Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 08-20-2012, 11:22 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
For Those Of You Who Want To Access The Hidden Menu
For those of you who want to access the hidden menu please read. This option will allow you to check your current operating voltage level, engine temp an many more options which cannot be seen through the I drive follow these steps. 1st hold the reset button, the next light that would pop up would be "ABS". Ignore that and keep holding the reset button. There will be a second screen popping up, ignore that one as well and keep holding the reset button. As soon as the third screen pops up, release the reset button. This screen would have approx 15 or 16 options. Go the option which says "unlocking". Press and hold reset button. The unlocking menu will now appear on the right side. Input your unlocking code (for me it was 11 - add last 5 digits of your VIN number). As soon as you put the code, hold the reset button. The screen on right side would disappear now and you would be back to 15-16 option screen. Now go and select the desired option an press and hold the reset button while on the selected option. You would now see the info on the right side of the screen. I give all credit to "itsgonabeme".
Old 08-21-2012, 05:17 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Certified 7
Mein Auto: 2004 745i
On the 745 unlocking is item number 19.
Old 09-03-2012, 07:53 AM
Big N Fast Big N Fast is offline
Mein Auto: 03 BM760Li, 67 Mustang
Mine was 3...
Just like rookie 2008 said...add the last 5 digits together! Thanks rookie!
Old 03-01-2013, 09:52 AM
Thesatman Thesatman is online now
Mein Auto: 2008 750LI
Can anyone provide an explanation for each option available to select? Yes, ones like the charging mv reading are easily understood...but there are several that are not.
HTML code is Off
