Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 07-01-2012, 06:10 PM
iturk iturk is offline
Mein Auto: GTR, S65 AMG, RD Sport 46
FS: 2008-2011 BMW M3 E9X Brand New Supersprint Cat Delete & Resonator X-pipe 40 HP
$1349.00 + Actual shipping UPS ground from Zip 20176. If you have any questions please route through ebay. Thanks!
BRAND NEW, NEVER OPENED SuperSprint Connecting Pipes L & R (Cat Delete) & Resonated X-Pipe Exhaust System
This will increase power by 40 HP without any other modifications on your BMW M3. You can still pick up about another 15 HP from a cat back exhaust system but that is not what you are bidding on. Install is approximately 1.5 hours and can be changed back to stock easily by a performance shop that knows what they are doing.
I purchased this system from Supersprint and it came from Italy as there were not any in stock in the USA. It was going to go on my BMW E93 M3 but I ended up selling it for a Nissan GTR-35. I paid $2,600 NEW including shipping but you can get this for considerably less here (30-40% off). This exhaust system is BRAND NEW, STILL in BOX, NEVER OPENED, NEVER INSTALLED. They will ship in two boxes and will ship from Zipcode 20176.
This will increase power by 40 HP. Your other option is to go with Turner Motorsports Cat delete for $400 but they have been out of stock and on back order for 6 months. In addition without a resonator your car will sound VERY loud, raspy and non-discreet. This is why I went with this system but I ended up selling the car show above last month.
Resonated X-Pipe
http://www.supersprintna.com/product...earch_model/87
Resonated X-Pipe
All Supersprint resonators are of the flow through resonated design. This means each unit has no chambers or baffles to reduce velocity. Simply, a straight through in & out design! The internal components are 100% stainless steel with a high heat resistant rock wool sound suppressing material, not found in any other systems. This is the reason we can offer you sound legal performance exhaust systems. Tubing is always mandrel bent for maximum flow. Flanges and hangers are O.E. or better quality for a perfect fit every time. Housings are all manufactured from 1.5mm material that is M.I.G. welded at all seams. The stainless systems are 100% 304 stainless, the mild steel systems are aluminized on the inside and out, then black heat coated for corrosion prevention.
Note: Must be installed as a kit with 022 980 702 and 022 980 722 Metallic Cats OR 022 980 712 Cat Delete Pipes.
MSRP $1,759.47
Your Price: $1,466.22
These are alternative pipes for the metallic race cats 022 980 702 and 022 980 722. Piping diameter is twin 65mm and it is maintained constant all the way to the rear muffler connections. Once again there are no crushed sections in the tubing as with the factory system for clearance. In place of the factory quad cat design Supersprint has designed 2 straight pipes for race track or export purposes only.
Legal only for racing vehicles which may never be used upon a highway. Not applicable or intended for street or highway use.
Note: Must be installed as a kit with 022 980 703 or 022 980 713. Replaces factory catalytic converters.
MSRP $896.88
Your Price: $747.40
Buyer Pays actual shipping from Zip-code 20176 which will be determined based on zip-code of winning auction. Will only ship to 48 Continental United States. All sales are final.
Posted with eBay Mobile
