Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Audio & Electronics Forum
Hi-Fi upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Old 08-18-2012, 05:05 AM
Lurch09's Avatar
Lurch09 Lurch09 is offline
VA makes me miss WA
Mein Auto: 2001 ///M5
Mediabridge install question
So I'm trying to get the Mediabridge (w/BT) to work on an '01 M5 w/DSP and 16:9 Nav.
The power cable for the DSP unit=(black to brown cable in the AMP, and the black/white cable to the green/red in the amp). That went fine.
Coax and RCA cables in to the DSP unit, then the 3 and 6 pin into the interface cable. Interface cable to the MB unit itself. Whew! So per the guide, DIP switches set to 1-ON, 2-OFF.
But when I plug the iPod into the USB port in the rear, I get nothing. The MB is getting power and charging my iPod but that's it.
Anyone know where I messed up?
I love my ///M, but I miss my 540.
Old 08-19-2012, 03:14 PM
Jeremy Bavsound Jeremy Bavsound is offline
Past Sponsor
Mein Auto: Bavsound
That is likely an issue with the DSP adapter! Make sure to verify all the coax connections, as well as the power connections are good and solid.
Old 08-19-2012, 06:00 PM
Lurch09's Avatar
VA makes me miss WA
Ok so I looked at my connections, and all appear to be well. I removed the power cables from the AMP power and re-attached. same result, though, when the iPod is plugged in it DOES register the MB (says audiovox on the top of the screen) so it knows it's there. But when I switch the mode on the stereo to where the CD player is all I get is CD1 Track 1, no ability to change track numbers. Also my iPhone isn't picking up the BT in the MB unit.
Whew!
Old 08-23-2012, 05:54 PM
Lurch09's Avatar
VA makes me miss WA
Ok still nothing. I think I'm ready to send this whole kit back.
Old 08-24-2012, 01:35 PM
Past Sponsor
Mein Auto: Bavsound
Lurch,
Please shoot me an email with your order number! It sounds like we have a defective unit and we would be more than happy to get a swap setup for you to get you up and running as designed!
Old 08-24-2012, 02:35 PM
Lurch09's Avatar
VA makes me miss WA
Originally Posted by Jeremy Bavsound View Post
Lurch,
email sent. thank you!
