Old 08-27-2012, 08:48 AM
msbc9090 msbc9090 is offline
Mein Auto: highway
01 750iL - Code P1461
2001 750iL E38 Code P1461
Converter?control module or battery?
Old 01-24-2015, 03:40 PM
Jodel Jodel is offline
Mein Auto: 2000 750IL
2000 750IL code P1461
Hello All! This is my first post. Wondering if anyone found the solution to this error? New Batteries already put in but low voltage to Cat bank 1 "P1461" still causing Check Engine Light. BMW couldn't find the issue.
Old 01-26-2015, 09:41 PM
Hey guys, Any one with experience with this on out there?
Old 01-27-2015, 12:12 PM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
You said new "batteries" so you replaced both? How long ago?
A quick google search and:
http://www.bimmerforums.com/forum/sh...rom-750-Owners
"New" batteries are hopefully charged enough to start the car, but are usually not fully charged since they have been sitting around a while before you install them, perhaps you have a charging issue.
No personal experience so I could be wrong, but that thread looks good.
Old 01-27-2015, 07:26 PM
Thanks for the input. I saw that thread too but the charge is good. Both batteries were replaced this month.
Old 03-10-2016, 02:51 PM
This seem to be a tough one.....Anyone out there? I have the same issue for months but can't find a straight answer even from my Indi mechanic...Help!!
Old 03-10-2016, 04:34 PM
Wow, going on 14 months and still no reply...have you verified the wiring or replaced anything since?
Old 03-11-2016, 09:04 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
There was some confusion with that thread above. The bottom larger battery starts the car, and upper 'systems' battery is smaller, and drives everything else.
Perhaps you have a problem with the battery switch on the side of the upper battery. This basically controls charging of both batteries, always giving preference to the starter battery.
Sound like the system battery has low voltage - might have been replaced, but is it getting charged ie is the switch working as it should?
Old 03-11-2016, 10:50 AM
Batteries both check out. I'm on the east coast, once the weather warms up the check engine light goes away. Temps drop, it's back.
