Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 06-02-2012, 09:53 PM
r.snook11 r.snook11 is offline
Mein Auto: e39 M5
Car turns off when "h0t"
I have a 2001 m5 and after driving it for a while and normally when its hot outside if i turn it off and attempt to turn it on it will turn over than shut off instantly and i have to wait for 15-20 min before it will start again. Any ideas??? Would grately appreciate it .
Sent from my PG86100 using Bimmer App
Old 06-13-2012, 10:23 PM
ard ard is offline
Resident Curmudgeon
there is a fellow oevr on m5board.com current troubleshooting this issue...Fuel pump or filter related.... check it out
Old 06-13-2012, 10:31 PM
Mein Auto: e39 M5
Thank you I appreciate it...
Old 09-29-2012, 11:17 PM
///fast5 ///fast5 is offline
Mein Auto: e39 Bmw M5, e46 Bmw 330i
Most likely fuel pump issue check pressure when its cold and check back when its hot. If you read the same then look for something else. If it different replace the pump
