1991 850i eml light - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 8 Series - E31 (1989 - 1999)
Old 06-12-2012, 12:35 PM
wharpermd wharpermd is offline
Mein Auto: 850i
1991 850i eml light
sometimes my 1991 850i will crank and run rough when the eml light stays on. cut it off and recrank until eml light stays off and runs smooth as silk. someone said something about throttle position sensor. does anyone know or have advice?
Old 06-12-2012, 01:19 PM
TxGr8White TxGr8White is offline
Sick Puppy Motorwerks
Mein Auto: BMW 850Ci
DK motors are probably needing a refurb - common problem with these cars.
White 1993 850Ci - 251,187 miles
Black 1993 850Ci - 125,508 miles
Old 06-15-2012, 01:01 PM
Mein Auto: 850i
do you know anything about throttle position sensor?
Old 06-15-2012, 02:49 PM
There is really no such thing by itself. The throttle positon is determined by the wiper arm within the DK motors. They send back signal voltage to the individual DME's which in turn is interpreted by the EML. The EML makes sure that both "halves" of the engine are in sync with each other. The EML light can indicate that one side of the motor is not keeping up with the other. This can be a number of things:
- DK motor getting hung up, or sticking
- O2 Sensor failure
- DME failure
- Fuel pump failure on that side
- Distributor cap/rotor faulty
- MAF faulty
- Intake gasket leak
- FPR failure
- CPS failure
- Impulse sender failure
As you can see, you will first need to try and narrow it down. Which side of the motor is not running? You can tell by which exhaust is cooler than the other after a few minutes of running. Also note that from the front of the car where the air enetrs each side until you get to the individual head, the left side feeds the right and vice versa. Once the air/fuel is in the head, then left is left and right is right. In other words, if your drivers side exhaust is cold, then you might have MAF, DK motor, or intake gasket probl;ems on the right side of the engine.
Let us know what you find.
Good luck
Old 06-21-2012, 09:12 AM
Mein Auto: 850i
DK motors 850i
does the intermittency of the problem mean anything to you? usually after it cranks and runs smoothly, it does not happen again that day no matter how many times you crank it.
Old 05-03-2017, 02:08 PM
Roland Johnsen Roland Johnsen is offline
Mein Auto: BMW 850
It is the throttle motors, one runs and the other does not, it is easy to see,
open the hood and have engine running with eml light on
step on gas and look on the throttle motors, one moves the other one does not.
Roland johnsen
Old 07-07-2016, 09:09 AM
Retired777 Retired777 is offline
Mein Auto: BMW 850i
E31 M70 EML Synchronizing
Good morning E31's
I have been working on my 850i and disconnected the batteries.
The batteries were disconnected for 1 week; I have been told that now the EML's will need to be synchronized as they would have 'lost their memory'.... any ideas how to re-sync. the units?
Eric
Keep the shiny side up
Old 07-14-2016, 02:27 PM
adwebinc adwebinc is offline
It's Bimmer, not BEEEEMER
Mein Auto: '01 750 | '91 850 | '00 5
Originally Posted by Retired777 View Post
Good morning E31's
Eric
Sorry... the e31 board here is not frequented often. The bimmer forums board has a specialty group for e31s.
Are you talking about synchronizing your DK motors? If so, most people say that you can just drive the car around like normal and they will ultimately adjust. There is a specific DK sync process (do a google search for that) that I have tried, but I didn't notice any particular difference from just driving the car around.
'02 e46|M54 - Orient Blue|Beige|'Vert
'00 e39|M52 - Anthrazit Metallic|Grey
'01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line
'91 e31|M70 - Schwarz|Schwarz|M70
'13 328i Auto - Black Sapphire|Coral Red|Sport Line|Premium|CWP|GONE
'05 545i SMG - Jet Black|Black|Bamboo Anthracite|NAV|LOGIC7|Sport|Premium|Comfort Seats|CWP|GONE
'07 335i Auto - Montego Blue|Grey|Premium|CWP|GONE
'05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|NAV|Sport|CWP |GONE
'97 528i Auto - GONE
Old 07-15-2016, 09:12 AM
Mein Auto: BMW 850i
Hi adwebinc
Thank's for the reply...
I have also been told that just driving around normally would re-synch the DK's and the EML's.
After I replaced all the hydraulic lifters, stripped down and did a major clean of the DK motor's and throttle bodies, this is what I did:
I found a process that appears to be from some kind of service manual in which you need to: "'Start the car, let engine idle up to operating temperature, then select 1st gear and gradually drive up to about 5500-6000 rpm (just below redlining) then let the car coast down to idle... repeat again a couple of times". I did this on a long quiet country road. The car now drives very smoothly and is very responsive. I don't know if this is due to the above process or what...but I thought I would share it with the E31 brigade.
Now I would like to find a program that I can use on my laptop that will 'talk' to the 850 V12 and not just code read. Any suggestion's?
Old 07-15-2016, 07:38 PM
1991 850i eml light
Hi adwebinc
Yes, that's it! That is the "official" DK sync process. So sounds like it worked for you.
There is a process you can use to add the INPA and dis official BMW software to a laptop to read and code the 850 DMEs and EML. However, the best performing set up is an older Dell or IBM with an actual serial port and dedicated to just the diagnostics to avoid software conflicts. You will also need the special 20 pin diagnostic head of course. I bought mine prebuilt off eBay for a couple hundred bucks, but many have success building it themselves.
I also saw a referral to this set up yesterday (have to find link).
Here it is - http://www.bcables.com
Sent from my iPad using Tapatalk
Old 05-03-2017, 02:40 PM
Mein Auto: BMW 850
Hi adwebinc
First gear at 5000 rpm for a half mile that what BMW in Sweden told me,
I did that, and no problems.
Roland Johnsen
Old 05-03-2017, 02:34 PM
Mein Auto: BMW 850
Good morning E31's
Eric
Put car in first gear, run car in first gear at 5000 rpm for a half mile, throttle motars should be sync.
Roland Johnsen
Old 07-16-2016, 10:34 AM
Wuffer Wuffer is offline
Mein Auto: 91 850i
Where in Canada? If in BC, I have BMW Diagnostic Software on a laptop in Langley and would be happy to assist. Visit www.wuffer.ca
Cheers,
Tom
wuffer at shaw dot ca
Old 07-26-2016, 10:51 PM
Mein Auto: BMW 850i
Hi ADWEBINC and WUFFER,
I also have an old laptop but it does not have a serial (RS232) port. A few years ago I purchased an interface which has the 20 pin BMR adapter that is connected to a box of electronics which has the serial cable. I also have a 20 pin to OBD2. This all came with CARSOFT V6.5. As my old laptop does not have the RS232 I never did get a chance to use the unit so don't even know if it will talk to the 850!!
The software 'how to manual' suggests I use a PCMCIA to serial adapter and not serial to USB as this would not work. Now...has anyone out there had any success with the USB adapter and CARSOFT or even using the 20 pin to OBD2...does the OBD2 reader able to talk to the 850 or does it use a different protocol?
Soooo many questions??
BTW Wuffer..its me.. the Princeton guy with a red 850 that has the steering wheel ...on the other side!?
Old 05-03-2017, 02:03 PM
Mein Auto: BMW 850
I took the throtle motors of the engine, apart very careful, cleaned the grit and oil deposits out
reassembled and put them back in, Car run OK, after cleaning, they have to be syncronised
in car, run car on first gear for a half mile at 5000 rpm, that what BMW Sweden told me,
No problems after that, I have 3 throttle motors just in case, seems to be a common problem
with the 850 Roland Johnsen
