7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
Alpina B7 supercharger chirping/pulley wobble - clutch/bearings
Car: 2007 Alpina B7 / 70k miles
Relevant history: Centrifugal clutch on supercharger replaced around 26k miles several years ago. Symptoms: Since I bought car a week ago there has been a metal-on-metal chirping. It has gotten more frequent with each day, then a few mornings ago it sounded HORRIBLE, like an index card in your bicycle spokes. I pulled off a small cover and saw the supercharger pulley wobbling in time with the chirps and clangs. So, I started pulling it apart. Pictures and descriptions are in the link below, but I'll describe a little bit here, too. Normal centrifugal clutch operation: (a more comprehensive training document on the Alpina B7 can be found on BMWTIS.com / BmwTechInfo.com) The belt-driven pulley is bound to the inside portion of the supercharger's clutching mechanism, which can be best described as drum brakes where the outside belt-driven pulley acts like an axle or wheel, which normally spins freely. Once the pulley spins up to about 1,100 rpm, the centrifugal force begins to push the clutch shoes out against the "drum", beginning to lock them together. This inner "drum" is what actually spins the supercharger. Problems that I've seen so far: In my pictures you can see that while the centrifugal clutch shoes have plenty of life left on them, a ball bearing and spring have come out of place. These normally help keep proper spacing between the metal pulleys, plates, and clutching components. In addition, there is an inner bearing or spacer that the pulley and clutch assembly rotate on. This bearing was fairly stiff when attempting to wiggle at any angle but one. The bearing wiggle at this one sloppy angle definitely caused the scoring seen in the various pulleys and plates. Resolution / fix: I ordered some sort of unlisted supercharger / radial compressor clutch rebuild kit from a local dealer, part number 11-6-57-973-081, for around $952 after taxes. They did not have any diagrams for this, so they could not confirm that it had the parts I needed, but they believed this to be what I needed and got the part number from the supercharger clutch recall repair previously done at 26k miles. I will post more pictures and info about this once the kit comes in. Kit came in and DID include all parts needed. Used gear-puller tool included in kit to pull clutch/bearing off and press the new assembly back on...process was fairly smooth. Time required: Took one evening going very slowly and taking lots of pictures. See pictures, videos, basic steps, descriptions --> here.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... Last edited by Keif; 06-09-2012 at 03:20 PM. |
Labeling / descriptions on pictures and videos complete. Supercharger working perfectly now.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... Last edited by Keif; 06-08-2012 at 10:56 PM. |
I love reading posts like this. Not that I would even ATTEMPT to do something THIS detailed but I guess I'm a sucker for happy endings when it comes to an issue most would chalk up to "NEVER TRYING THIS DIY DEAL..." which is sort of me.
Thanks for posting. -lendog
07 BMW 750LI - daily driver, pride & joy & an 04 Jeep Rubicon- rock crawler & overpriced hobby. |
Very well done, Keif - this just happened to my B7, almost at identical mileage and with the same issues. Fortunately warranty is replacing the entire supercharger, but great to know that a full replacement is not always necessary in the future. Very nice detailed step-by-step pics and vids!
![]() Maserati GT 4.2 Range Rover 4.4 Dodge Ram 1500 PAST: ALPINA B7, e63, e39, e39, e36 |
Gracias! =]
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
| Tags |
| alpina, b7, clutch, radial compressor, supercharger |
