E39 528I Recomended Oil Change SOURCES! - Bimmerfest - BMW Forums
Old 06-26-2012, 01:31 PM
blackontan blackontan is offline
Mein Auto: 99 540i Sport Black/Sand
ive read the thread and heard alot of opinions my cars fancy oil and filter. I have come to find out the mann is one of the best filters and the mobile1 synthetic doesn't even meet standard bmw requirements..... last oil change used mobile1 and mann cause i didnt know where to get a German or any LL-03 oil locally? or can i? we have autozone, advanced auto, oreilys, carquest. thats about it, small town. Bay city, Mi 48706.
so my question is where do i simply buy my oil online (unless someone knows of a kind thats carried at above mentioned places)
i found this link:
http://www.ebay.com/itm/Liquimoly-5w...#ht_2953wt_952
$60 for what looks like German ll-03 and a mann filter. is this a good deal, can it be trusted, im tired of buying Chinese counterfeit Bs online and am afraid these manns my be or cheap oil.
where do i buy this stuff!
Old 06-26-2012, 02:05 PM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Mein Auto: 1998 BMW 528i
i am using castrol syntac with the bmw. mercedes yellow logo on it which supports bmw long life i believe. A friend of mine told me to check out rotella and motul so i might try one of those next.
Old 06-26-2012, 02:07 PM
bkgreene39's Avatar
oh yea try amazon for online
Old 06-26-2012, 04:39 PM
tmvE39/E53/Z32's Avatar
Mein Auto: Dinan //M5, Dinan 4.8iS,
Walmart has Mobil1 0w-40 that meet LL01. I use Mobile1 synthetic 5W-30 and change every 7.5K mi. No problem. Dont get too caught up with LL01.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 06-26-2012, 09:13 PM
isnt it suppose to be ll-03? is ll-01 better or similar.
Old 06-27-2012, 04:13 AM
Fudman's Avatar
Fudman Fudman is offline
The designation for oil is LL01. Do not worry about it unless you prefer to change your oil at the BMW recommended 15,000 mile intervals. If you do not race your car and replace your oil 7,500 m intervals or less, the oil designation does not mattter. Do a search. This is a much discussed topic. I fall in the "oil is oil" category.
Old 06-27-2012, 06:18 AM
WDRAcing WDRAcing is offline
Mein Auto: 99 540iA
Like Fudman said, oil is oil. The important part is actually changing it. Even conventional discount brand dino oil will work fine. The correct weight oil is more important then the brand.
Some oils ARE better then others, but if you're not racing AND change your oil often...well then buying boutique oil is for suckers imho. I drive my cars hard, so I buy expensive oil. I also change my oil filter mid way between fluid changes, just a habit I got into years back. Cheap and can't hurt anything.
Cheaper oils have less detergents and R&D put into them. Detergents help keep sludge to a minimum. However, changing your oil often removes the need for detergent heavy oil.
Walmart Supertech will work if you want a cheap synthetic. Just change it out every 4-5k.
Amsoil is the best fluid available, purchased online usually.
Just my .02
Old 06-27-2012, 08:23 AM
Fudman's Avatar
For those that need proof positive, simply look inside your valve cover. If you have that dark golden oil sheen on everything with no balck sludge buildup, all is good with whatever oil you are using and your change interval is adequate.
ID:	330810   Click image for larger version
Old 06-28-2012, 06:34 AM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
Mobil 1 0-40 has mine looking like Fudmans on the inside...enough proof for me to stick with it.
Old 09-10-2012, 06:04 PM
bschmidt25 bschmidt25 is offline
Mein Auto: '07 530xi, '01 525iT
+1
I'm not quite an "oil is oil" guy, but I do think that any good quality synthetic is fine as long as you're using the proper weight and change it every 7500 miles. I always use M1 0W-40 now though.
Old 06-28-2012, 06:47 AM
BigCo540i's Avatar
The Usual Suspect
I have used the STP filter in a pinch but normally I stick to WIX which is Nappa Gold.
Old 06-28-2012, 07:02 AM
bigugly fab bigugly fab is offline
Dr.BMW
Mein Auto: 2015 M4
Regardless, if you want to see if your oil is performing correctly, just Do an oil analyisis
Old 06-28-2012, 07:46 AM
fuzzynations fuzzynations is offline
Mein Auto: 1998 528i manual
Thanks for the heads up on the filter, I did a few searches and found the round o-ring gasket for the oil filter housing fails, and the inside of the filter has a weak seam allowing unfiltered oil to pass through.
doh me
Old 09-07-2012, 06:11 PM
In the end, I opted for the following oil change setup........
Liquimoly 5w30 Synthetic Longtime High Tech Oil Change Kit BMW E39 525i 528i
7 Liters Oil And Mann Oil Filter
http://www.ebay.com/itm/221019848413...84.m1439.l2649
WHY? My Personal thoughts?
