Old 07-17-2012, 09:00 PM
zmao zmao is offline
Mein Auto: BMW X3
2013 BMW X3 Memory Seat
Hi, I received my 2013 BMW X3 three weeks ago and got confused about how its memory seat works. After I set my position to button 1, do I need to manually press that button every time I unlock the car (assuming someone else drove the car last time)? How can it be automatically called up every time I unlock it using my remote? I tried several times but seems like it doesn't work that way. I have to press that button.
I also have an Acura TL which will automatically reset the seat to my position every time I open the door using my remote. Your answer will be much appreciated! Thanks.
Old 07-17-2012, 09:29 PM
valeram valeram is offline
Mein Auto: E92 M3 using ED
Just use the same key that you used when you program the seat and mirrors.
Old 07-18-2012, 05:33 AM
lbjgh's Avatar
lbjgh lbjgh is offline
Mein Auto: 2013 X3 M-Sport
Once you have all of the setting (seat, mirror, pre-set buttons the way you like it) exit the car and lock the car with the remote. Like valeram said just unlock using the same set of keys.
Old 07-18-2012, 06:31 AM
Wabbajack Wabbajack is offline
Mein Auto: 2013 X3 35i
Also set a Profile for yourself in iDrive for all your other custom settings.
Old 07-18-2012, 07:20 AM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
The memory seat in this thing is dumb.
It doesn't work like past BMW's - I can't figure it out either, although honestly I haven't tried very hard.
Old 07-18-2012, 04:37 PM
Mein Auto: BMW X3
Thank you very much! I followed all you guys said but the seat still doesn't automatically reset when open the door using my remote. still need to press button 1 for my position.
Old 07-18-2012, 05:02 PM
siddi siddi is offline
Mein Auto: BMW 2013 X3 28i
Settings
Page 33 of the user manual has an option you need to set in your personal profile: "Driver's seat position: automatically retrieved
after unlocking."
I think you need to enable it.
Old 07-19-2012, 07:18 AM
Yep. It's all about the profiles on these cars.
Old 07-19-2012, 07:42 PM
Mein Auto: BMW X3
Thank you all for your help! Finally, I talked to my BMW delivery specialist and here's the answer: the key always memorizes your last position (if this option is checked off in your iDrive). The memory buttons on the driver seat is the secondary memory which memorizes your position which may not be your last position. You can also set up your profile with your seat position and other stuff and call it up from the screen. Sounds awfully complicated, doesn't it? Thanks again!
Old 09-11-2012, 06:41 PM
Stephan Franz Stephan Franz is offline
Mein Auto: 2013 X3 xdrive 28i
Thanks ... picked mine up yesterday and this is driving me crazy ... will try your solution.
Old 09-15-2012, 06:21 PM
plancktimebmw plancktimebmw is offline
Mein Auto: X3 28i
same here- it is quite simple on my 3, but for whatever reason, when I go get in my wife's x3(she is 5'2 and i am 6'2), So, I usually begin to enter, expecting the seat to have set while I unlocked it(as in the 3), but alas, get a knee adjustment etc and then I remember to press the seat memory(hold) and I'm good to go; I think it used to work during the first few months, not sure what she changed.....
Old 09-16-2012, 06:37 AM
I finally went back to the dealer to ask for help on this. Now I better understand zmao's reply.
In addition to setting the seat memory using the buttons (this locks in your base settings), iDrive also remembers your last settings. For example, you may have made slight adjustments during a long trip or lent the car to someone using your FOB. The memory buttons get you back to your starting point if needed. Apparently each FOB needs to be individually set up so that it automatically changes the seat position the next time that you unlock the driver door. Go to MAIN MENU / SETTINGS / DOOR LOCKS / and then make sure that LAST SEAT POSITION AUTOMATIC is selected. Then get out, lock the door and repeat the process with the second FOB. In my case I set up my wife's correctly and just assumed that the setting was good for both FOBs. After I went through the process with my FOB everything worked fine. Not intuitive but now that I have gone through the process it makes perfect sense. Having iDrive remember seat, mirror, AC temp, radio station, etc is a great feature.
2013 bmw x3, memory seat
