Old 06-11-2012, 03:18 AM
gspannu gspannu is offline
Mein Auto: F10 2015 Model
Retrofitting Lane Departure Warning
Originally Posted by miotoo View Post
So for EU F10 owners who do have LDW (ie blessed with KAFAS module+camera) seems the conclusion is that using the settings from the cheat sheet will in fact enable SLI properly for them.
Wish there was someone here who could confirm this.
Wonder also what's in that retrofit box. Probably only coding then.
@Dream KAFAS2 is a different module, probably 66519271195. How can it help us? Maybe we can read the FDL settings from one who has it say in the F30?
I have access to a UK 2012 model F10 that I have just started programming. I am still waiting for my own car to arrive in a couple of weeks time.
The referred car has SLI, High Beam Auto & HUD but does not have LDW. I believe the camera is still the same (as it is required by SLI). SLI works like a charm - almost 99% accurate on UK roads.
Let me know if you want me to read settings from this car - just guide me into what you want done and I'll post the files. I am still a bit of newbie but happy to help out.
My project is to get LDW working (as reading from your/ DreamCar/ others efforts on SLI) - I think it may be possible to get LDW working as they all share the same hardware camera.
Old 06-11-2012, 03:51 PM
DrHorsey DrHorsey is offline
Mein Auto: MY2013 F25 X3 35d MSport
@gspannu, funny you should be considering this ...
I just got a MY2013 F25 with SLI but not LDW …
… I didn’t want LDW, but its only now I see the user guide that I discover that LDW come with Forward Alert, which I would have taken the option for if only the sales associate had known or mentioned it.
I am also left wondering if LDW and Forward Alert are coding option on the same hardware used for SPI.
Of course, the steering wheel wont vibrate for LDW, and there is the small issue of the activation buttons on the dash, but none the less, if I could enable Forward Alert, I would be interested to see how this could be done …
Old 06-11-2012, 06:38 PM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: F10 M5
GSPannu,
Thanks for the files...
I dont see any difference between these and Mobilieum's (I assuming this will be case for all EU countries).
So enabling SLI in EU countries on cars with LDW should be a breeze.
And regarding the question you posted for me in the other forum...
We gotta check if we can activate the LDW with out the hard switch or if we can default the LDW to be "on" like HBA .
Old 06-12-2012, 12:20 AM
@DreamCar, it's been mentioned that LDW needs special rear sensors ... What for?
Do you know if the Forward Warning uses anything other than the camera?
On a side note, does the front camera have a video out anywhere? I was thinking of getting one of those loop recording dash cameras in case of an "event".
Would be handy for the front facing camera to keep a loop of video prior to an accident or something. Failing that maybe it can be wired into a recording device...
F25 X3 xDrive 35d M Sport Alpine White, Black Nevada Leather, Speed limit info, TV, Prof. Nav & Speakers, HUD, M Sport steering wheel, Sport gearbox, BMW Apps, Internet, VDC, Comfort with Powered boot, Hi-speed synch, VSS, Top View, Electric tow-bar, Heated steering, Storage, DAB, Heated electric seats, Moonroof, Adaptive High beam assist Xenons, Servotronic, Performance control, etc. http://x3orevoque.co.uk
Old 06-12-2012, 02:16 AM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Ok I was only referring to lane departure warning not the the lane change warning I think rear sensors are required for lane change warning aka blind spot detection?
Well thats what I think , I may be wrong.
Old 06-12-2012, 04:21 AM
mjgood mjgood is offline
Mein Auto: 2011 550i M-Sport
I think you're correct... front camera for LDW, rear sensors for blind spot...
I thought the side sensors were used as well for blind spot, it doesn't seem they are since the cars aren't picked up until they are in range of the rear sensor... guess the side sensors are for parking assist..
2011 550i M-Sport
2011 Countryman S
Bell 407
Old 06-12-2012, 04:59 AM
Hi,
Now that you have the reference files from my car; and it seems that I may not need the rear sensors (hardware) - it should now be trying out 2 things:
1. Enabling LDW
2. Getting the LDW to be 'Always ON' - as there is no physical switch for the same.
Any idea what changes I should try to get LDW working?
As mentioned earlier; I have Speed Limit Info and Head Lamp Assist as factory standard.
Can you advise which key functions/ values to try and modify?
Much appreciated….
Old 06-12-2012, 07:32 AM
akiss akiss is offline
Mein Auto: 2016 MINI F54 Cooper S
Hi,
1. Enabling LDW
Much appreciated….
Beside that you'll need a NEW steering wheel as the one for LDW has a different part number and so won't feed the vibrations with the "old" one - already tried.
Andy
Old 06-12-2012, 07:37 AM
miotoo miotoo is offline
Mein Auto: F10 520d
Andy
Hello Andy, when you say you tried, you mean the LDW worked & the missing action was only the steering vibration? Did you get the warning light in the kombi to show?
F10 520d Deep Sea Blue 11.04.2011/16:24
Retrofitted:
5DF Active Cruise Control with Stop & Go incl. Collision Warning with Brake Function /ver. 1
2TB DEC Switch for Normal / Sport / Sport+ Writeup: http://www.bimmerfest.com/forums/sho...d.php?t=685869
8TH SLI Speed Limit Info / KAFAS 1
5AD LDW Lane Departure Warning / KAFAS 1
319 Universal Garage Door Opener
6WA Instrument Cluster with Extended Contents
Old 06-12-2012, 07:45 AM
Hi,
1. Enabling LDW
Much appreciated….