This meets the requirements.
better than most options for brand name and purchase location, although i never heard of the brand.
made in germany.
sold by bravanian auto sport. They seem to be a big bimmer reseller.
the ease of clicking but it now once and forgetting about it.
it came with 7 liters as well as the mann filter.
not much more in price and sounds like everyone says i can run this to 7.5 or 10k easily (some say safely to 15k?, dealer says 15k with LL)
most importantly. the next time i need oil wont be for 10k and when its that time, i will buy it now again from brav autosports on ebay in 10 seconds and save myself hours or time doing this oil is oil research or time driving to the local autozone... also it arrived quickly and packaged well!
other thoughts.. i bought an extra mann filter. I will put it in at 5k or 7k thus more safely extending oil change interval to 10 or 15k and then doing the oil filter every 5 or 7k......
one last question... everyones saying 5, 10, 15k? Are we all talking miles or kilometers?? Im used to driving a gm and changing it every 3k with regular oil. i like the idea of only changing oil every 10k since everyone says its safe with good oil.
Old 09-08-2012, 07:17 AM
Change oil and filter on my BMWs every 7.5K miles.
Old 09-08-2012, 11:34 AM
motormouth motormouth is offline
Mein Auto: 2003 540i/6
I've been using M-1 High Mileage 10W30 mixed w/ 2 qts. 10W40 for 5 years with 3 BMWs. Available at Walmart for around $25 5qt. jug. I've had a couple analyses done at Blackstone with exceptional results, changing at 8K miles. The HM specs meet LL01, works great, and is the right price. Whats not to like?
Old 09-08-2012, 12:08 PM
AH673000 AH673000 is offline
Mein Auto: 1997 BMW 528i
Oil is oil..... Not really ...... Use synthetic ... Period ..... Why? For all the stated reasons plus one rarely mentioned..... It is cheap insurance if you loose your cooling system . Synthetic will not breakdown at elevated temperatures during this brief temperature excursion . It will save your engine when dyno oil will not . Personally I use Mobil 1 ...... In 30 years it has always resulted in the same outcome. Zero engine problems ..... Zero increase oil burn as mileage piles up . Current cars have > 150 k .
Many synthetics on the market . Mobil 1, Royal Purple , and Amsol are the only true Synthetics .. The rest are technically not syn but ultra refined dyno oils ...... So again oil is not oil . For a few pennies more.... Just stick with Mobil 1 ... And everybody has a Walmart store nearby. .... Right?
Old 09-08-2012, 10:53 PM
These are useful:
- Cn90 How to change your oil; and Bluebee how NOT to change your oil!
- How to choose the right motor oil for your E39 (by quality, cold-start, warm viscosity, slipperiness, and cost)
- You never get what you pay for ($18 Fram oil filter)
Old 09-11-2012, 08:56 AM
Originally Posted by AH673000 View Post
Oil is oil..... Not really ...... Use synthetic ... Period ..... Why? For all the stated reasons plus one rarely mentioned..... It is cheap insurance if you loose your cooling system . Synthetic will not breakdown at elevated temperatures during this brief temperature excursion . It will save your engine when dyno oil will not ......
NO oil can save your BMW engine from failing cooling system.
Old 09-11-2012, 09:42 AM
+1.
Just ask these people who lost their engines (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
Old 09-09-2012, 02:37 AM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/05 X5
Mobile1 is what I use in my bmw's and my 323i is working its way to 300,000 miles now and runs fine.
As long as you change the oil at reasonable intervals you will be fine. Ive got several other high mile vehicles 330k on my f250 with valvoline synthetic, over 500k on my wifes mercedes 190D turbo rotella for instance. Just change the oil and drive
Old 09-09-2012, 03:56 AM
radd radd is offline
Mein Auto: e39
i use aral 10w-40 since my e30, e34 and now e39. i dont know how easy to find aral in USA (when I lived there i drove a plymouth voyager, no need for german oils ).. but i kinda agree its not the brand but how you schedule oil changing
Old 10-13-2012, 12:01 PM
jp5touring jp5touring is offline
Mein Auto: 525i touring
I can get seven quarts of Mobil 1 0w-40 for like $ 45.00 A Mann filter online for under $ 5.00 I change it myself,,, Heck I enjoy changing it, I change it every five thousand miles or so.
Its Cheap relatively speaking. Overkill ? most likely. Why chance something that could cost so much to repair for so little savings in the long run ???
If people want to go 10k or even 15k between oil changes have at it. Oh when you go to sell your car make sure you state in used car ad
You changed the oil every 15k !! good luck with that..
Old 11-24-2012, 10:53 AM
Sonare Sonare is offline
Mein Auto: 2000 E39 touring
My E39 with 220k gets Syntec and a filter every 10k-- at the suggestion of my mechanic. He sees a few more cars than any of us, and when questioned he replied that his observations led to and justified his recommendation. And in a way, he sells oil- at retail. Lost profit!
Rich
Rich
2000 528it (5-sp manual, M52TU engine, 220k miles and going strong) Bimmer #13!
