BMW Coding and Programming
Discuss coding options and features on your BMW here. |
One of the first things I noticed after picking up my F10 is that it did not have the radio menu and telephone options in the HUD like the F30 did. I figured that this should be a simple one to code and turns out that it was pretty straight forward although there is still some work to do.
In order to get these to work the following options in the KOMBI module need to be coded: Section 3000 - HUD_ENTERTAINMENT_ENABLE to aktiv (enables radio menu) - HUD_TELEFONANRUF_ENABLE to aktiv (enables recent calls list to be displayed) There is an additional setting for HUD_TELEFONBUCH_ENABLE that should enable the full contact list to be displayed, but it didn't seem to do anything (it may be that it is either the recent calls or the full phone book can be displayed, but not both, however I am just speculating as I have not tried this). There is one more setting in the HU_NBT module under section 3000 for HUD_ENTERTAINMENTLIST. When this is set to active a checkbox will appear under the settings -> Heads Up Display -> Displayed Information menu for "Entertainment/Telephone" however the checkbox cannot be selected. Although the box can't be selected, the HUD still shows the screens. I have a 2013 F10 which replaced the HU_CIC module with the HU_NBT module. The option for HUD_ENTERTAINMENTLIST may be in the HU_CIC, but I am unable to verify. I have attached a few pictures of this working in my car, but as always try/use at your own risk. Last edited by falcongeek; 08-29-2012 at 08:30 AM. |
Very Nice!
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
Cool !!!
Are these options available in 2011 models (F10 528i Feb 2011 Built)
2011 BMW F10 528i M Sport |
Sweet! Trying this tonight on my 2012 F10. I will look for HUD_ENTERTAINMENTLIST in the HU_CIC and let you know.
2012 550i MSport 6MT - Dinan S3 - Imperial Blue Metalic/Everest Gray - 20" 373M Wheels |
So Nice! I will try this later on my 535i
I could not seem to locate:
HUD_ENTERTAINMENT_ENABLE HUD_TELEFONANRUF_ENABLE in KOMBI, 3000 I was also unable to locate: HUD_ENTERTAINMENTLIST in HU_CIC, 3000 This is on my 2012 F10 (550i). Anyone else? Maybe this is just available with 2013+?
This was added with the 2013 models, as part of the next generation Navigation / iDrive. At the hardware level, KOMBI is still KOMBI, but HU_CIC is now HU_NBT. So, it may be possible that a full dealer programing of the car with 47.x will flash KOMBI and HU_CIC with new firmware, and then these entries will appear, or it may be, particularly in the case of the Head Unit, that HU_CIC can not be flash updated o HU_NBT. It's too soon to say. We need a 2011 / 2012 model with HUD to be fully programmed with 47.x and see what the affect is.
I was able to successfully code the radio menu and telephone options in the HUD, as mentioned in post #1 by coding the KOMBI module Section 3000 - HUD_ENTERTAINMENT_ENABLE to aktiv (enables radio menu) - HUD_TELEFONANRUF_ENABLE to aktiv (enables recent calls list to be displayed) Both options exist in the KOMBI Module after the software update (they did not exist in the older version). However, I was unable to locate HUD_ENTERTAINMENTLIST in the HU_CIC module. Not a concern, as I still get the functionality in the HUD. I am very happy with this
i thought it is possible to upgrade the fw versions with esys, am I wrong? Have you played with it? |
You will be able to update the firmware on any ECU so long as BMW releases updated firmware. What I am saying is that Kombi seems to be the same in the 2013 model, so you can update your Kombi firmware, and get the same coding options and features, so long as those features are not dependent on HU_NBT. You will be able to flash HU_CIC to newer firmware, but no firmware update will ever turn HU_CIC into HU_NBT. HU_CIC will always be some version of HU_CIC, and HU_NBT is a whole different animal.
Did you get this from E-Sys VCM Current I-Step, and can you confirm this is the Integration Level Reported there? The 520 is puzzling, as for F10 chassis, all I have seen from 7/12 is 531, 532, and 533. In fact, I don't even see a 520 for any other chassis either.
Ok. Thank you. You have ISTA/P 2.47.4.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 09-18-2012 at 06:09 AM. |
@falcongeek; What are the names of your Kombi and HU_NBT CAFD Files?
@falcongeek; By chance does your car have SLI (Speed Limit Info), Options 8TH and 8TD?
HU_NBT: CAFD_00000DED_001_019_008 I do not have SLI. |
Sweet feature! I just coded this to a late build July F10 with HU_NBT module and everything worked flawslessly
Does the checkbox for "Entertainment/Telephone" in the Displayed Information screen in the HUD settings work for you?
His music selection was able to be seen on his HUD, so I think it works. I didn't check the box you are speaking of. I will ask him
Thanks Falcongeek and cn555ic
Love this new feature! We only coded this part so far: Section 3000 - HUD_ENTERTAINMENT_ENABLE to aktiv (enables radio menu) - HUD_TELEFONANRUF_ENABLE to aktiv (enables recent calls list to be displayed) Right now i notice the radio menu showing up on the HUD and incoming phone calls. Haven't had enough time to really play with it yet but this feature is sweet! Alan
Current - 2013 N55 535xi Msport SAT Retired - 2009 N54 335i Msport 6MT Retired - 2000 M52TU 323i ASA Supercharged 5MT More photos of my car here |
@falcongeek;
Does your car have option 6VC (Combox)? I am guessing not. And do you have CMB_MEDIA and CMB_ECALL ECU's showing in E-Sys? Also, what is your Bluetooth option? I am guessing instead of 639 and 6FL you have only 6NL?
OK....English Please
Shawn -
I have a VERY EARLY bulid 2012, are you saying its doable (with a firmware update only), or doable without needing a visit to the dealer, or not doable at this point? This would be a HUGE usability improvement IMO, i would wrank it up there with the TPMS activation ![]() Aceman
2012 550iX Alpine White, M-Sport, CW PKG, SAT, HUD, PREM SOUND, SUR VIEW CAMERAS Mods: OEM Spoiler, 35% tint, Front/Rear Mud guards |
marcosg just had his 528i with a Feb 2011 build date programmed and they are working for him.
#25
any instruction or possibility to get these update without 100 bottles of scotch ? greetz sibob |
