Old 05-23-2012, 06:02 PM
Navy79 Navy79 is offline
Mein Auto: Southern California
Opening Trunk with Battery Disconnected
My BMW-325I has a probable dead battery. I tried to remove same, but needed pointers on how to proceed. I went to the internet and found instructions for removing the battery. With the battery partially disconnected, I closed the trunk. Now I cannot open the trunk to continue removing the battery. Any suggestions on how to open the trunk with the battery partially disconnected?
Old 05-23-2012, 06:23 PM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
Do you have fold down rear seat or ski pass through? if former, fold down and crawl in, pull the emergency release if you have it... If only ski pass, maybe reach through with a coat hanger or a stick of some sort and pull the emergency handle... final option, not sure if it would work... Connect a battery to your jumper posts in engine compartment, may power the trunk release button... Not sure but might be worth a shot!
Old 05-23-2012, 07:37 PM
cronus cronus is offline
3 pedals
Mein Auto: 09 E90 335i
Is there a keyhole under the trunk lid ledge above the license plate?
Old 05-23-2012, 08:20 PM
max. max. is offline
Mein Auto: 3
Remove the key from your key control and use it to open the trunk.
Read your owners manual for more info
Old 05-23-2012, 08:46 PM
Salvator's Avatar
Livin' like Larry!
Doh! I should have thought of that instead of my elaborate ideas... That's what I did on my E46 when the power wire to the lock broke... Hopefully the OP waited for your suggestions instead of taking mine! Sorry OP!
Old 05-24-2012, 07:50 PM
Garticus Garticus is offline
A -n- P
Mein Auto: E90
When my battery died....even the key in the trunk unlock keyhole did not work as even when you use the key it actuates electrically.
When I tried to get a jump.....once I connected the jumper cables under the hood I was able to open the trunk via the key fob\under dash button or the trunk handle itself. (my car neither has the fold down seat nor the ski pass-thru option)
G14 Classified Tech
Old 05-25-2012, 08:43 AM
Hidden Key
Easy solution. I did not know about the hidden key in the fob. The trunk is open and the battery is replaced. Thanks.
Old 05-25-2012, 06:43 PM
jelliotlevy jelliotlevy is offline
Mein Auto: 2011BMW 335i, Honda S2000
Thumbs down
That won't work on 2011 335i. There is no key slot in the trunk.
