Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 06-25-2012, 11:50 PM
Konfucious Konfucious is offline
Mein Auto: 2008 BMW M3 Convertible
Unhappy Need brakes and maintenance program expired
So I go to the dealership yesterday because my brake lights come on... Come to find out my maintenance program expired a couple weeks ago.
I drive a 2008 m3 convertible with 37k miles on it and replaced the front brake pads not too long ago.
The dealership is quoting me thousands to fix the rear brakes and of course wants me to shell out 4k for two years maintenance program and another 5k for the additional warranty or trade in my baby for a new ride and more debt.
How much are rear brakes to replace and how much for rotors if needed at the local BMW private garage?
Old 06-28-2012, 08:34 PM
bigugly fab bigugly fab is offline
Dr.BMW
Mein Auto: 2015 M4
Rotors are about 300/each, pads (oem) like 200ish IIRC.
Measure the rotors to see if they need to be replaced. Put some akibono ceramics on there for street duty.
Old 06-29-2012, 10:36 AM
rdollie rdollie is offline
Mein Auto: Mostly Euro sedans
Just did a quick search at RockAuto and found:
A set of front and rear Akebono ceramic pads will cost $147 and rotors are all over the place but a set for cross-drilled 'high performance' rotors can be as low as $1185 for all 4 corners so you're looking at a little over $1,300 in parts plus tax and shipping. Then there's labor unless you do them yourself.
For comparison, when I was talked into the extended maintenance plan for this car (no regrets) I was told the price for new pads and rotors at the dealership is about $3,000! (The price for a non-M e9x was much lower.)
Old 06-29-2012, 11:13 AM
Dr.BMW
Mein Auto: 2015 M4
You aren't putting "less stock" rotors on there..,,, cross drilled floating rotors are going to be what you can put on there..... So look at 200-300 a rotor like I said
Old 06-29-2012, 11:41 AM
Yes, that $1185 price I mentioned is for front and rear OEM Centric cross-drilled rotors.
Old 06-29-2012, 11:46 AM
Dr.BMW
Mein Auto: 2015 M4
You sure you are looking up for e90, not e46?
brakes, m3, maintenance, rotors, warranty
