Some Cobb experience - Bimmerfest - BMW Forums
Old 07-25-2012, 08:24 PM
burnie35's Avatar
burnie35 burnie35 is offline
Old Timer (Really)
Mein Auto: 2009 BMW 535i Sport
I've been running Cobb AccessPORT on my 535i Sport for a couple of weeks. Installed Stage 1 Sport Stock Throttle v401 about a week ago, and love it. It makes the car feel smooth as silk ... smooth acceleration and shifting. Even my wife loves it ... although she always is a bit nervous that I'm going to screw up our bimmer.
Today installed Stage 1 Aggressive Stock Throttle v401, and was taken aback by the extra power. Drove around for a while and decided to put it back to Stage 1 Sport, because it felt more "daily drivable", while Agressive didn't seem quite as smooth. Of course, when I'm in the mood I'll change it back to Aggressive.
Running 93 octane here, so even Drive and Sport modes kick butt ... while Agressive kicks a$$.
For the heck of it, I made some quick runs while monitoring the boost. They were run in regular automatic Drive, and all I did was hit the throttle to "passing gear" (as we used to call it). RPM went to about 6k each time. Boost for Stage 1 Drive maxed at 14.4 psi, while the Aggressive maxed an 17.1 psi. (That's another reason I went back to Sport. I felt that there's no need to work the turbo's too hard on a day-to-day basis ... just my feeling).
2017 X5 35 M-Sport, Carbon Black, Black
2009 535i Sport, Jet Black | Cobb Stage 2 Aggressive | Injen DCI | AR Downpipes | BMS Led Angel Eyes | Michelin Pilot Sport A/S Plus
2008 528i (Retired)
2006 328ci (Retired)
1975 US Army (Retired)
Old 07-25-2012, 11:01 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
Hey what's up Burnie. Im now running stg1 aggressive map also but I am using the linear throttle map. The stock throttle map lets you push the pedal down less to get more power. I like the linear better since it feels smoother when I press down the pedal and when I really press down the car goes into take off mode. The sport mode was fun but I'm going to keep mine in aggressive mode. If you are worried about the boost, which ive see other cars running 16-17 psi max, you can datalog a couple of runs and send them to Cobb or post them on their forums for examination.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 07-26-2012, 07:53 AM
mermar mermar is offline
Mein Auto: 535xi
Thanks for the great write-up. I am exactly like you - want a healthy bump - but not at the expense of over stressing the sweet in-line 6 we have. Im planning to order my cobb in a few weeks. It has been so hot here I thought it would be better with cooler ambient temps while I install and 'learn' my new Cobb tune. Also, I think Cobb was on the verge of going to a new version for the N54 - as it had been in beta for a while. I too use 93 octane. You mention it is very smooth - is it also noticeably quicker in sport setting?
BMWCCA
09 535xi Sport, AT, Staggered Michelin Super Sports, purely stock now, Passport 9500ix
Old 07-26-2012, 10:38 AM
burnie35's Avatar
Old Timer (Really)
Yes, a lot quicker and smoother than the factory settings. I used the Drive setting for a little bit, but it didn't do much for me.
2008 528i (Retired)
Old 07-26-2012, 06:30 PM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
Glad to hear that you're happy with the COBB AP as it definitely gives the car the extra power and kick it deserves! The v4.01 and v4.02 Off-The-Shelf maps for BMW N54 Cobb AccessPORTs have been promoted to General Release. The v4.01 and v4.02 maps now supersede v3.01 maps, which have been archived. COBB Tuning recommends upgrading to the latest version of the maps for optimal performance. These maps can be downloaded from the BMW AccessPORT Off-The-Shelf Map Database. For instructions on downloading maps, transferring them to the AccessPORT and flashing them to the BMW ECU, please see the Step-by-Step Map Download and Install Tutorial.
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
Old 07-26-2012, 08:18 PM
burnie35's Avatar
Old Timer (Really)
I assume the production version 401 is the same as the beta 401 ... am I correct? Or do we need to download a copy of the General Relase version. If they are different, normally they would have a different number.
2008 528i (Retired)
Old 08-02-2012, 09:21 AM
Mein Auto: 535xi
So if I order a Cobb AP from you next week does it arrive with b4.01 pre-installed or do I install the software on the AP when I receive it?
BMWCCA
Old 08-04-2012, 07:35 AM
hp jnkey hp jnkey is offline
Mein Auto: 535i & C6
Mod
Once Cobb is installed, how long does it take to change maps that are loaded into the Access Port?
Old 08-04-2012, 10:23 AM
uwhusky's Avatar
uwhusky uwhusky is offline
Mein Auto: 2008 e60 535xi
Originally Posted by hp jnkey View Post
Mod
If you're installing a map to your stock BMW, it takes about 20-25 minutes the first time. This is because it first takes your stock map from the car and downloads it to your AP, then it installs the map you chose from the AP to your car.
If you're installing a new map over an old map (like going from Sport Map to Aggressive or Stock throttle to linear throttle) it only takes about 5-10 minutes because it doesn't need to download the map from your car at that point.
2008 e60 535xi : Alpine White / Natural Brown / Poplar : Auto : Sport : Prem : Nav : Cold Wx : Comfort Access : PDC : Sirius
Aftermarket: K&N Air Filter : Clearbra : Tint : 12mm H&R rear spacers : Cooper Zeon RS3-A Tires: Debadged : Matte Black Kidney Grille : OEM M5Tech Front Spoiler
Old 08-04-2012, 10:30 AM
Ok, thanks for that.
I thought it would only take a minute or so.
Old 08-05-2012, 08:59 PM
Vax Vax is offline
Mein Auto: 2008 535i
I've seen charts on performance gains for just adding the Cobb AP alone. I have not seen data on how much more power and torque can be gained from adding intake and or exhaust in addition. Anyone done this stepwise?
