Old 07-14-2012, 06:24 PM
tribecaX5 tribecaX5 is offline
Mein Auto: '11 X5 35d
Difference between 18" vs. 20" wheels?
I am looking to potentially replace the 18" wheels on 35d with 20" Oem wheels and tires (rf) and I am just wondering, how different will be the ride in terms of performance and comfort. My wheel switch will be solely for aesthetics purposes as I love the big wheels and wide tire look. Anyone who have actually done this switch?
Old 07-14-2012, 09:46 PM
RPsX5d RPsX5d is offline
Mein Auto: X5 Diesel xDrive35d
A few things to keep in mind . . . I have Option 214 . . .
  • improved handling but a harsher ride . . . not only is your sidewall getting shorter (less shock absorption) you are also switching from non-RFT to RFT
  • you will need the fender flare (assuming you don't have one now) . . . without it your tire will stick out
  • Non RFT tires lasts much longer than RFT.
  • Assuming you mimic Option 214 - these have staggered tire configuration, therefore cannot rotate tires
  • If you experience serious winter, you will need to keep your 18" set as winter tires
  • Yes IMO wider tires look great.
If you are doing this only for aesthetic reasons, you may want to consider 20" non-RFT . . . or a 19" with about the same width. These options should give less harsh ride.
Old 07-15-2012, 07:33 AM
Thanks for your input. The 18" are run flats. I do not have the fender flares but I looked it up and they're about $300-350.
Winter in NYC is not bad. We get snowed maybe twice, three times a winter plus snow gets removed right away, so that's not an issue.
Let's see. If it costs too much then I'll just stick with 18"s. Thanks again.
Old 07-15-2012, 08:04 AM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: '11 X5d
The 20s are going to get ruined in NYC within a couple days
I really wanted them, but I gave up the awesome looking wheels because tire replacement costs are ridiculous and the roads suck in the Northeast
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather
Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production
Old 07-18-2012, 10:23 PM
Aqua Bliss Aqua Bliss is offline
Mein Auto: e92
I replaced my 18's with 20's... love ride on 20's vs. 18's, but then again I'm in OC, Cali where the roads are nice and smooth.
Old 07-21-2012, 04:30 PM
CALLAWAY845 CALLAWAY845 is offline
Mein Auto: 2007 x5 3.0...2009 328i
I really dont think fender flares are needed with the 20 inch rim. The back tires stick out only slightly, and the fronts do not stick out at all.
Old 07-21-2012, 05:31 PM
Talstar Talstar is offline
Mein Auto: '12 X5 35D White
I get more comments on the 20s than anything else. Really sets the X5 off.
2012 white X5 D
Retired: Space grey 2011 335D
Old 07-21-2012, 08:20 PM
Mein Auto: e92
This is a subtle thing but it's a huge difference visually. Looking at the X from behind or at 3/4 view, it just makes the whole vehicle look wider and stronger with the flares.
You probably spent over $50k+ for this vehicle, spend the extra few hundred bucks and make it look right.
