Old 04-02-2012, 08:15 PM
jkelly12 jkelly12 is offline
Mein Auto: 2002 745li
Blower motor squeak
Seeing if someone can help with this weird issue. when my car slows down starting at about 40 and coming to a stop there is a sound like the blower motor is squeaking. when i come to a complete stop it goes away, when i start to accelerate it starts up again. you can hear the squeak gets a little faster as i speed up and slower as i slow the car down. it happens with the system off. i have even removed the fuse and the same issue is there. i read on mitchell on demand that there is an auxiliary blower motor that does this. it says this blower will increase as rpm increases and decreases as the rpm's decrease. i cannot find the auxiliary blower motor anywhere. anyone have any ideas????
the noise is driving me nuts
Old 04-02-2012, 08:39 PM
pkathee's Avatar
pkathee pkathee is offline
Mein Auto: 760 Li
Yes, you need a replacement blower motor. BMW Part #64116913401
Dealer price is quite expensive but you can get a brand new one off eBay. See link below;
http://www.ebay.com/itm/BLOWER-MOTOR...35472475269665
It is under the front passenger side footwell. You'll have to remove the lower plastic fan cover. See below;
http://tis.spaghetticoder.org/s/view.pl?1/07/57/21
Good luck.
1) 760Li- Logic7, Rear entert', Rear Climate, Comfort Access, 20" DP Wheels.
2) Lexus LX470- Mark Levinson Video/Audio, 22" Diablo Elite Wheels.
Old 04-02-2012, 08:43 PM
i have removed the fuse and it still makes noise. how can the blower motor make noise when the fuse is removed??? is there an auxiliary blower motor like mitchell on demand says there is??
Old 04-02-2012, 08:48 PM
pkathee's Avatar
Mein Auto: 760 Li
I dont know what you mean by Mitchell on demand. And i'm not sure what fuse you are removing.....
Anyway, listen. If you want to eradicate the cricket/ bird chirp noise coming from your blower motor, then you'll need to have it replaced. Condensation/ Moisture gets into the unit and it fails over time. Dont get a used one because it will not last too long either.
I just replaced mine about a couple of months ago. Noise is gone.
Old 04-02-2012, 08:51 PM
Mitchell on demand is a tool that auto shops uses to get info about every car out there. its also the manual used for book time when doing repairs. what fuse??? the blower motor fuse. the noise is still there. i am trying to see if the is an auxiliary blower motor like mitchell says
Old 04-02-2012, 08:55 PM
pkathee's Avatar
Mein Auto: 760 Li
Forget about those auto shops tools. This is a BMW and it has a mind of its own that most third party diagnostic tools will not pick up.
Anyway, like I said. It is your blower motor. Pretty common issue. Do a search in here and you'll see.......
Old 04-02-2012, 09:54 PM
Pdux72's Avatar
Pdux72 Pdux72 is offline
Mein Auto: 05' BMW 745i,
Good luck.
Thanks pkathee! I have this same problem being described and has been buggin the $/#* out of me. I turn the fan motor button off and it goes away... Glad to know this ia the fix. Hallelujah!!
Any crazy install problems that i should be aware of or is it pretty straight forward...how long would u say the change out takes?
Old 04-03-2012, 12:19 AM
pkathee's Avatar
Mein Auto: 760 Li
Yeah, extremely annoying noise actually. Sharp bird chirping/ whistling noise emerging from the front vent system that sometimes get amplified/ intensified by acceleration, applied fan speed setting and what not........ I couldn't stand it anymore so I decided to pull the trigger and I replaced the fan blower.
Anyway, its a pretty straight forward process. Hardest part would be removal of all the plastic fan cover under the passenger footwell in order to get to it.
There are a couple of screws that requires removal of the 12V adapter housing on the left side of the footwell in order to gain access to the fan cover. There is no way around it. Just remove the whole trim that is attached to the adapter housing. It extends from the footwell under the dash and terminates somewhere in between the center console and the passenger seat. You'll see once you get there.......
Old 04-02-2012, 11:24 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
Just a thought, the system is always returned to fresh air, meaning the faster you go the more air that maybe pushed thru the system. Next time try to put the system on re circulate and see if it still makes the noise.
Again just a thought.
Sent from my PC36100 using Bimmer App
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 04-03-2012, 06:37 AM
Khabar Khabar is offline
Mein Auto: 745i 2005
remove the motor spray it w-40 and problem is solved. I did that and it worked for me. There is DIY for that in DIY section
Old 04-04-2012, 06:17 PM
Pdux72's Avatar
Sorry Khabar. I couldnt find it under the search. If you could post the link that would be helpfull. I searched a bunch of keywords, phrases... Even bought a vowel from Vanna White.. no luck...
Old 04-03-2012, 09:00 AM
bkdave2atl bkdave2atl is offline
Send a message via AIM to bkdave2atl
Mein Auto: 745i
Jkell,
check this youtube link out, dude does his step by step. he has a 750 but pretty much it can give you an idea, hope it works good luck
Old 04-04-2012, 11:30 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
E-box = electronics box. It houses the DME and VANOS control units, the IVM (integrated voltage supply module), and has a little fan at the bottom of the box that ducts out to the passenger foot well.
Sent from my ADR6425LVW using Bimmer App
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 04-05-2012, 09:48 AM
Go to DIY you well see "Heat blower removal " there are 2 videos from youtube. check post #17 the same video.
Old 04-05-2012, 07:27 PM
Keif would the ebox fan be loud enough to hear inside the car?? Would it speed up as the car speeds up and slow down as the car slows down??
Old 04-05-2012, 10:08 PM
try to fix one thing at time. If heat blower does not fix your problem,move to ebox.
Old 11-16-2012, 04:37 PM
carfan87 carfan87 is offline
Mein Auto: 750i
For others searching for the squealing ticking fan problems both my e-box and blower motor went bad about the same time. The symptoms below may help others troubleshoot.
The blower motor was making a ticking noise often (sounds like a leaf is stuck in the blower) when cooler out (about 40F and lower). When turning or braking the noise would come and go. When the car heats up the noise usually went away. Turning the blower speed up (or off) the noise often went away. I pulled mine apart, blew out the motor with compressed air and oiled the bearings. I noticed the motor turned harder than I'd expect too. I'll probably have to replace it but it's MUCH better now. It's an easy fix and takes about 30 minutes. I watched the video earlier in this post which worked well.
After fixing the blower motor I still heard a squealing noise (sounded like a bird) only when it was colder (under 40F) and it was very intermittent. It only happened when I started the car and lasted for 3-4 seconds. It could not be heard from outside the car. The noise was coming from under the dash on the passenger's side. If you pull off the black cover off under the passenger dash you'll see a 2" or so black tube on the firewall on the right side. I covered the hole with my hand and the noise mostly went away. This fan is the one in the electrical box and since this one looks harder to get to I'll probably just replace it instead of trying to do a short term fix. I'll also use the pictures of the process from earlier in the post.
Hopefully this will help some others narrow down which fan(s) are bad.
Old 11-16-2012, 05:06 PM
flash_n flash_n is offline
Mein Auto: 745Li
Carfan thanks so much. I've been wondering for a few days what was going on.
My symptoms are as you describe. 3-4 second squealing noise from the passenger footwell when the car is cold in the morning.
The blower motor I replaced recently and it did sound alot different.
One more thing to add to the list...
flash_n
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer, headlight vertical aim, VCGs
next up: P0492
Old 11-20-2012, 10:41 AM
7ELEVEN 7ELEVEN is offline
Mein Auto: 2002 745LI
Thanks for everyone that contributed to this post! This is on the long list of issues I currently have! ha ha