I guess same for JB4? Anyone added the JB4 first and then further tuned? Is it diminishing returns or not?
Old 07-26-2012, 07:22 PM
uwhusky's Avatar
When looking at the various maps, they list requirements for the various stages.
What do these abbreviations mean in that chart? IC, DP
For "Intake", I'm assuming they are referring to a dual cone intake?
Old 07-26-2012, 09:05 PM
booyaazaa's Avatar
What's up uwhusky. The abbrev IC = intercooler, DP = downpipes, CBE = cat back exhaust.
2009 AW 535i
Old 07-27-2012, 08:19 AM
uwhusky's Avatar
Thanks for clarifying. I have none of those and have no plans of installing any of them.
I am seriously thinking of installing the Burger Motorsports dual cone intake. At only $95 and a fairly easy install (or so I've heard) sounds like a relative "no brainer".
Old 07-27-2012, 08:46 AM
That is absolutely correct
You may want to re-download and re-flash your car with the general release v401/v402 maps.
Old 07-27-2012, 09:25 AM
uwhusky's Avatar
Just out of relative curiosity, what are the rough estimates on cost for each of these mods?
Intercooler?
Downpipe?
Catback exhaust?
Old 07-27-2012, 07:55 AM
xclone's Avatar
xclone xclone is offline
Send a message via AIM to xclone
Mein Auto: 2008 535iA
It's pretty much any after market intake. The stock intake is a limiting factor when tuning the engine so any aftermarket one will suffice.
BMWCCA Member 368765
2008 BMW 535iA | Cobb stg 2+ | FBO | Meth
Old 08-03-2012, 05:40 PM
booyaazaa's Avatar
If it doesn't it is very easy to up data the AP. Just install the AP manager program it comes with or download it from cobb tuning. Once installed you connect the AP to the pc with the program open, update the AP, plug the AP into the car to determine ecu and then replug the AP and download the new maps based on your ecu. There are lots of youtube videos on how to update. It is definitely worth getting an a whole lot of fun once installed.
2009 AW 535i
Old 08-04-2012, 11:24 AM
booyaazaa's Avatar
It varies based on your cars battery strength. When i change maps its only a few minutes. But like what husky said to new install/uninstall it takes a little bit of time.
2009 AW 535i
Old 08-06-2012, 05:53 AM
xclone's Avatar
All the supporting mods do is allow you to go more aggressive with the tune. Believe me, there is a huge gain between stag 1 and stage 2 plus. Around 40hp. It all depends on how far you want to take your car though.
The intake should be used with any tune. Adding an exhaust did little for me, performance wise, besides making it sound better. It did, however, remove the back pressure from the system (turbos do NOT like back pressure) and make me about 40 lbs lighter (about a 4hp gain in weight reduction).
The high you go with any tune the more in diminishing returns you will get unless you are making serious engine modifications (bigger turbo, single turbo, engine swap, etc). When you consider the price of those items though, the amount of HP we get, per $$ from a tune is outrageously cheap!
Old 08-06-2012, 09:16 PM
Vax Vax is offline
So why is it a big deal removing the back pressure if there is little hp to be gained? Longevity for the turbos?
Old 08-07-2012, 02:52 PM
xclone's Avatar
I told myself i was going to only do a cobb ap and nothing else. But I'm finding myself looking at the bms dci and a remus exhaust. I know many have argued this point with stock box w/bms dropin vs bms dci. The only thing is having to uninstall when i take it in for servicing and vice versa. That is what has me on the fence still from pullin the trigger. Damn these cars get expensive.
From what I have seen (and heard), no dealer will care about ANY intake you have as long as you have a filter on it. Intakes alone give you nothing but sound and do not impact the operation of the engine or fuel system.
Just wait until you decide you want an IC, Methanol injection and downpipes... I was just like you, I just wanna do this and i'm done. That first step is damn slippery..
The turbos will be much happier with less backpressure. The 535 especially is pretty restricted on the exhaust side with 2 sets of cats and 2 mufflers. When you replace the exhaust you remove alot of that (so you get more power from a weight reduction), less backpressure (happier snails) and a much nicer sounding car.
Old 08-10-2012, 09:44 PM
booyaazaa's Avatar
Ya, I was looking at a IC upgrade but I need to wait since my wheels will be arriving soon, got to buy some new rubber and I just ordered my Remus sport exhaust. All I know is these toys add up quick. So I finally pulled the trigger today and im running a 27/73 e85 mix in my tank. I'm not sure if it is a placebo affect but the engine seems smoother and it feels like it pulls stronger through the rpm's. I'm running the same Cobb stg 1 aggr map that I've been running for the past month.
2009 AW 535i
Old 08-22-2012, 06:43 PM
burnie35's Avatar
Old Timer (Really)
Well, it's been about a month since I loaded the Cobb AccessPort Stage 1 Sport (Stock Throttle) to my bimmer (2009 535i Sport). And I must say, it's been a blast! Even my wife enjoys the extra acceleration and power.
But alas, I had to uninstall the Cobb a few minutes ago because it's time for a "check-up". Now have almost 46k miles on her, so it's due for an oil change, spark plug change and intake filter change. Also, since I'm so close to the 50k miles end of warranty (I didn't opt for and extended warranty) she'll be getting a good once-over at the dealer, along with checking things that I've identified as possible problems. (We've had 3 bimmers from this dealership in Orlando since 2005, have had the same service rep the whole time, and so far at least, have been well taken care of).
Can't wait to reload the Cobb next week though!
2008 528i (Retired)
Old 08-06-2012, 12:49 PM
booyaazaa's Avatar
2009 AW 535i
