E90/E91/E92/E93 (2006 - 2013)
330XI wont start
Recently I had a engine misfire. I found it was a bad coil. The car was having trouble turning over when I started it for a few weeks now. I replaced the bad coil today and now the car wont turn over at all. Does this sound like a battery issue?
if it was running before you replaced the coil, i would double check the coil you replaced.
I could start it yesterday with the bad coil out of the engine... today it wont start at all... the engine wont turn over...last time I had it in the repair shop the guy told me I was going to need a new battery soon but was telling me it would cost me $350 for him to do it. I was thinking about replacing it myself.
jump start it?
if you didnt drive it around after all the starting and testing you may have a dead battery |
How about measuring the voltage ?
If this car hasn't had the battery replaced before you are due. There is a glass eye on the battery that tells you its condition . I assume you mean its not turning over. You can get a batter for between 110 and 200 in the US . Don't use battery backup when changing a battery in these cars it blows fuses. You should register the battery after installation. The cheapest way is to get a coding setup which will give you diags and the ability to code. Last edited by ctuna; 08-28-2012 at 11:05 AM. |
thats what Im thinking the last time I had it in the shop I was told my battery was going to need to be replaced.... about how long do they last?
how do i read the battery indicator?
It tells you right on it.
green good
black inadequate charge or marginal battery yellow bad When mine was marginal I would get long cranks . I tried trikkle charging it but it wouldn't hold a charge very long . Like from 12.4 to 11.8 volts overnight it had the black indicator. Last edited by ctuna; 08-28-2012 at 12:00 PM. |
| Tags |
| 330xi, battery, coil, engine, misfire |
