E34 (1989 - 1995)
E34 Engine HELP!! Or, "Shouldn't this cable be connected to something?"
Hey,
I just joined Bimmer nation recently. I was cleaning the engine compartment and noticed a throttle-like, or actuator cable dangling. Don't know what it is, don't know if I knocked it loose while cleaning. I haven't and won't try starting the engine until I decipher it. It runs just under the the throttle body, I think. See pix and tell me what you think.
Thx! Dave ![]() ![]() ![]()
Is it the cruise control cable . Does you cruise control work ?
Sent from my Desire HD using Bimmer App |
![]() There are two cables: one for the Cruise control and one for the accelerator pedal. If you can still accelerate then the cruise control cable is at fault. Use RealOEM.com to find the plastic bushing needed for the repair. |
Also but I'm not sure about the model u have , wondering if that is also a kick down cable
P.S. Is that a broken fan blade I see? You better replace that before it throws off your waterpump bearing. Should be 3 hex head screws on the front of the fan clutch. You may have to remove the shroud as well.
![]() Couldn't help it paperplane. Just kidding with ya'. We're even now right ? ![]() And to Dave, Paperplane is right. You need to replace the fan. As an FYI, I have heard bad things about aftermarket fans coming apart and doing massive amounts of damage. I would recommend OEM only for the fan blade.
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
as for that cable, i cant tell from the picture, what engine do you have? in anycase, it will be either the throttle, cruise control or maybe kickdown. which ever it is, it is safe to start the car. start her up and press the accelorator pedal, if nothing happens then theres your answer
Now that you mention it...
Now that the mystery of the mysterious cable has been solved the broken-fan-blade-throwing-off-the-waterpump-bearing thing has me nervous. I just bought the car and the blade was part of the whole "as-is" deal. Would I feel a vibration or something if the bearing was blown? Would there be any collateral damage if this was the case, or would I simple be replacing the waterpump along with fan? Feel free to scare the crap outta my wallet as you let me know that what's what. 'preciate it. DTT |
with a fan like that with so many blades, i really doubt it will mess up the waterpump. a 5 or 6-blade fan maybe
He has the M60, so its electronic kickdown.
@BMR LVR lulz.....just sayin
Yeah my guess as well is the cruise control, the po of my car had a problem with the throttle sticking a little after using the cruise control and the idiot cut the damn thing b/c his wife was driving it and it scared her
If the gas petal throttle works i would say cruise control secondary throttle cable. I would get a Bentleys Manual for that BMW for best results.
Could it be the cruise control actuator?
see this parts like and let me know what you think. http://data.bmrparts.com/bmwparts/BM...711378315.html |
Yes, that's the cruise control cable. There is supposed to be a plastic bracket that sets in the hole below the intake. I took some pictures of mine the other day (see below). Definitely get that part on order!
Sent from my Droid Incredible
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506 BMWCCA Member# 451235 (Summer) 2001 330Ci - ZSP (Winter) 1994 530i "Greenie" - LOADED
Yup, the plastic fan is much easier to replace than the waterpump. You will probably extend the life of the WP by doing so.
Just follow what I said above to replace the fan without removing the clutch. Use allen keys and a screwdriver handle. |
Not the cruise control cable. That cable comes from your ASC actuator.
You will note you now have a yellow triangle with ! when you start the car. This is because the actuator has no "feedback/tension" on startup self test. Hard to tell from your picture but there should be a threaded plastic sleeve that passes through the notched holed bracket. If you cannot reconnect then secure cable away from fan. Car is safe to drive you just have no traction control.
E34 530i SECONDARY THROTTLE HOUSING TUBE ASC Bowden cable Ads 2 part no. 17 - PN 35411163163 http://www.realoem.com/bmw/showparts...51&hg=13&fg=15
Bimmer Dave ![]() Remember Boys, once you've grown-up, Santa delivers his joy year-round... on a flatbed! 1994 E34/530i manual, Oxford Green Metallic on Tan - totaled (not my fault... honest! )1997 E39/528i manual, Arctic Silver Metallic on Black |
I'm going to start a new thread to continue this conversation....
http://www.bimmerfest.com/forums/sho...70#post6971970 join me, won't you?
Ah, overlooked the ASC system for the newer models. Glad that is settled.
Ok, question pertaining to this cable. My car runs like crap when it is in it's plastic holder. But when I take the cable out of the plastic holder and it rests against the manifold, it runs like a champ. Any ideas?
I believe the cable controls the intake flap. So it seems that the car runs better when the flap is more closed. Does this mean the computer is running a bad air/fuel mixture causing it to bog down, quite noticeably? Would this then indicate a bad MAF sensor? Any ideas would be appreciated. |
Cable should not hold flap partly closed. Now you know why it was discnected. I guess it (the cable) has not been correctlt fitted.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
Should be adjustable. Keep looking for an adjuster nut somewhere.
