BMW Coding and Programming
Discuss coding options and features on your BMW here. |
I am getting a sense of Déjà vu here.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
@DreamCar, feel free to add my name to the helpers ... I'm in Chicago, IL and have been able to code everything on this list except SLI and HUD because I don't have them, but it should be straightforward enough.
- 2013 X5 35i Sport Activity (Born 08/12) - Titanium Silver /Oyster Nevada /Dark Bamboo - ZCV /ZCW /ZPS /Sport Package /Adaptive Drive /Soft-Close Doors/Running Boards /HUD /Shift Paddles /Comfort Seats /6NR /6NF - 2011 535i (Born 08/10) - Titanium Silver /Black Dakota /Anthracite - ZCV /ZCW /ZPP /ZP2 /6FL /6NF (Sold 08/12) - 2010 335i (Born 02/10) - Titanium Silver /Black Dakota - ZCW /ZPP /6FL (Sold 09/10) - 2007 328i (Born 07/07) - Jet Black /Black Dakota - ZSP /ZPP /6FL (Sold 04/10) |
Epic
Dreamcar, add me to the list I can help people install everything or help them get started . I'm at St. Louis, MO.
@dreamcar,
I can code/help with set up in Birmingham, AL...please add to the list. |
Hi,
I have a 2011 F02 and would like to know if you would be willing to code some functions for my car. (delete seatbelt warning, nav acceptance screen, DVD in motion, and key fob closing of window/folding mirror.) Thanks In advance for your reply! I will be in Birmingham area this weekend, and go there quite often. Have a good day! Ming |
i can help in norcal area
One feature I'd love to disable is the comfort access locking by touching the ribbed portion of the door handle.
When I reach for the door handle, especially in a tight parking space, my hand naturally lands on the ribs, causing the door to lock. I never use the feature intentionally- I just reach in my pocket and press the fob to lock. I would like to keep the comfort unlock function intact if possible.Anyone have any ideas on what module or code area I could disable this in? Thanks! |
I'm in Sunnyvale would love to get your help on coding. New to Bimmerfest but been active on Bimmerpost. Will PM you . . .
sure i can help. do you need me to just code somethings for you? or do you want me to help with your setup so you can code?
contact me via email at byongpark at gmail what would you like coded? Byong. |
Thanks, I sent you an email. If you're willing to do the coding that would be great, though I wouldn't mind learning how myself.
I have some findings to share. Canadian 535i x-drive, build 25.01.2011 without NAV.
1. In "E-Sys - Getting Started Coding - Part 1.pdf" after step 9, the FA can be activated as it will stay that way and it will activate at the first attempt. No retries needed. 2. In "F10_CheatSheet_V3.0.pdf" for the following two values: - KOMFORTSCHLIESSUNG_FB - KOMFORTSCHLIESSUNG_PA The default values given are nicht_aktiv / Werte=00 but on my car the values I did find were nicht_aktiv / Werte=01. I did try three times to program these two with aktiv / Werte=01 and won't work. What worked for both is aktiv / Werte=00. 3 For cars without NAV to turn off the iDrive disclaimer, the module is called HU_CHAMP instead of HU_CIC Maybe specify somewhere that for reading and writing the modified values to the car, the car is safer be on with the engine running. Also one has to go by module. Read it, save it, modify whatever needed and code it. Then move on to another module if needed. The idea is you don't have to code each value by itself. Only each module. You can add me to the "Volunteers" list as gicamuci (Montreal)
Regards, Alex 2012 w204 Mercedes-Benz C350 4MATIC MY 05/2012 Black/Sahara 2011 F10 535i xDrive MY 01/2011 Sophisto Grey/Black Last edited by gicamuci; 06-24-2012 at 05:01 AM. |
Guys we have entire forum for us... please create a seperate threads.... and you have more visisbility for your question
I see the 3001 TELEPHONE_PARAMETER, but am unsure how to get the MP3 to the car. Last edited by wnrussell; 08-04-2012 at 07:29 PM. |
I haven't messed with it, but I assumed that with 3001 TELEPHONE_PARAMETER / INBAND_RINGING, the ring tone of the phone was streamed via Bluetooth.
You can find this and many other settings in available cheat sheets, please go through them and pickup what you like.
I'd be willing to help others code in MA.
I was able to successfully code my car yesterday. Thanks to the help of DreamCar and the other members of the forum!
I coded: Window/moonroof close on fob and door ridges. Trunk close on cabin button and fob. Auto high beams on by default with headlights. Fog lights and high beams on at the same time. iDrive warnings off (camera & navigation). Seat belt warnings at 1 chime instead of 90 seconds of chiming. Front windows continue to roll up with opening of door. Side view cameras at all speeds. Tire pressure monitor show psi and temp. DVD in motion. Doors unlock on engine off. I am no expert as I have only done my own car. But I have the software and the enet cable, so put me down for being able to assist with coding in the Philadelphia/South Jersey area. Last edited by harrisfb; 06-08-2012 at 09:48 AM. |
Hit a Roadblock - HELP
I got everything set up, I see the IP address for my car and the VIN shows up in ZGW.
I open E-Sys and when I hit connect get the pop up which has my VIN next to that radio buttion, but nothing shows up in the Target box. Any thoughts on what I'm doing wrong? TIA DLM
"...hovering like a fly waiting for a windshield on the freeway..." p.g. |
http://www.bimmerfest.com/forums/sho...postcount=1453 Sean Last edited by ImSW1; 06-07-2012 at 10:15 AM. |
yup i had the same problem but i was missing the dist folders. |
#25
Not me. I had the dist folders, but managed to put the whlole data set in the wrong sub-folder.
FWIW DLM