Correct, I did you the indicators in the KOMBI but the vibration was missing - the part sell for more than EUR 400...
Andy
Old 06-12-2012, 09:19 AM
Mein Auto: F10 520d
Andy
Vibration generator is part 32336787451 for standard steering wheel. 74 Euro. Maybe new wiring is needed to pass the signal..
Retrofitted:
Old 06-12-2012, 06:14 AM
Mein Auto: F10 520d
@gspanuu there are cafd files from @mobileum in the old thread http://www.bimmerfest.com/forums/sho...d.php?t=619819, his car is EU build and if I'm not mistaken has all 3 options LDW HBA SLI so comparing your files to his should be a good way forward for you.
I can't seem to find that post at the moment, but if no one gets to it, later I can post the files as I have them at home..
Retrofitted:
Old 06-12-2012, 06:16 AM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Hi,
1. Enabling LDW
Much appreciated….
Obviously KAFAS, HU-CIC ... I need to check in detail to be sure.
Old 06-12-2012, 12:17 PM
Mein Auto: F10 520d
@gspanuu these are the KOMBI, HU_CIC & KAFAS files from a EU car with SLI & LDW.
In the FDL editor, search for TLC entries which is the code for the Lane Depart Warning system.
Retrofitted:
Old 06-12-2012, 12:34 PM
You need to code the steering wheel ECU SZL_LWS too!
3000, Lenkrad_Vibration
Andy
Old 06-12-2012, 06:54 PM
Sharbotcom Sharbotcom is offline
Mein Auto: F10 535xi MSport
I am Ivory Pure (99.44%) sure that the Blind Spot Warning is only the side sensors. The pointing of the sensor allows it to pick up objects adjacent and behind it.
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, M Sport Package, 316, 322, 3AG, 5AD, 5AG, 5DL, 609, 620, 655, 677, 6FL delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
Old 06-13-2012, 04:56 PM
@miotoo @akiss @dreamcar
Great suggestions guys, I'm out until Sunday. Will give these a go on Sun or Mon evening and report back.
Even if I get the warning to light up in dashboard, would be a good start; I can worry about the steering vibration later.
Side question: How would I enable this permanently as I do not have a switch on/off button for LDW?
@akiss: Since you have already achieved this...
1. do you happen to remember the exact settings changed/ documented anywhere? Saves me the hassle of going through the files line by line & comparing.
2. How did you manage without the physical switch?
Old 06-13-2012, 06:37 PM
svache's Avatar
svache svache is offline
Mein Auto: 2012 F30 328i
Do you have buttons at all below your light switches? If so, it's possible your car is pre-wired and then you would just need a new switch
'12 F30 328i w/ A17, LCLY, ZLL/7S2, ZCW, ZDA, ZPK, ZPP, ZPS, ZTP, 205, 2VL, 302, 3DZ, 415, 417, 522, 524, 5AC, 5AP, 5DP, 615, 6AA, 6AB, 6NF, 6NL, 6NR, 6UH, 6VA, 6WA, 8S4, 8TH (yes, that's all lol)
Retired: '09 E70 X5, '04 E46 M3
Old 06-13-2012, 09:47 PM
Yes, I do have a switch below my light switches. I have the HUD switch, but that's the only one...
Old 06-13-2012, 09:57 PM
svache's Avatar
ic.. chances are that it is pre-wired but you'll have to check that
Old 06-19-2012, 12:16 PM
Hi,
I didn't document all my coding for LDW but here's what I remember, I do have SLI from factory:
KAFAS:
3000, TLC_START_VERSION, default_on
3000, TLC_ON_OFF, aktiv
3000, SEND_MESSAGE_327, aktiv
3000, SEND_MESSAGE_345, aktiv
3006, ACTUATOR_ON_OFF, aktiv
KOMBI:
3003, TLC_VERBAUT, aktiv
3004, ST_TLC_TIMEOUT, aktiv
3004, ST_TLC_ALIVE, aktiv
3004, ST_TLC_APPL, aktiv
HU_CIC:
3001, LANE_DEPARTURE_WARNING, aktiv
SZL_LWS:
3000, Lenkrad_Vibration, aktiv
So, this seems to be all I changed for LDW. Hope this helps someone else here.
Andy
Old 06-19-2012, 12:37 PM
Hi,
KAFAS:
KOMBI:
HU_CIC:
SZL_LWS:
Andy
@akiss: Awesome feedback. Thanks a ton.
Another query: I hope I will not need the physical switch and LDW is activated as default ON.
Old 06-19-2012, 02:48 PM
Yes, it's always ON if you set this, the default is to remember the last setting but without a switch...
KAFAS:
Andy
Old 06-19-2012, 02:57 PM
KAFAS:
Andy
You are awesome, Andy.... Thanks a ton. I'll code this in the next couple of days and then confirm back.
Q: Do you get the steering vibration or just the Heads-up message?
Q: I believe coding the KOMBI generates an error code - any idea how to clear this?
Old 06-19-2012, 03:00 PM
akiss, how on earth do you work out what was required ... I mean some of the things might leand one to the possibility ... but what inspired you to enable SEND_MESSAGE_327 and SEND_MESSAGE_345?
I have an F25 with factory SLI & HBA, and I would like to enable Forward Warning (which is probably more useful to me than LDW).
Any suggestions?
No steering vibration as a do not have the right wheel
Coding the KAFAS module first and KOMBI afterwards could reduce the problem with an error on coding, I did get one as I coded KOMBI first and LDW was not active in KAFAS first.
Andy
