E90/E91/E92/E93 (2006 - 2013)
Remote range is horrible .... getting worse?
I don't remember feeling this way the first year i owned the car, but recently I'm getting HORRIBLE range when I try to lock/unlock the car. Unless I jamb it against my chin I need to be within 20 feet!
I switched to the other rarely-used key and the result was the same. Any ideas? "Remote" and "range" didn't return much in the search....
The word "there" can appear as a pronoun, as in “over there". "Their" is a possessive pronoun. In a phrase like “Susan and Bill's car,” it could be used to to make a new phrase: “their car.” ”They're” is a contraction of “they are.” “They are” should always be able to replace “they're.” Extra credit: It's "I'm looking for an M3" not "I'm looking for a M3". |
But, if a new battery doesn't change anything then I suppose that it is possible that the car's receiver circuitry is going bad. Hopefully just a loose connection to the antenna (wherever that is). Frank.
ED Vehicle: 328i Platinum Bronze / Beige / Light Burl | Sports (paddles) | Premium | Auto | Navigation | Fold-down seats | Alarm | Comfort Access | iPod integration. ED Tour: 1st June - 13th July 2009. (Route map). ED Progress: Delivery of M1100Z on 2nd June 2009; Drop off at Geneva 13th July; The journey home on 'Ryujin'; Redelivery 19th September. |
Or is the official range 20'? |
Sorry ... I completely forgot I had made this post.
I don't think it's the batteries, one key is 1.5 years old and the other one is original (2006). Do you still change the batteries in these? I thought they charged in the ignition? (I don't have comfort access).
Current Stablemates: '12 Porsche 911 GTS Cabriolet; '11 BMW 335is Convertible; '08 BMW 535xi Favorite Cars Gone But Not Forgotten: '09 Corvette ZO6; '04 MB S600; '01 BMW 740iL; '90 Nissan 300ZX 2+2; '89 Jeep Grand Wagoneer; '79 BMW 320i; '79 MB 300D; '67 MG Midget |
Open your mouth slightly, face your vehicle, point the key fob at your skull from beneath your chin, click button, enjoy double / triple range.
e90m / ssii / foxred / wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer / no chrome WHEELS FOR SALE
Did you apply tints?
Some tints block radio signals. |
Which window is the antenna in? The windows are tinted, but obviously the windshield is not and the range is still crappy when I approach the vehicle from the front.
Glad to see we cleared up the fact that the batteries recharge during driving. One remote is less than 2 yrs old so that shouldn't be the problem either. Did you read my original post? It still sucks even when I do that.
If the antenna is in a window, it will be printed on like the defroster traces in the rear window. You may actually mistake the antenna traces for the defroster traces. Look for similar traces in the other windows.
I think the most probable culprits have been identified: The tint and/or a weak antenna amplifier. Are you still under warranty? The nuisance risk here is they may blame the tint and refuse to diagnose or replace the car's receiver until the tint is removed. ![]() Quote:
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
Some time when your car is parked in an open lot with not many other cars around, you could experiment a little to figure out how to get the best range. |
I have the same issue and I, too, don't have comfort access. Therefore, my batteries charge with driving and should both be charged by now. Range is awful...20-30 feet max.
I, too, had my windows tinted but I'm having a hard time buying into the claim of tint messing with it since I most often approach the car facing the antenna (or so I assume I am), and the range was never stellar prior to the tint. With the tint being on the inside of the window (i.e. antenna more outboard of the layers) I don't know why/how tint is a factor. |
07' 328xi sedan premium pkg 06' cadillac sts v6 fully loaded |
Go to this page: http://www.pulseelectronics.com/prod...reference/faqs and search for "tint". Of course the above site is only relevant if the antenna is an on-glass type and is on a window containing tint. The tint doesn't block the signals, it de-tunes the antenna. Ever try to tune an old TV or radio and when you get close to the device, the signal comes in great but when you move away, the signal fades out? Your body (mostly water and some salts) is changing the electrical properties of the antenna and receiver circuit, causing the device's receiver to be tuned to a different frequency when you are close, and once you move away, this frequency changes. That being said, over time batteries degrade and eventually don't hold the charge they are designed for. Old cell phones are a good example. They get about a year of so old, and don't hold the same charge they used to. The same is true of the battery in the key FOB. Eventually the battery will degrade, and not as much energy can be delivered to the FOB circuity, causing a reduced output signal strength, limiting range. This is true only of rechargeable batteries, but... I just popped the battery door off of my FOB and noticed the battery was a CR2025 size 3V watch battery. To the best of my knowledge, these are primary lithium cells which CANNOT be recharged. I was also told by the sales man that putting the FOB in the slot should recharge the battery. I really can't see how that is the case. There are some rechargeable batteries in a CR2025 case, but the one I have is definitely not one of those. Bottom line: Pop the battery cover off your FOB. Check the battery. If it does not specifically say it can be recharged, or if it does not say "Lithium Ion", then get a new CR2025 battery and try that. |
The 5 series cars have a diversity antenna amplifier that is known to be the culprit with diminishing range on the remote AND FM radio reception.
See if you have one of these.
2008 535xi: Sport, Night Vision, NAV, PDC, HUD Mods Rear Seat Heat Retrofit, Passport 9500ci, HD Radio Retrofit Shock Sensor Alarm, Sport Automatic Retrofit , Active Backrest Retrofit, Fire Extinguisher, PROcede with Meth Injection Last edited by NoQuarter; 09-05-2012 at 01:06 PM. |
I'm not saying anything you said is wrong, just elaborating. |
2008 535xi: Sport, Night Vision, NAV, PDC, HUD Mods Rear Seat Heat Retrofit, Passport 9500ci, HD Radio Retrofit Shock Sensor Alarm, Sport Automatic Retrofit , Active Backrest Retrofit, Fire Extinguisher, PROcede with Meth Injection |
CR designates 'manganese dioxide lithium' chemistry which is not rechargeable. LIR designates a chemistry (variable types) which is Lithium Ion based and rechargeable. The first two digits ('20') indicate the diameter in mm, and the second pair of digits ('25') the thickness in tenths of mm. I'd be curious if a BMW supplied from new non-Comfort Access fob had a basic 'CR' non-rechargeable battery since that contradicts in the most absolute sense with their manual's notification that the fob recharges while it is in the slot. Someone in BMW's tech pubs or more likely their fob supplier messed up. Frank.
Non-Comfort Access keys have rechargeable batteries that cannot be replaced without disassembling the fob. OP stated in post #4 that he does not have CA therefore advice to inspect/replace the battery is unhelpful. (Also, the rechargeables in the keys easily last over a decade with normal/regular use.) Also, FWIW: http://www.bimmerfest.com/forums/sho...6&postcount=18.
Nope, no warranty, the car is a 2006.
Since both remotes have horrible range I think we have indeed identified the culprit as the tint or the antenna amplifier. It's not a dealbreaker ...... I may not even pursue it any further, after all the remotes do still work - I just found it odd that the range was that much worse than my previous 2 cars, both E46's - one of those with tinted windows as well.
