E36 (1991 - 1999)
Old 08-13-2012, 03:29 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Hot start issue and something else while youre here
Ok been battling this issue for a while now
When the car is operating temp and I shut it off for 5 minutes it'll start up no problem.
However if the car sat for maybe 15-20 mins it will refuse to start or will have a hard time stating up. Most cases extra long crank, sometimes more than one extra long cranks or long crank than it catches misses goes to about 300 rpms stall or it will gain composure and idle fine. sometimes it'll stall twice.
Leave the car for about 2-3 hours or more it starts up first try.
Long story short:
When Hot-
5 Mins =Start
15-20mins = No start
2.5hours- or more = Start
I changed
the Coolant temp sensor = No change
Cam sensor= thought it worked but today it took 2 cranks on the first start of the day
Crank sensor= first thing I changed (Cant remember if this was the reason why I changed it)
Once the car is started it runs and idles perfectly
This has been going on before AND after chipping the DME
Oh and once it starts it does have a weird smell (gas maybe?)
This may have to do with when I let off the throttle the car stinks but as long as my foot is on the gas there's no smell
Young Ken, suggested a clogged return line and the fuel is just running in to the chambers
And before the 1st start of they day my car started like it was missing for a second or 2 then continues fast idling normally
-Dino
Old 08-13-2012, 03:34 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
This may sound odd, but have you ever changed your O2 sensor?
Changed fuel filter?
Cleaned ICV?
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 08-13-2012, 03:41 PM
BMRfanatic's Avatar
o2 was changed- CEL went away less than a mile for it
Fuel filter was changed last year
ICV was cleaned last year
TB- cleaned last year
Sparks- last year
Coils are all in the right ohm spec (but spark would cause it to act up all the time no?)
Seafoamed not too long ago
Had no CEL after the o2 was changed but the light went out like 2 weeks ago
-Dino
Old 08-13-2012, 03:53 PM
peels'bimmer's Avatar
peels'bimmer peels'bimmer is offline
LSD = yum yum
Send a message via MSN to peels'bimmer
Mein Auto: '95 332IS
I have the exact same problem you are having. I have also changed and clean the same parts as you. The next thing on my list was to change my fuel pump and fpr (fuel pressure regulator). Try checking your fuel pressure, after the car is nice and warm.
Originally Posted by TRaV MaNN View Post
you never notice how ugly something is until you get rid of it
That's what my first wife said.
Old 08-13-2012, 04:05 PM
BMRfanatic's Avatar
Where and how should I go about doing that?
the crank sensor is ruled out. Got a constant reading of 638 ohms
-Dino
Old 08-14-2012, 03:40 PM
bigugly fab bigugly fab is offline
Dr.BMW
Mein Auto: 2015 M4
take off the fuel filler cap and see if it does that.
as in take it off BEFORE you let it sit.
Old 08-14-2012, 03:58 PM
BMRfanatic's Avatar
Hmm seems odd and easy enough to do
but what would that do to the issue?
-Dino
Old 08-14-2012, 04:10 PM
Dr.BMW
Mein Auto: 2015 M4
perhaps. try it and report back.
more than likely you will get a check engine light on, so make sure you have the ability to clear it for a major DMTL leak.
Old 08-13-2012, 04:39 PM
LSD = yum yum
Check out this thread on Bf.c. Although he is fixing a hose. It should be the same process of getting to the fpr.
http://forums.bimmerforums.com/forum...&highlight=fpr
Old 08-13-2012, 05:13 PM
BMRfanatic's Avatar
aghh looks like im gonna have to invest in a pressure tester
-Dino
Old 08-13-2012, 05:17 PM
jonesin's Avatar
The Canadian Prick.
Harbor Freight: $20.
Old 08-13-2012, 05:28 PM
BMRfanatic's Avatar
Thank God, I saw a video on how to narrow down if its the pump and other crap. Looked easy on youtube but we all know things dont go smooth when you actually try it lol
oh well Good luck to me
-Dino
Old 08-13-2012, 05:39 PM
LSD = yum yum
Can you post the video link?
Old 08-13-2012, 07:27 PM
BMRfanatic's Avatar
Part 1
Part 2
Sent from my SPH-D710 using Bimmer App
-Dino
Old 08-14-2012, 02:55 PM
LSD = yum yum
Thanks for the video link. That was very helpful, but damn, that guy has a boring voice!
Old 08-14-2012, 04:37 PM
BMRfanatic's Avatar
nope same thing took 2 tries to start it up
My check engine light bulb doesnt work so i cant tell if it caused a code
but then again OBD1 doesnt car for emissions so it probably wouldnt care.
Car ran the same with or without the gas cap
-Dino
Old 08-14-2012, 05:09 PM
Dr.BMW
Mein Auto: 2015 M4
no pressure came out?
Old 08-14-2012, 05:13 PM
BMRfanatic's Avatar
yeah pressure did come out
does it matter that I started the car, shut it off then opened the cap?
-Dino
Old 08-14-2012, 05:17 PM
Dr.BMW
Mein Auto: 2015 M4
:facepalm:
yes.
Old 08-14-2012, 05:21 PM
BMRfanatic's Avatar
agh , well the car has been sitting now, should I pull the cap now since the last time i started it was when i last posted my findings?
-Dino
Old 08-14-2012, 05:28 PM
Dr.BMW
Mein Auto: 2015 M4
do whatever you have to do to replicate the long crank AFTER you pull the gas cap off for a bit
Old 08-14-2012, 05:32 PM
BMRfanatic's Avatar
Ok i just took the cap off (car has been sitting for 30 mins now) no pressure came out
give it 10 mins then start it with the cap off?
-Dino
Old 08-14-2012, 05:41 PM
Dr.BMW
Mein Auto: 2015 M4
go start it and drive it, just like your first post. sheesh this is hard for you to understand! lol
Old 08-14-2012, 05:44 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Then park it and take cap off after turning engine off?
I'm not following either...
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 08-14-2012, 05:55 PM
BMRfanatic's Avatar
Lol I just drove it with the cap off nothing changed
What I understood was.
Take gas cap off, start car, drive it
When I 1st took the cap off there was pressure
unless you mean leave cap on, drive car , wait till i know the problem exposes itself then take off gas cap and see if theres pressure?
-Dino
