BMW Motorcycles (aka Beemers) and the Competition
Have an interest in BMW motorcycles or just motorcycles in general? Discuss the line of BMW motorcycles and how they may compare to the rest of the competition in this forum! |
ride it and have fun !!
1999 BMW 328is/M Sport Package/5 speed/122k and climbing/
2010 Audi S4 Premium Plus/3.0L Supercharged V6/Quattro/6 speed/25k and climbing/ |
Mike White 2001 Z3 3.0i Roadster (Topaz Blue, 5-speed manual, Sport Package, CD radio, heated seats and mirrors, non-power top via special order) "Beemer" is for my BMW motorcycles! |
Oil Leak?
Thanks Mike. I had my '91 K75 serviced at the nearest dealer (over an hour away and $1000 later). An oil leak at the "crank case cover" was identified but not repaired. Any idea whether this is something I could tackle myself. I have average home mechanic skills but NO experience with MC or BMW repair. Thanks.
If by "crank case cover" you mean the cover on the right side of the engine that says "BMW" on it, this is a fairly simple repair. There is a "rubber" gasket that seals the cover to engine seam. The only difficulty is the water hose the runs through the front end of the cover. You should be able to just: 1. remove the 8 bolts that hold the cover on 2. pivot the cover off the engine using the water hose for support 3. remove the old gasket 4. inspect and clean the two gasket mounting surfaces 5. fit the new gasket (IIRC, the gasket goes on "dry") 6. refit the cover and tighten the 8 bolts. Done!
Dealer Work done
The dealer put on 2 new tires, changed engine engine oil, gearbox oil, fork and final drive oil, brake fluid, gearbox and shaft lube, fuel filter, air filter, spark plugs, safety check, state inspection, replaced rear brake pads and crankcase breather. Sound like a value?
The crank case cover refers to the one in front (not the one with "BMW" on it), which they said is a big job to work on, and has only sealing compound, no gasket. Watching it for now. Appreciate your advice. Thanks. |
Been away for awhile. Looking for advice on K75 preparation for winter storage in un-heated garage in upstate NY. All the fluids are new. Should I fill the gas tank or empty it? I figure fuel stabilizer for sure. Thoughts on the necessity of spraying WD-40 into the spark plug holes and cycling the cylinders? Any other storage prep advice welcome. SJM
I never bothered with the cylinders, never had any problems.. ![]() Pull the battery..
