
For 30 years of car ownership in the Northeast, 4 years is my typical battery life for a non-AGM battery in cars in non-heated garages. With our car's "sensitive electronics", it doesn't seem to make sense to go beyond this.
Old 02-22-2014, 10:20 AM
KevinC's Avatar
KevinC KevinC is offline
your average JAMF
Mein Auto: '05 330Ci ZHP, '16 Golf R
My original battery lasted until just after the 4/50 warranty was up. But that's here in Phoenix, probably the most brutal environment on car batteries in the country. It must help that they're not under the hood, getting even more heat than the Sonoran desert already produces.
'05 ZHP Coupé
'16 Golf R
Old 12-15-2014, 06:36 AM
It looks like AutoZone has discontinued carrying the Duralast Platinum Battery, I am going with the O'Riley one. Thanks to Bucko for the spread sheet.
VRSF Charge Pipe /
BMWCCA Member
Old 12-15-2014, 12:41 PM
Bucko521's Avatar
Bucko521 Bucko521 is offline
Proud Canadian, I'm Sorry
Mein Auto: 06 Z4 3.0i & 01 Z3 2.5(2)
No problem....glad we can all help each other.
Here is the link https://docs.google.com/spreadsheets...J7A/edit#gid=0 for the Google Spreadsheet. Link allows editing, you don't need to be a Google user.
01 Z3 2.5i Sapphire Black, 01 Z3 2.5i Topaz Blue(SOLD), 06 Z4 3.0i Jet Black
ZSCCA Area Rep and Member - Prairie CruZers
